Old Mar 13, 2015, 11:06 AM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Hello Michael! If you do the adjustments on the HALF formers it should be ok and both the endpoints should stay on the Cplane/ Mirror axis. Before mirroing you can us the 2..3 controlpoints at the ends to establish tangential integrity and to get "round" transitions ... always mirror after all adjustments are done as Splines work a little bit like a bow under tension: two unified halves with similar look but different control point locations end up in asymetry of the spline after unification....
Harpye is offline Find More Posts by Harpye
Old Yesterday, 03:30 PM
Gary27 is offline
Find More Posts by Gary27
The Netherlands, NH, Amsterdam
Joined Jun 2008
How do you know when the surface youve created is correct?
How do you know its when good enough for modeling purposes?
Gary27 is offline Find More Posts by Gary27
Old Yesterday, 03:40 PM
Harpye is offline
Harpye's Avatar
Germany
Quality of the transition in between the seams
Quality of the bow and the curvature and ( Rhino has the Zebra room )
If you have 2 surfaces and the curvature , the bow and the seam in between both match most work is done ....
A nice reflection pattern on the surfaces wich would discover all warps and problems you could include during the setup!
Old Yesterday, 03:45 PM
Gary27 is offline
Joined Jun 2008
Oke thanks, but can you explain what I have to do exactly and what to look for? Or is there a tutorial on this subject somewhere?
Old Yesterday, 08:40 PM
Kevin Matney is offline
Find More Posts by Kevin Matney
Kevin Matney's Avatar
United States, MI, Erie
Joined Mar 2000
This thread will take me some time to read it all but I think it will help me out alot.
Thanks keep it coming
Kevin Matney is offline Find More Posts by Kevin Matney
Mini-HowTo Rhino ... some basics Harpye CAD/CAM 574 Yesterday 08:40 PM
Wanted Looking for some 4S and 5S zippy/Turnigy/Rhino Lipos Aga1978 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 30, 2009 08:09 AM
Help! Probably basics for some markles123 Sailplane Talk 6 Oct 07, 2009 01:46 AM
Discussion Some basics of FPV for a beginner?! GOK FPV Talk 10 Feb 15, 2007 08:04 PM
In need of some basics Doug Sipprell Batteries and Chargers 5 May 26, 2004 10:21 PM
