Old Jan 08, 2013, 07:00 AM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Question
Engine Mounts....
Hey all. I have been looking around for a good mount for this 750, I just don't like the stock one and I can see a small crack in it so there's no way I'm going to trust it. I ordered and received these yesterday http://dreamworksrc.com/catalog/turb...rge-p-291.html Has anyone used these? Any problems? They seem to be a lot nicer mount than the stock one's. Thanks.
av8ersteve is offline Find More Posts by av8ersteve
Old Jan 08, 2013, 07:16 AM
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
Cracked mount?? That's not a normal problem since there isn't any vibration.
Anyway... the one you got from DreamWorks is what I normally see on a RAM. The clamp style is what is mostly used. Just don't over-tighten the clamps. You don't want to crush the engine housing.
What did you decide on for a model? Did you get the Elan?
Dr Honda is offline Find More Posts by Dr Honda
Old Jan 08, 2013, 11:05 AM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Hi Dr. The Elan for sure. Already saved 1/2 the $$$. I have enough now to get the others if I decided to but gona hold off and get what I really want.
Oh, and it's not the mount it's self that's cracked but the little screw tab where it is attached to the strap. It looks like it's been welded back on and there is a crack in the weld.
Old Jan 09, 2013, 03:34 PM
Cudahy, WI, USA
Joined Jul 2005
On those straps there is a nut soldered to the back of the strap. On mine the solder cracked frequently. It is nothing to worry about, the solder is only there to hold the nut so you don't loose it. If you are worried about it, put some solder flux on it and heat it up to reflow the solder. As long as the strap itself does not have a crack in it. The crack usually means that you are over tightening the strap. Snug is all it takes.
On mine I did remachine the radius of the mounts to exactly match the OD of my engine. This is not necessary but just makes me feel better.
Flyinfool is offline Find More Posts by Flyinfool
Old Jan 11, 2013, 11:16 PM
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Those are what Im using on my 750
vettster is offline Find More Posts by vettster
Latest blog entry: 3DTRYER ripped me off!!!
For Sale Zenoah Gas Motor Engine Mount and Rubber Motor Mounts for your gas boat Rondog Boats (FS/W) 0 Jun 17, 2012 11:19 PM
Help! How much should I offset the engine mount mchandrayan The Builders Workshop 16 May 18, 2012 01:38 PM
Sold Sig SH-626 engine mount for .60 to .91 engines plus other mounts jsesere Aircraft - Fuel - Airplanes (FS/W) 1 Apr 29, 2012 11:02 AM
For Sale JTEC Snuf-Vibe vibration isolating engine mount BF4, NIP redball8 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 02, 2012 10:05 PM
Sold Engine mounts gkamysz Boats (FS/W) 0 Mar 01, 2012 11:14 PM
