Old Mar 09, 2014, 01:22 AM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
Not to drag it out. Buut.
My initial reaction to the OPs post was why not. Everyone says you need lasers or barometers, which doesn't make much sense to me.
OP was talking about say flying nose first into gusty rotor winds that would bob helis up/down unpredictably.
Why couldn't a gyro with pitch accelerometer apply collective to correct instantaneous acceleration that was not commanded from the user? I realize there is further engineering than that of course, but why dismiss the concept?
eagle777 is offline Find More Posts by eagle777
Old Mar 09, 2014, 03:07 AM
Green Darner is offline
Find More Posts by Green Darner
postcounts are meaningless
Green Darner's Avatar
Joined Feb 2014
My gut reaction is it would work kinda like a rate mode tail gyro. It wouldn't be able to maintain a constant altitude at all. It would try to stop unwanted movement in the vertical plane, but I think the end result would be more just slowing it down?
Green Darner is offline Find More Posts by Green Darner
Old Mar 09, 2014, 03:16 AM
eagle777 is offline
Closed Account
Joined Aug 2007
Yeah, hence my 'just engineering' copout. I realize it could be in a given orientation, and you'd have to at least use trig for all 4 sensors to not make it bobble. It's probably doable with code I guess. No idea. But you do see my and OPs original question now.
Old Mar 09, 2014, 03:43 AM
eagle777 is offline
Closed Account
Joined Aug 2007
If you think about it, that would be an incremental improvement in computer controlled flight. I don't know if there is something like this out there, but it isn't in the $100 or $200 range yet.
Old Mar 09, 2014, 04:55 AM
eagle777 is offline
Closed Account
Joined Aug 2007
He was not talking about holding an absolute altitude, just lessening the spikes (see earlier posts) I assume he is flying 10-30' and doesn't want to bobble up and down. I am not sure why you all are so obtuse.
Old Mar 09, 2014, 07:00 AM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Cyclic gyro's alone do a fairly good job of fighting bouncing around from the wind.
I figure that if its hard enough, someone will try even when an easier known solution exists.
Roto Rob is online now Find More Posts by Roto Rob
Old Mar 09, 2014, 12:18 PM
Balr14 is online now
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
GPS doesn't give accurate altitude readings. That's what the barometer is for. The one on my Phantom is accurate to less than 2 feet. The original request can be satisfied with a decent multiwii board, which has everything but GPS for $40 - $50. All you really need is accelerometers, but since they come with the other stuff, you might as well use it.
What has been overlooked in this discussion is determining when pitch, roll, or yaw is caused by wind or is intentional. You can't determine that without some way of measuring input to those values and having some way to make decisions based on that data. None of these half-baked Ideas can do that. Naza H and APM 2.6 can do that. A multiwii board could do that with a fair amount of programming. Otherwise, you either have to activate auto-level with a switch, or turn it on all the time with very low settings. I had a rather interesting experiment with auto-level on a quad, with an MWC board. If you have a DX6i, you have to screw around with available switch setting combinations, because a DX6i has no 3 position switches and not enough two position switches for all board functions. My switch settings accidentally tied the barometer and accelerometers together, with no way to shut them off. I got the damned quad 15 feet in the air, turned on the switch and it that was it! I couldn't get it to budge until the battery ran down.
I have experimented with the MWC multiwii board on a heli and found a BeastX does a very effective job of countering wind, without needing additional help.
Balr14 is online now Find More Posts by Balr14
Sold (2) MINI MWC Flight Control Board and DSM2 Receiver ACC/GYRO/BARO/MAG + GPS, OLED LCD crd Aircraft - Electric - Multirotor (FS/W) 10 Apr 06, 2014 09:30 AM
Sold Blade BLH7601 4-in-1 Control Unit, Rx/ESCs/Mixer/Gyros: Nano QX BLH7601 Used sst2000 Aircraft - Electric - Multirotor (FS/W) 0 Oct 28, 2013 02:02 AM
Sold CNC 4axis hotwire package browncbr1 Aircraft - Sailplanes (FS/W) 3 Jun 01, 2012 03:48 PM
Discussion HobbyCNC PRO Chopper Driver Board Kit 4axis Kevin Matney DIY Electronics 1 Jan 10, 2012 12:17 PM
Discussion getting gcode on both turrets 4axis wire cutter Blackrat CAD/CAM 2 Oct 14, 2011 12:41 PM
