Old Jan 02, 2014, 10:27 PM
Hemet, CA
Joined Sep 2002
Programming the X-10 and RFU
Hi Jim,
I just got my X-10s and the RFU. I've been playing with them for a couple of hours but not making a lot of progress. My understanding was that by using the XDP.exe program I could program all the features of the X-10. By using my XDP I am able to program the receiver to change the relationship between the Channel number and the output number (which I thought was an X-10 function, not a receiver function) but while in the Receiver programming screen and going to the Servo output screen and I try to reverse one servo output and then updating the eeprom it doesn't work. I have two flap servos on channel 9 on my transmitter that must go in opposite directions. I put transmitter Ch 9 on outputs 9 and 10. Both servos follow the flap signal but I can't make them go in opposite directions by putting a check mark in the reverse column for channel 9 and updating the EEPROM. Both outputs 9 and 10 still go the same way they did before I checked the "Reverse" box for Channel 9.
Am I to understand that the XDP can't program the X-10 itself? The manual says it can be programmed with the Extreme Link module and software (not included). What software?
Also, on the RFU, are the two white portions of the antennas supposed to be the same length? The one I just got has one white portion about 0.150" longer than the other. If they are supposed to be the same length how long should the white portion be?
I'm looking forward to using these in my next plane but I have got to be able to reverse one of the servo outputs.
Art
Art Horne is offline Find More Posts by Art Horne
Old Jan 02, 2014, 10:37 PM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
X10 needs the serial link to program it as it doesn't have a radio link to connect.
theKM is offline Find More Posts by theKM
Old Jan 02, 2014, 11:11 PM
South Africa, LP, Polokwane
Joined Jan 2012
I have tried reversing with the serial link and the servo does not reverse, I have this problem on elevator pluged in on channel 2 and 9 of the x10+ and channel 9 mapped to 2.
INDIZA is offline Find More Posts by INDIZA
Old Jan 02, 2014, 11:36 PM
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Is your firmware version for the X10 1.1? Per the X10 thread:
"The v1.1 firmware that I just released today for the X10+ also has the new servo output code. This means that the output ports are totally independent from the channel. So, servo reversing and output are now OUTPUT port based, NOT channel based. The XDP software will show you Channel 1, Channel 2, etc. in the SERVO POSITIONS menu. I will need to change that so it shows OUTPUT1, OUTPUT2, etc. instead of CHANNEL. In the mean time, treat those controls as output ports. The failsafe is still channel based. I chickened out of making it output port based because I didn't want people ripping their rudder racks apart by having 2 out of 3 output ports set to different failsafes!"
GBR2 is offline Find More Posts by GBR2
Old Jan 03, 2014, 10:54 AM
Hemet, CA
Joined Sep 2002
X-10 firmware version
GBR3, where do I find the X-10 Ver 1.1 firmware?
TheKM, can't you program the X-10 plus RFU with the XDP?
Thanks, guys.
Art
Old Jan 03, 2014, 11:49 AM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Indiza, are you updating the EEPROM after making the reverse change?
Art, your firmware is the latest.
You MUST have the Serial Link in order to program the X10+. There is no RF on it, and no way to add RF to it.
JimDrew is online now Find More Posts by JimDrew
Old Jan 03, 2014, 02:19 PM
Hemet, CA
Joined Sep 2002
X-10 programming.
Jim, I am able to change the Channel # to Output # with the XDP and the RFU. Is that a change to the RFU coding or is that sent to the X-10 via the serial cable between the RFU and the X-10? The XDP.exe has provisions to change the reversal of individual output channels but they don't work. A previous poster (Indiza) also has the same problem and he is using the Xtreme Link. Can't the RFU provide wireless connectivity between the XDP and the X-10?
Art
P.S. I just replied to your post on the RFU thread.
Old Jan 03, 2014, 08:14 PM
Lake Havasu, AZ
Joined Jun 2005
That change is to the RFU. The ONLY way to change the X10+ using the XDP software is by using our Serial Link. There is no way to provide a wireless link to the X10+.
Old Jan 03, 2014, 09:07 PM
Hemet, CA
Joined Sep 2002
Servo reversing
Hi Jim,
Ok, I can't change the X-10 servo reversing but if I could change the RFU servo direction that would solve my problem. I tried many times to reverse one servo and, yes, I did save to EEPROM each time. I would change it, save it, then read it back in again and it said it was reversed but it wasn't. Indiza was having the same problem. Did the changes that GBR2 made fix this problem?
How can I tell what version of firmware I am using. When I run XDP.exe it says it is Ver 3.7.
I don't want to belabor the point, I do understand there is no RF link on the X-10. What I'm asking is since the XDP communicates wirelessly with the RFU and the RFU communicates serially over 3 wires to the X-10, couldn't that be a way to wirelessly communicate with the X-10?
Thanks again for all your help.
Art
Old Jan 04, 2014, 12:18 AM
Lake Havasu, AZ
Joined Jun 2005
It is not physically possible to program the X10+ using the RFU or Nano.
The XDP shows the firmware version in the information about the device (receiver or Tx module).
I will look at the RFU settings.
Old Jan 04, 2014, 12:30 AM
Joined Jan 2012
How do update to version 1.1? I have searched for update and it keeps saying that I already have the latest update but I am on version 1.
Old Jan 04, 2014, 01:19 AM
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
If you go to the website and then to download then to XDP software, if you go down the page you will eventually get to where it says Firmware Updates, at the bottom of the list is Updater 4.3. This is what you use to update the firmware in the X10 and other XPS products. Get the X10 into programming mode and hookup up to the Serial link. DO NOT start the XDP software. Instead run the updater file that you have downloaded.
Old Jan 04, 2014, 01:23 AM
XtremeLink South Africa
mikestark's Avatar
East Coast of South Africa
Joined May 2007
Indiza, my apologies for not replying via email.
To update to Firmware Version 1.1 on the X10 :
1. Download Updater V4.3 from http://xtremepowersystems.net/xdp.php
2. Put the X10 in Programming mode (hold the button and connect to the Serial Link)
3. Run the Updater V4.3. It will change the Firmware Version to 1.1
4. When complete, disconnect, and then again put the X10 into programming mode, and access the functionality via the XDP software
Description:
mikestark is offline Find More Posts by mikestark
Old Jan 04, 2014, 08:11 AM
Joined Jan 2012
Very easy thank you.
Sold USB ASP programming cable $10 shipped Johnnymeg Aircraft - Electric - Multirotor (FS/W) 0 Dec 29, 2013 11:18 PM
For Sale Hawk 10 amp ESC with programming instruction sheet $9 shipped. CONUS paypal john-doe Aircraft - Electric - Power Systems (FS/W) 0 Dec 29, 2013 04:40 AM
Sold yep program card w/cable $10.00 woodyflight Aircraft - Electric - Power Systems (FS/W) 1 Dec 13, 2013 05:45 PM
Discussion Jr 10-x programming tej1usa Electric Plane Talk 1 May 26, 2013 09:43 PM
Help! JR 10 X programming alex louw Scale Sailplanes 4 Oct 01, 2008 09:30 PM
