Old Nov 26, 2007, 07:31 PM
Thanks for the Fish!
aerogel's Avatar
Land of cajuns
Joined Dec 2001
Micro threaded rod?
I remember a old post that someone was using the threaded rod out of a linear pot. Anyone have this link or a part number for the pot? need it for a swing wing I’m working on.
aerogel is offline Find More Posts by aerogel
Old Nov 27, 2007, 01:12 AM
Portland, OR USA
Joined Mar 2005
Try Small Parts, Inc. (www.smallpartsl.com)
One possibility is Small Parts, Inc. They have a variety of threaded rods, including very small sizes. For example, in sstainless steel:
http://www.smallparts.com/products/descriptions/trx.cfm
or brass
http://www.smallparts.com/products/d...tions/trbb.cfm
Eric
esweet is offline Find More Posts by esweet
Old Nov 27, 2007, 03:28 AM
Joined Jan 2006
Look for trimpots, some are squarish rotary worm gear based.
The ones to look for are longish and have the long threaded rod.
Digikey, Mouser?
GavinBLDC is offline Find More Posts by GavinBLDC
Old Nov 27, 2007, 10:05 AM
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
The trim pots you would need are multi turn pots, go for the 30 turn. But that said just buy long #0/86 screws or smaller. I think I once saw some #00 threaded rod listed at Small Parts, but I'm not sure.
village_idiot is offline Find More Posts by village_idiot
Old Dec 30, 2008, 06:03 PM
barney 69's Avatar
France neer Paris
Joined May 2007
How many inch is an 1.5mm diameter ???
Hi , please help me to understand how are called the diameters ( I' m French ).
I now that 1 inch is 2.54cm
I search 1.5mm diameter Threaded Rod , i find 0.059 inch is the theorical value for the diameter and I think i will not find this value in practice ....... What is the nearset ( "more near" ) value ???
1/16 of inch dosn' t exist ( 1/16 inch = 1.58 mm )
What means 0 , 00 , 000 , 0000 ?
Thanks in advance , if you help me i will learn you how to make Champagne with Turkish beer , spanish mushrooms ..... and French water melon off course
This is what i find on "small parts shop"
( http://www.smallparts.com/b/16410731...AF&pf_rd_t=201 )
Size
barney 69 is offline Find More Posts by barney 69
Old Dec 30, 2008, 06:21 PM
It's a spiderweb of knit lines
Souderton Pa. USA
Joined Mar 2002
Is this what you need?
http://www.csgnetwork.com/screwinfo.html
mcross is offline Find More Posts by mcross
Old Dec 30, 2008, 09:08 PM
barney 69's Avatar
France neer Paris
Joined May 2007
great , thanks you
..... for your link about :
Decimal and Millimeter Equivalents of Fractional Parts of an Inch
( Equivalence de décimale et de millimètre des fractions de mesures en pouce )
Code:
Size Number: 000 00 0 1
Diameter: .034 .047 .060 .073
I found my 1.5mm screew diameter , it' s ~ "0 size"
And : "1 size" = 1.85mm diameter
00 size = 1.2mm diameter
000 size = 0.86mm diameter
Old Dec 30, 2008, 09:13 PM
Souderton Pa. USA
Joined Mar 2002
"0 size" is not exactly 1.5mm
You will need to use 0-80 nuts to fit it
the "-80" means 80 threads per inch
Old Dec 30, 2008, 09:22 PM
barney 69's Avatar
France neer Paris
Joined May 2007
OK , for my 1st application it will be OK because I will fit the Threaded Rod in a plastic part .
I also search where to buy 1.5mm Threaded Rod for an other application where i must use nuts .
Perhaps i finaly will must buy 0-80 nuts , and become an "Imperial screews user"
Old Jun 18, 2012, 02:28 AM
Joined Jun 2012
preci is offline Find More Posts by preci
Really thin threaded rod Ron Williams Electric Plane Talk 6 Jun 18, 2012 08:02 AM
Using turnbuckles instead of threaded rod? AndrewsJr Electric Heli Talk 5 Sep 24, 2002 04:24 PM
