Old Jun 18, 2013, 12:30 AM
Chile, Santiago Metropolitan Region, Stgo
Joined Dec 2012
Build Log
Ypsi notos build log - (in progress...)
This is my first DLG build, so deal with me.
I started of with some transparencies to get the position of the carbon fiber reinforced part of the wing
Calculating the spot to cut
Cutting the fiber glass and removing the foam to get to the carbon fiber..
With a circular file I cut a channel all the way to the the position of the servo to pass the cables through
Making some small holes with a pin to get epoxy more impregnated in the wing
Sticking with 6min epoxy. Probably should have used a 10min to get a better stick.
15cm dihedral.
sandpapering the wing to get better adherence.
I used two cellophane pieces of paper to get the whole fiber impregnated with the least amount possible, I removed the extra with a credit card.
I cut diagonally the 6cm wide carbon fiber strip to get 2 strips of 4cm on one side and 2cm on the other side.
Covering my face and eyes to cut the carbon fiber with a rotary tool.
Cutting the control horns, the dremel cuts it like butter.
I used plastic wrapper to get a shiny finish, and pressed it for 24hrs.
I measured from the leading edge of the wing to the beggining of the rear stabilizer is 68cm, So I cut off like 10cm, leaving enough that overlaps the rudder.
I marked where the the channel in the boom should end so that I wouldn't go passed it.
I used the dremel to trim of from the boom, the cut ended up very clean.
Cutting the position where the control horns will go.
I used a 0,8mm wire as the swivel for the rudder and elevator.
Here you can see the swivel installed in the rudder.
And the elevators swivel.
Installed control horns in the rudder and elevator.
Leveling the stabilizer.
I used 30 min epoxy this time to get everything in place, I messed up the rudder and it seems to be in a angle.
Heres the channel that will be used for the link of the "top drive" servo installation.
I used a circular file to do the aileron link channel.
Here I had to cut a bit of the aileron tape to get the wire through
Cutting the ailerons for the control horn installation
Aileron with the control horns installed.
Well that's my progress untill now, it's my first DLG and the manual sucked so I thought this might help someone.
barrosinc is offline Find More Posts by barrosinc
Old Jun 18, 2013, 12:33 AM
barrosync:
Looks good so far. Keep up the good work.
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Jun 18, 2013, 04:36 AM
my building log at picasa:
https://picasaweb.google.com/1111033...eat=directlink
regards
thomas
bardioc is offline Find More Posts by bardioc
Old Jun 18, 2013, 10:09 AM
Joined Dec 2012
Thanks Thomas, that will help me a lot!!
Old Jun 19, 2013, 03:50 PM
cirrus_uk's Avatar
United Kingdom, London
Joined Mar 2012
awesome guys - hope to start my build soon. This will help a ton.
subscribed.
cirrus_uk is offline Find More Posts by cirrus_uk
Old Jun 27, 2013, 02:16 PM
Joined Dec 2012
I still have some work to do... But I am progressing steadily but slowly.
I made a really small whole that just fits the link trying every couple of goes to get a perfect fit. Top drive ailerons don't allow any movement.
Here you can see the perfect fit, I tried this before sticking the to the ailerons because it is a lot easier to work with.
I made a tiny hole with the drill to get the pull string through the boom.
I used a small push rod tube to get the braided kevlar pull rope through the boom to avoid abrasion.
I made a small pieco of wood for the D47 servos.
There is a bunch of space leftover so that the servos will sit firmly
I wrapped the servos in masking tape just in case I brake one and need to replace it.
Here is the knot I used for the rudder and elevator..
They look really tight! I might use a drop of CA to keep it there.
Here you can see the aileron servo links perfectly measured.
Old Jun 27, 2013, 07:34 PM
elkski's Avatar
United States, UT, Sandy
Joined May 2013
nice....
elkski is online now Find More Posts by elkski
Old Jul 03, 2013, 12:46 AM
Joined Dec 2012
Soldering the servos to the extenders, I tried going on without this step and got a disconnected cable while trying it out... Soldering is a must!!
Here I had a hard time screwing the screw back in because the link was very tough and there is basically no space to work with.
I used 6 min epoxy to stick the servo to the wing.
Here you can see the amount of movement the ailerons have upwards.
...and downwards.
Old Jul 03, 2013, 07:25 AM
zero2nine's Avatar
Deutschland, NDS, Hannover
Joined Aug 2007
Subscribed!
Very nice pictures, thank you very much!
Did you insert small pieces of a pushrod into the rudder and elevator where you stick the wire in? I think otherwise the wire will work through the foam and the glass one day. Especially because you use 0.8mm wire which is pretty strong IMHO (I use 0.5mm).
Christian
zero2nine is offline Find More Posts by zero2nine
Old Jul 04, 2013, 10:42 AM
Maki's Avatar
Joined Aug 2007
Very good work Max, keep posting, and don't forget to record first flight...
Mario
Maki is offline Find More Posts by Maki
Old Jul 04, 2013, 05:45 PM
United Kingdom, England, Wiltshire
Joined Apr 2011
Very far off topic here, but your build photos are superb. The depth of field seems perfectly calculate to show off your work to best advantage. It really draws the eye to the piece of interest. Either you have stumbled upon a good camera setting or you know a thing or two about photography and you're applying it here. I'm going with the latter.
I'm enjoying reading about your build and the pictures are excellent.
ThermalSniffer is offline Find More Posts by ThermalSniffer
Old Jul 04, 2013, 05:50 PM
Joined Dec 2012
Thermalsniffer... guilty as charged...
www.barrosinc.com is my wedding photography page down here in Chile
Old Jul 08, 2013, 12:28 AM
Joined Dec 2012
Pushing AWG 32 servo extenders through the wing
Soldering the servos to the extenders.
Heres the servo installed with the cables soldered.
I used an MPX connector so that I don't have to fiddle with the receiver every time.
The MPX connector on the pod side, connected directly to the receiver.
Calculated 3,5cm from the border of the wing to the place where the metal insert is stuck inside the pod. I used a 2mm drill so that later I can make the 3mm thread with the tool that has 3mm thread on it.
I used the threading tool to mark the spot on the pod.
Heres the 2mm drill making the hole on the pod on the mark made on the previous step.
The threading tool must be used pushing hard enough for it to go in but not too hard to pull the insert out.
I used a sandpaper to scratch the surfaces on the outside of the pod and the inside of the boom to get better adherence.
Now I ensamble the whole plane, remember I still only have just one screw holding the wing. I do this because now I can measure everything and place the wing in the exact position it must be in, now I stick the boom with 30 min epoxy to get a lot of time to move stuff around and leave it overnight.
My initial estimation of the CG is 98mm... 18mm farther back than the recommended 80mm... It is going to need some weight.
Old Aug 01, 2013, 01:36 AM
Joined Dec 2012
Mounting D47 in the pod for rudder, I used the most outer hole of the small servo horn
I had to use a larger servo horn to get the movement I wanted
I made a wing of paper with the shape of the notos
I found the place I wanted to put the peg
Heres the peg in place, I used the hobbyking files to make the hole for the peg, and stuck with 6min epoxy, I used the hair dryer to get the epoxy all the way in.
I needed 11 grams of weight to get the CG to 80mm
Final weight 287gr
Old Dec 24, 2013, 05:53 AM
GO!!!
Garvey's Avatar
Eastern edge of the pond
Joined Mar 2003
Nice work barrosinc. Can you say how the model flies now and do you know which airfoil section it uses?
Garvey is offline Find More Posts by Garvey
Link RC kite build logs.. show your kite and link it to your build log davereap RC Kites 15 Feb 10, 2015 10:29 PM
Discussion Winter scratch build in progress moes Thermal 8 Mar 31, 2014 10:40 PM
Log in, log out?!?! log in head! Looooeeee! Life, The Universe, and Politics 4 Oct 01, 2001 10:34 AM
