Old Feb 25, 2008, 07:55 PM
Life is better w/ RC
kman712's Avatar
United States, IL, Rantoul
Joined Aug 2004
Question
Thrust line on Bud Nosen Cub
I purchased a Bud Nosen J3 Cub at an auction without an engine. I plan to install a Zenoah 26e but need to know where the thrust line is. Will it make a difference if the engine is mounted a little above or below the line?
Also, can someone tell me where the CG balance point is.
Kman
kman712 is offline Find More Posts by kman712
Old Feb 28, 2008, 08:14 PM
Cheektowaga, NY
Joined Sep 2007
I have the quarter scale Bud Nosen J3 (1980's vintage kit), that is 90% complete. Here is what the plans list..
Engine - 3 Degrees down, 2 Degrees right
CG is 5 1/4" from the leading edge
I am using a OS 90 2 stroke...
Hope that helps...
edave41 is offline Find More Posts by edave41
Old Feb 28, 2008, 09:26 PM
kman712's Avatar
Joined Aug 2004
Thanks for the info. Do the plans indicate where the thrust line is? This should be where I line up the prop shaft. There are two lins drawn on my firewall, one about the middle and one toward the top. I assume one of these is the thrust line but I don't know which. How far up from the bottom of the fire wall do the plans show to mount the engine? I really thank you for your help.
Kman
Old Feb 29, 2008, 08:14 PM
Cheektowaga, NY
Joined Sep 2007
See correction..
Old Mar 01, 2008, 09:46 PM
kman712's Avatar
Joined Aug 2004
edave41, thanks for the pics of the plans. I think your plans are for a plane smaller than the quarter scale Cub I am working on, but I can scale things up and get very close. This information helps a lot. Thanks for taking the time to send the pics.
Kman
Old Mar 02, 2008, 09:00 AM
Cheektowaga, NY
Joined Sep 2007
KMan..
I apologize your comment that it may not be a quarter scale plane caught my attention..
Well I can tell you.. the first 25 Percent of the Bud Nosen Cub and Senior Telemaster blueprint look nearly the same.
The centerline is 5.25" from the bottom of the firewall plywood. The CG is 4 5/8 from the leading edge.
2nd time is a charm..
Old Mar 02, 2008, 07:41 PM
kman712's Avatar
Joined Aug 2004
edave41,
Yes, this plan looks more like my plane. Sometimes it's easy to confuse plans for big planes.
Thanks for taking the time to photo the plan, this answers my questions.
Kman
Old Nov 20, 2010, 07:54 PM
United States, IN, St John
Joined Mar 2010
1/4 scale Bud Nosen Cub
Can I get a copy of the plans for this kit. I just crashed my 30 year old model and would like to rebuild it..
Rafeek
rafeeki is offline Find More Posts by rafeeki
Old Nov 21, 2010, 04:35 AM
Relax, have a Cub
mewert's Avatar
College Place, WA.
Joined Apr 2004
Run a wanted ad in the classifieds and see what happens. You might get lucky.
mewert is offline Find More Posts by mewert
Discussion Thrust Line On Pusher raymacke Beginner Training Area (Aircraft-Electric) 4 Jan 18, 2008 02:11 PM
Discussion Thrust line on custom w/AA guts K4RT80Y Micro Ready-to-Fly 0 Aug 15, 2007 12:59 AM
thrust line on pushers? gouch Modeling Science 11 Sep 01, 2004 05:25 AM
Question Thrust line on a pusher nyoman Beginner Training Area (Aircraft-Electric) 15 Mar 04, 2004 08:30 PM
Thrust line on a bandit Heli Slime Electric Sailplanes 1 Nov 04, 2002 03:22 AM
