Old Jul 23, 2012, 09:41 AM
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
I got rid of the stock radio as fast as I could!
I think I stell have a copy I well look it up when I get home tonight
Black_heart is offline Find More Posts by Black_heart
Old Jul 23, 2012, 10:47 AM
Joined Jul 2007
Thanks BH- I actually have a Turnigy 9x that should be here by the end of the week so Im not too concerned about it. I just have to put everything on hold becuase my settings arent right and the stock Tx wont take programing...which I think is in the software at this point.
speedster00 is offline Find More Posts by speedster00
Old Jul 24, 2012, 12:27 AM
michaeldepeza's Avatar
Trinidad & Tobago, St Andrew, Valencia
Joined Jan 2012
ok guys has anyone had this problem with heli,as soon as i throttle enough to get heli light on skids it starts spinning uncontrollably...i changed three tail servos and ensured when the servo was centered that the tail blades did not have too much pitch ensuring the the mechanism was centered along tail slider....i use the stock ZD720 gyro.......
the ct6b program doesn't offer much in terms of how to adjust gyro and i'm tired of researching online yet not any clearer as to what should be done(reversing gyro setting didn't work)
is there a setting on Digital radio prog that cansolve gyro problem short of buying a new gyro....by the way i ordered this one incase
http://www.ebay.com/itm/120831830098...84.m1439.l2649
michaeldepeza is offline Find More Posts by michaeldepeza
Old Jul 24, 2012, 11:46 AM
Joined Jul 2007
I had that same problem. My issue was that rate mode was very sensative. As soon as the light goes out on the servo, stop turning the nob. Just barely out of HH mode. DONT take off if the heli is spinning. Reset the tail servo position until you can lift the heli in rate mode with out rudder compensation. It took me 3 battery packs to figure this out. Once you make minor servo position adjustments and it lifts with out input, then reset HH mode by turning the nob 3 times with in one second and the gyro will flash when it resets.
Also, from the factory, my Gyro settings were backwards. I thought I had mine set up in rate mode, and HH mode just sent the heli into a crazy spin. turns out the gyro direction in the Tx and on the Gyro itself were both backwards so in HH mode, the gyro was compensating the wrong way making the heli unflyable.
Old Jul 24, 2012, 08:45 PM
CERMARK
Steven Chao's Avatar
Joined Apr 2004
Originally Posted by mdugas View Post
hi,wonder if setting gyro to anolog for zd9257digital tail servo would make it last longer,
supposed to work on some tail servos
Absolutely NOT. It will shorten the life of your tail servo and your gyro. If you have a digital servo, then you will need to set the output from the gyro to digital, and vice versa.
Peace,
Steven Chao,
CERMARK
Steven Chao is offline Find More Posts by Steven Chao
Old Jul 25, 2012, 09:54 AM
Joined Aug 2003
Peace,
Steven Chao,
CERMARK
hi,thats interesting .have replaced servo whith a different 9257 clone already,
using the copterx cx3-1000 set for digital tail servo ,seem to be a good setup
thanks
mdugas is offline Find More Posts by mdugas
Old Jul 25, 2012, 10:00 AM
Farmer
United States, CA, San Mateo
Joined Oct 2011
We have recently noticed that we did not include the instructions + cd with many of the kits. We are very sorry. Please let us know so that we can send it to you. Our telephone (562) 906-0808.
Here are a few items that you can download immediately;
1. Parts list version 2
2. Quick Start version 2
3. Transmitter programming instruction version 2
4. Manual version 1 (small - lower resolution)
Peace,
Steven Chao,
CERMARK
Does This Heli Come With Medical And Liabilty insurance?
Also An On Board First Aid Kit Would Be A Nice Touch?
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Jul 26, 2012, 01:29 PM
CERMARK
Joined Apr 2004
We will look into the first aid kit possiblity. Any suggestion what should be included? :-)
Peace,
Steven Chao,
CERMARK
Old Aug 04, 2012, 02:55 PM
United States, TX, Pflugerville
Joined Jul 2012
Hi all! I'm waiting for my Hausler 450 V2 to arrive later next week. Can I set this heli up with my Spektrum DX7 and AR7000 receiver? I'm guessing I can, but want to make sure before it gets here.
Jestered is offline Find More Posts by Jestered
Old Aug 05, 2012, 07:36 PM
Fixed and rotary wing flyer
United States, CA, Newark
Joined Sep 2011
I'm trying to help a bud verify that his ESC is set to soft start. Through some searches, I found this link that suggests its the manual for the NAO-40A ESC
However, when he goes into the programming and gets to "startup mode", he only hears 1 beep or 2 - not 3 as he's supposed to. So is this the right manual?
What's the proper programming instructions throught the TX for super-soft start?
Thanks!
fabric8 is offline Find More Posts by fabric8
Old Aug 06, 2012, 01:53 PM
wasilla,alaska
Joined Nov 2005
is this the same model that you are talking about in this thread ?
http://www.ebay.com/itm/3D-6CH-remot...ht_6484wt_1198
jasonak is offline Find More Posts by jasonak
Old Aug 07, 2012, 09:26 AM
Joined Aug 2003
hi that is one . $110 for new v2rtf free shipping thats a pretty good deal
Old Aug 08, 2012, 07:35 PM
Texas NewB
Joined Dec 2011
Yes that is a Hausler v2
Old Aug 11, 2012, 10:05 AM
Joined May 2012
A couple of questions if anyone can help...new at 6 channels but learning a lot on this forum. I have a Hausler I bought from Leaders Hobby. Same as discribed here. First, has anyone had luck with programming the ESC? I can enter the programming mode, but after the beep sequence indicating function, moving the throttle lever down to adjust has no effect. The ESC just continues to repeat the beep sequence for each function. Normal for these? Seems impossible to program. My other problem is understanding the throttle hold switch and start up. Turn transmitter on in normal mode w/ throttle swtich towards me. After beep sequence, I then click the switch away from me. This initiates spool up. Is this correct? The rotors then start spinning immediately. Seems to me I should have no rotor movement until I move the throttle stick up from the fully down position. Any help here is appreciated. Sorry, a complete newbie at these 6 channels. Pretty good at coaxials (lol) and 4 channel fp. Thanks in advance!
FrankPalmer is offline Find More Posts by FrankPalmer
Old Aug 11, 2012, 08:22 PM
Joined May 2012
Nevermind.
Figured it out....
Mini-Review Cermark Hausler 450 SE V2 koppterX 3D Electric Heli Flying 387 Apr 20, 2013 04:21 PM
Sold hausler 450 rtf heli new in box dennishobbies Aircraft - Electric - Helis (FS/W) 22 Jun 02, 2012 03:12 PM
New Product hausler 450 rtf heli dennishobbies Hot Online Deals 8 Jan 30, 2011 07:48 PM
Sold FS: RTF Align Trex 450 V2, DX7 OCFly Aircraft - Electric - Helis (FS/W) 2 Jan 10, 2011 11:24 AM
Off Site Align T-Rex 450 SE V2 Complete RTF RC Helicopter Tom Z Aircraft - Electric - Helis (FS/W) 1 Sep 25, 2010 08:07 PM
