Old Jan 19, 2014, 07:12 PM
sleepwalker is offline
Find More Posts by sleepwalker
sleepwalker's Avatar
United States, PA, Clearfield
Joined Jan 2007
Question
Sealed Lead Acid Batteries
Would these be good to use in a scale boat such as a 36"to 48" tug with two motors ? Motors would probably be Pittman 9000 series or Johnson 970's.These are in the sale isle at Walmart for $18,but might get them to go lower on the price.
http://www.amazon.com/Wildgame-Innov.../dp/B0031AUPOC
sleepwalker is offline Find More Posts by sleepwalker
Old Jan 19, 2014, 07:45 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
These SLA batteries are pretty much a commodity, generic... I'm sure your private branded example is as good as any other. No clue if that specific size is what you want or need in whatever model you have...
patmat2350 is offline Find More Posts by patmat2350
Old Jan 20, 2014, 02:43 AM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
As one of our "master" model tug builders from Canada says, "the ONLY good lead in a model boat, is wrapped in acid (a battery)! Yes, SLA's or Gel Cell batteries, work great in a tug. Here is my 25'' pushboat.
CaptCB is offline Find More Posts by CaptCB
Old Jan 20, 2014, 03:12 AM
Rustbucket is offline
Find More Posts by Rustbucket
Portland Oregon
Joined Aug 2006
HECK Ya I use them all of the time . WITH MY 6 foot DDG and carrier you cant beat them as far as I am concern and I use a pair of standara 12 volt motors with mind never had a problem . FOR that pirce for that battery I feel it is good price. Just keep it charge and check on it when your not useing it . Just be sure to keep at least a full 12 volt in it all of the time . During the winter I charge mind up and usely once a month I will check mind and it the are a low 12 volt I will put a charge in them . One thing nice about thoes Jell cells you can put them in any way you want. I eather will lay them down or keep them up right.
. But that is my opinion only. HERE IN portland at the shop I deal with Battery exchange I cant touch for less then 20 any more I had to pick up one about 2 years ago . I dont have a clue on what they are going for now. I did know wall mart handled those something I will have to check into..thanks for the tip. DON the Rustbucket in Portland Oregon
Rustbucket is offline Find More Posts by Rustbucket
Old Jan 20, 2014, 08:39 AM
Joined Jan 2007
The Walmart in my area has an isle for things that are reduced for quick sale.Maybe each Walmart has a cheapie isle. These were originally in the sporting goods/hunting dept and were used for automatic game feeders,lights and electronic predator calls.If I get one or two,I'll have to see if they have any of the chargers for them.
Old Jan 20, 2014, 08:53 AM
jeno is online now
Find More Posts by jeno
United States, ME, Bar Harbor
Joined Sep 2005
Let me join all the previous posts by saying that SLA's are the way to go. One more thing to note: SLA's generally are rated at 24 hour discharge rate( some may be @12hr rate) That said, a 7.2 amp SLA is not going to give you 7.2 amps/hr. Not without cooking the battery. Match your motors and your batteries so your current draw remains within the comfortable limits of the battery.
jeno is online now Find More Posts by jeno
Old Jan 20, 2014, 11:01 PM
Greg Hiltz is offline
Find More Posts by Greg Hiltz
Saint John, NB(East Coast) Canada
Joined Apr 2006
Perfect Batteries
Yes Sleepwalker, those Gel Cells are the perfect batteries for any larger model boat, can be laid flat, sideways, or vertical. Buy and install as many as you need to get the proper trim in the finished boat. Much better to add storage voltage for weight rather than dead lead weight.
Simply wire up + to + to + and - to - to - , this will keep the same voltage but really add up your amp capacity, which is same as your fuel tanks.
Greg Hiltz is offline Find More Posts by Greg Hiltz
Old Jan 21, 2014, 06:50 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
Not a good idea to parallel Lead acid batteries, or series them for that matter. Uneven discharge leads to strange fault symptoms. Load them into the available space, but it doesn't take long to change over two leads?
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Jan 21, 2014, 07:11 AM
HeavyCruser9 is offline
Find More Posts by HeavyCruser9
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
Never had a problem running SLA's in parallel.....cheap ones are good for about 18 months to 2 years of hard use if you are pulling lot of amps out of em'
I now run more expensive deep cycle 12v 10ah SLA's (twice as expensive and a kg heavier!) I have had these ones since Nov 2011 still going strong
Cheers Bruce
PS any decent electronics parts store should have a 12v SLA charger of some type.
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old Jan 21, 2014, 09:19 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
Provided that all the batteries concerned are measured at the same voltage prior to connection, and kept like that, there is no problem. Lead acid cells can supply enormous currents, but not for long before they damage themselves, and that is why some caution should be used. The circulation currents involved while they settle themselves out can be very large.
Using batteries in series, again, they should be in a similar state of charge, because if one is not as charged as its friends, it will not only run down faster, but possibly try to reverse charge. This manifests itself as a very sudden drop in performance, and likely difficult recharging. Of course, while a 6 volt battery is 3 cells in series inside one box, a 12 volt battery is 6 cells in one box. 2 of 6 volt batteries in series (provided they are both the same AH rating) just makes a 12 volt battery. You might want that to make siting them in the hull more convenient.
mfr02 is offline Find More Posts by mfr02
Help! Charging my lead acid batteries Liam.great98 Batteries and Chargers 8 Oct 07, 2013 04:09 PM
Question How many charges from a 4AH sealed lead-acid battery ? borgs Batteries and Chargers 18 Feb 25, 2003 05:55 AM
Power Supply or Sealed Lead-Acid Battery? konaboy Batteries and Chargers 6 Nov 18, 2002 07:51 PM
Charging sealed lead acid batteries.. simingx Batteries and Chargers 0 Oct 07, 2002 11:50 AM
Charging sealed lead acid batteries Jim McPherson Power Systems 10 May 04, 2001 03:51 PM
