Old Sep 15, 2013, 06:36 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
Build Log
Brodak Shoestring build
I thought i'd post a few pics of my Brodak Shoestring build as i go. Any and all comments welcome! This is my first C/L build in allmost 40 years, been building R/C models since then.....Gene
gene6029 is offline Find More Posts by gene6029
Old Sep 15, 2013, 06:39 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
First thing i did was to make a tool to enlarge the holes in the wing ribs to fit the steel rods that i have, (5/16") .
Old Sep 15, 2013, 06:44 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
After all the holes were enlarged I slid them over the steel rods and supported them with angle iron on both ends and in the center. I made a piece of wood with drilled and taped 1/4-20 bolts on each end to keep the spaceing the same and prevent movement during the construction of the wing. A simple C clamp prevented any further movement. Crude, but it worked and i didnt have to buy anything to get started!...Gene
Old Sep 15, 2013, 06:48 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
I used a piece of lite ply to act as a rib spacer, and assisted in keeping the ribs 90 degrees to the plan.....Gene
Old Sep 15, 2013, 06:56 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
The glueing has begun, here i have tacked the ribs in place to the leading and trailing edges, and added the main spar.....Gene
Old Sep 15, 2013, 06:58 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
Next was the leading edge sheeting, and installation of the bell crank.
Old Sep 15, 2013, 07:06 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
I sheeted the center section, then flipped the jig over and repeated the same on the bottom of the wing. My method doesnt allow for the addition of the wing tips, so once the wing was sheeted top & bottom , i removed it from the jig to add the wingtips, and the tip weight box.....Gene
Old Sep 15, 2013, 07:11 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
Next up was the fuse, First off i had to widen the engine blocks, to allow the Mcoy .35 to fit up there. Here i attached the canopy to the fuse.....Gene
Old Sep 15, 2013, 07:14 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
I trimmed off the underside of the fuse to be able to finish it off better, then i'll re-attach it later.Here i added the plywood fuse re-inforcements to both sides.....Gene
Old Sep 15, 2013, 07:19 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
I glued together the pieces of wood to form the cheek cowl and test fit it with the wing slid into place. Not sure if i'm happy with the cowl nose shape!
Old Sep 15, 2013, 07:22 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
In addition to widening the engine blocks , i had to make them deeper to fit the Mcoy in there, so i added hardwood blocks with 1 degree of offset built in....Gene
Old Sep 15, 2013, 07:26 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
After looking at full scale pics of the Shoestring cowl, i cut my cowl nose off and re made a new one closer to scale. As you can see i added the rudder and stab assembly.......Gene
Old Sep 15, 2013, 07:36 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
I worked on makeing & carveing the wheelpants today. Like a kid, i had to assemble everything & stare at it. , I also started filling in all my dents and imperfections with vinyl spackel. Next up will be laying down several coats of clear dope before covering with silkspan. So far i have two weekends into my build. I only get to work on the weekends....Gene
Old Sep 15, 2013, 08:09 AM
pd1
United States, MA, Haverhill
Joined Jun 2006
Nice job, and the new cheek cowl looks great.
pd1 is offline Find More Posts by pd1
Old Sep 15, 2013, 08:43 AM
NOT SCREWED UP
alf.g's Avatar
Australia, VIC, Melbourne
Joined Jun 2011
Great job Jene. Looking real smart. Keep us posted as I'm keen to see the end result
alf.g is offline Find More Posts by alf.g
Build Log Li'l Jumpin' Bean build - Brodak/Goldberg RknRusty 1/2A Planes 105 Nov 09, 2013 08:28 AM
Help! *Pics Added* 2 NIB Super Clown ARFs by Brodak..1 Blue & 1 Red..$68.92/ARF SHIPPED2U! bighank13 Control Line 12 Jan 03, 2013 11:44 PM
Build Log Build off: Shoestring pd1 Scale Kit/Scratch Built 174 May 10, 2007 09:20 AM
Gallery Building Brodak Mustang Bartosaurio The Builders Workshop 0 Feb 23, 2007 04:10 PM
Slope Nut's Shoestring Build Slope Nut Sport Planes 25 Nov 11, 2004 04:57 PM
