Old Jan 11, 2015, 06:52 AM
Joined Aug 2013
Hi guys,
I had always the setup: Jeti DS16 -> rSat2 -> TX700
This worked fine, because I programmed the rSat to give out 12ch PPM.
Now the new Jeti Software supports also 16ch PPM direct out, but I can just choose between 8 vor 16ch, 12 is not possible.
In 16ch mode I cannot bind, in 8ch it works without any Problem.
Is this a Jeti Problem, or does my TX/RX700 have a prob with this?
Help! I dont like to use the Repeater Setup with the rSat anymore!
WDZaphod is offline Find More Posts by WDZaphod
Old Jan 11, 2015, 11:42 AM
Germany
Joined May 2010
Does anybody know the pin out of the Tx700 lite input? And is there a new manual on itīs way?
Here is something out of the description I like to know how it works:
"It has also sequential fail safe, that lets you store a fail-safe pattern of 3 interactions when it hits fail safe"
Cularis is offline Find More Posts by Cularis
Old Jan 12, 2015, 10:25 AM
France, Bourgogne, Nevers
Joined Feb 2012
NR Rx antenna
In over 900 pages, all things, including this one, have GOT to be old hat----so, sorry, but the limp wire antenna on the NR receiver is underwhelming. I've got pretty good soldering skills, and the board has mounts for a real connector. Anybody have a good idea for a better antenna- nice through -the-wing dipole, maybe- attached to an SMA or an MCX connector on the NR Rx board? I could use some real-world length data, instead of just formula numbers. 155mm good, inside tube? Will it help the range? Seems like it's got to.
wazoo22 is offline Find More Posts by wazoo22
Old Jan 12, 2015, 10:55 AM
Gravity is patient............
Joined Mar 2006
You could just use a standard Scherrer 433mhz dipole that he sells for the LR version. You don't need to add a connector unless you want to. Solder it direct to the board and if you're worried about ruggedness just dump some silicon glue at the joint. (like Goop or similar).
The point of the NR is convenience of a small antenna (and only one) though, and also a smaller footprint. If you need more range of course there is the LR version...
billyd60 is offline Find More Posts by billyd60
Old Jan 12, 2015, 12:25 PM
Joined Feb 2012
Money.
If I didn't have the NR, I'd not do this at all.
That's also why I was asking for some opinions based on experience about adding a more sophisticated antenna on the bird )(in the hand), and do it myself. Also, it's fun.
Old Jan 23, 2015, 12:44 AM
Singapore, Singapore
Joined Apr 2012
Selling a v6 TX with custom made stand over here:
http://www.rcgroups.com/forums/showthread.php?t=2329576
100$ plus shipping.
Dio
Dionysos is offline Find More Posts by Dionysos
Old Jan 23, 2015, 03:13 AM
Professional UAV Services
Redemptioner's Avatar
Australia
Joined Dec 2009
Any1 heard from Thomas?
I have not seen him online in a while, hope everything is ok mate.
Redemptioner is offline Find More Posts by Redemptioner
Old Jan 23, 2015, 10:38 AM
Edmonton, AB, Canada
Joined Oct 2002
I have to admit, this is the quietest UHF LRS thread ever. I guess TSLRS users don't spend much time troubleshooting? Too busy flying?
anixs is online now Find More Posts by anixs
Old Jan 23, 2015, 11:43 AM
Joined Jul 2009
Hi,
Thomas remember me please, where is the RSSI voltage about our old RX 3.30D? And where is the difference about the RSSI out on the new v7 RX!
In my Rx v3.30D voltage is: Max signal 0,8-0,9v lost signal 0,4v is normal?
Neo360 is offline Find More Posts by Neo360
Old Jan 23, 2015, 04:38 PM
Australia, NSW, Ingleburn
Joined Mar 2013
I've been thinking the same. Maybe he is on holidays?
v2rocketeer is online now Find More Posts by v2rocketeer
Old Yesterday, 05:14 PM
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
Don't worry, Thomas is on Geocache hunt
Rastislavko is online now Find More Posts by Rastislavko
Discussion Long range flight using new DMD 868Mhz RC equipment tron FPV Talk 500 Feb 25, 2014 03:22 AM
Idea Long Range RC pmarek UAV - Unmanned Aerial Vehicles 22 Nov 07, 2011 07:17 PM
Long Range RC Link? cloudy Radios 2 Aug 09, 2008 01:11 PM
long range radio system suggestions?? oracle_9 Thermal 15 Aug 09, 2008 11:44 AM
Discussion Long Range 2.4 Ghz Wireless RC Camera edplane Aerial Photography 8 Apr 18, 2008 09:24 PM
