Old Nov 06, 2014, 05:17 PM
RickC_RCAV8R's Avatar
Canada, BC, Castlegar
Joined May 2014
V22 Osprey : Complete SCANS !
Gentlemen :
I have just completed the rescans of all of the bulkheads and profiles that I used to make my version of the V22 . These scans are of the 100% scale that I chose some years ago to yield a bird of some 63 1/2 inch wingspan . The scans can be scaled down to any amount using your printer . Note that the measurements for the fuselage bulkhead spacing is based upon the 100% scale !
Check out my blog for the details on this one and the CAUTIONS for using the pair of DATUM lines for the alignment and assembly of the fuselage .
Also please note that the wing drawings have disappeared over the years . I will have to remeasure the model and make up a drawing complete with the root and tip rib profiles and post them separately . This should be enough to chew on for now .
All comments and questions can be sent along to me and I will try to sort out any issues for you . Now I can start to build up some necessary Styrofoam blocks and ................
Regards to all : Rick
RickC_RCAV8R is offline Find More Posts by RickC_RCAV8R
Latest blog entry: RIX Ptarmigan : Upper Fuselage
Build Log VTOL Tiltrotor (Osprey V22) tom stanton VTOLs 170 Jan 10, 2015 11:37 PM
Help! V22 Osprey Nacelle Drive : HELP ! RickC_RCAV8R VTOLs 3 Oct 03, 2014 10:36 AM
