This thread is privately moderated by The Don, who may elect to delete unwanted replies.
Old Feb 10, 2015, 06:34 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
What kind of setup are you looking for? 3S is limited in choices as amps get high if you want any real power.
The Don is online now Find More Posts by The Don
Old Feb 10, 2015, 07:04 PM
Joined Sep 2003
would like 3s as it is for a friend and he has 3s 2200
SpadHawk is offline Find More Posts by SpadHawk
Old Feb 10, 2015, 07:14 PM
Joined Sep 2003
dont need speed demons. just like stock or a bit better is fine, a bunch of us are going to fly together and want similar performance.
Old Feb 10, 2015, 07:58 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Sounds like Setup A is exactly what you want.
Old Feb 10, 2015, 08:09 PM
Joined Sep 2003
but your out of stock on the fans
Old Feb 10, 2015, 08:20 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The type II was discontinued follow the link on that page to the type 1 fan.
It will take you to this fan the type 1:
http://www.donsrc.com/cart/index.php...&product_id=74
Old Feb 10, 2015, 08:25 PM
Joined Sep 2003
excellent....placing my order now
thanks
Old Feb 10, 2015, 11:32 PM
The ground is my Enemy!!!
Jose5x5's Avatar
United States, CA, Crestline
Joined Aug 2008
Don,
I am currently running the wicked plus 4000 with the edo type 1 fan. I have been running this combo for over 2 years now. Would upgrading to the Het 6404 fan be worth it and give me more speed. If so what would I need to swap out the fans?
Jose5x5 is online now Find More Posts by Jose5x5
Old Feb 10, 2015, 11:40 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The HET 6404 will give more speed , watts will go up to 800 watts you will need a 60 amp ESC. You will have to remove the rotor plug of your motor. You will also need to have the HET with 3mm adapter ( I have those). You also have to drill some new mounting holes in the fan. Best thing may be to just send the motor back to me then buy the HET fan and for $10 I can do the mount and balance with the new fan. Just make sure it is the Wicked Plus (blue motor bell) and not the regular Wicked 4000 (red bell) as it will not survive.
Old Feb 11, 2015, 12:38 AM
Jose5x5's Avatar
Joined Aug 2008
Ok Don, I am already running the 60a hobbywing. I will double check on the motor. This is currently in phase 3 f16. I also saw on your website the the changesun 2800 was around 800 watts. Which way would you go?
Old Feb 11, 2015, 05:32 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The chagesun is a different animal, needs a large outlet and is more a sound fan. There are a few guys running that changesun with the larger outlet around 61mm and are around 120 mph on the videos I saw which is really good, usually that fan is slower for the same watts but seems to work OK in the EF-16 with correct outlet size. I have not done a EF-16 with CS fan yet. My plan is to have one for this flying season but thatis a 2-3 months away here in Ohio. The HET setup I know will do 120 with the same thrust tube for the EDO 64mm fan.
Sold Dons Wicked EDF 4800KV brushless and 55mm EDF UNIT hi2nr Aircraft - Electric - Jets (FS/W) 4 Mar 01, 2012 07:51 PM
Sold Dons Wicked EDF 4800KV 55mm EDF unit hi2nr Aircraft - Electric - Power Systems (FS/W) 0 Mar 01, 2012 07:28 PM
Mini-HowTo Mounting the Wicked EDF motor into the HET 6404 64mm EDF Fan unit The Don Don's RC 0 Jan 28, 2012 12:20 PM
Discussion dons wicked edf plus 4400 60mm edf applications tommythecat Don's RC 6 Nov 20, 2011 02:13 PM
Question Hobbykings edf 35mm Mig-15 *Wicked Setup* deuce66 Don's RC 4 Oct 27, 2011 08:56 AM
