Old Jun 05, 2013, 10:17 PM
RR750 is offline
Find More Posts by RR750
Joined Jun 2013
Help Needed MultiWii Pro Sketch Removal
This is a dumb question for which I apologize. I am trying to set up a Hexacopter that uses an Atmega 2560 control board. Using MultiWii Pro 2.0 (Arduino 1.0.2) I loaded firmware with the incorrect configuration. After doing this, I opened the board with MultiWii GUI in real-time and saw the incorrect configuration, but noted that the gyros all seemed to work when the board was moved around. I then went back to the sketch, and changed the configuration to the proper HEX6X. I then loaded this revised firmware on top of the incorrect version. Now the GUI display still shows the incorrect configuration and all the gyros don't show motion. Throughout all this the yellow and blue leds on the board are solid and the green and red lights are alternately blinking (I think this means the throttle is locked). Also when I use the Verify/Complie command in Arduino, I get an "Error Compiling" message.
Can someone tell me how to remove the incorrect sketch from the control board, or otherwise reset it so I can load the correct version of the sketch?
Thank you
RR750
RR750 is offline Find More Posts by RR750
Discussion Need help on MultiWii Pro with GPS tnt2k03 Multirotor Electronics 9 Jun 14, 2013 12:01 AM
Discussion multiwii pro with gps - help loading a sketch dubzn1 Multirotor Talk 13 Jun 08, 2013 08:45 AM
Discussion Need help with multiwii pro 3dx450 Multirotor Electronics 2 Apr 10, 2013 11:09 PM
Discussion need help with multiwii pro 3dx450 Multirotor Electronics 4 Apr 05, 2013 06:14 PM
Help! cant upload sketch to crius multiwii se v0.2 ash123 Multirotor Electronics 2 Jan 16, 2013 09:25 PM
