Old Jan 20, 2015, 07:25 PM
macinr's Avatar
USA, CA, Santa Barbara
Joined Feb 2003
I had to use a dremel disc-wheel-cutter, per James' guidance, on removing material from the socked spar in order to get the servo to slide back enough due to the tab on the servo. Potentially that is your issue? I can get a photo tonight.
macinr is online now Find More Posts by macinr
Old Jan 20, 2015, 07:29 PM
R.I.P
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Wouldn't you be better off removing the servo tab than cutting into the spar?
josh18 is offline Find More Posts by josh18
Old Jan 20, 2015, 09:48 PM
Pompano Hills Flyers
Dangerous James's Avatar
Miami
Joined Aug 2004
Originally Posted by winchdoc View Post
DJ- next trip to HR, If you don't have one yet, I'll let you fly mine.
That may or may not help the Gizmo jones...
WinchDoc
Thank you Doc.
DJ
Dangerous James is offline Find More Posts by Dangerous James
Old Jan 20, 2015, 10:41 PM
I was 1eyed But I fixed that
HUMPHREY1957's Avatar
Central Coast NSW Australia
Joined Nov 2007
I am with josh with that?
It's not like you are going to need the tab again?
HUMPHREY1957 is offline Find More Posts by HUMPHREY1957
Old Jan 20, 2015, 11:57 PM
Yes, ALL your money...
winchdoc's Avatar
A hut in the woods in Oregon
Joined Jan 2003
I just cut a tab sized slot in the spar sock in the right location. The only real 'mount' was the front rail. Everything else was potted in. 1 screw
winchdoc is online now Find More Posts by winchdoc
Last edited by winchdoc; Jan 20, 2015 at 11:59 PM. Reason: look carefully and see some of the wedge I put in on top of the servo
Old Jan 21, 2015, 02:14 AM
Addicted to carbon and speed
Soaring Junkie's Avatar
Australia, QLD, Tingalpa
Joined Jul 2013
That's what I did, using the KST DS135s, and they fit nicely and the control rods align perfectly. Having the servo pop out when crashing, like Tim says, will save you replacing busted control/servo horns.
Soaring Junkie is online now Find More Posts by Soaring Junkie
Old Jan 21, 2015, 05:26 AM
willmo's Avatar
United Kingdom
Joined Jan 2010
My 10mm KSTs won't slide far enough under the skins to align the pushrods - the rear servo lug isn't touching the spar either. I'll have to use 9mm servos (Hyperions) or 6100s which have a smaller footprint.
willmo is offline Find More Posts by willmo
Old Jan 21, 2015, 10:55 AM
macinr's Avatar
Joined Feb 2003
I didn't say it was the BEST idea - but i wedged the servo tab in with epoxy so it's all pretty solid now. I guess I liked the idea of it being fitted in-place. Oh well.
Old Jan 21, 2015, 01:13 PM
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Originally Posted by timbuck View Post
Yep no frames , and the AA takes a bit of a shove to pop in.
Don't worry about glueing servo's in as the skins are tough enough to pop them out easy if needed , And often pop in big landing's which has happened more than I can remember to all of us who fly them. Is a regular thing that happens.
Use the thread search for pic's and you will see winch doc's set up with turnigy 777 on the first page.
I like to use Quick Grip when glueing in servos. No more popping free as it is rather rubbery. May not be available internationally.
-Wayne
Rotozuk is online now Find More Posts by Rotozuk
Site Sponsor
Old Jan 21, 2015, 03:49 PM
ERS....Energy Retention System
timbuck's Avatar
gold coast australia
Joined Aug 2008
Quick grip or similar is available here , also goop give ok results as well with that little bit if give very forgiving on hard landings. I do like epoxy for that rock solid feel but does pop occasionally when I land at 100mph
There's no right or wrong way guys , just glue them in and fly the wing's off it
timbuck is online now Find More Posts by timbuck
Latest blog entry: Gizmo 36 pics
Old Jan 22, 2015, 07:53 AM
gizzo don't tweet
gizzo's Avatar
Adelaide, Australia
Had a laff ds furballing a couple of gizmos at mt leura the other day, Dave and myself.
gizzo is online now Find More Posts by gizzo
Old Jan 22, 2015, 09:40 PM
Miami
Joined Aug 2004
The best thing here is all the cool info I jot down to make my future Giz fly with no issues. Don't see how gooping and using servo screw could the servo still pop out.
DJ
Old Jan 22, 2015, 11:30 PM
gizzo don't tweet
gizzo's Avatar
Adelaide, Australia
I glue them in with 5 min epoxy and dont mind if they pop out. Saves smashing thé servo. Glued thé fin on with Sika.
For Sale FG 1/5 viper. Just tuned by gizmo hobbies in Burbank, CA. New RC. LPU Mrmarshall Cars - Accessories (FS/W) 0 Sep 01, 2012 12:56 AM
Cool Homemade micro tools, gadgets, gizmos, apparatus for flying, modifying, repairing flyrtim Scratchbuilt Indoor and Micro Models 3 Jun 21, 2012 01:18 AM
Discussion Gizmo wanted for Commercials Aaron 1 Life, The Universe, and Politics 15 Jun 01, 2012 02:45 PM
Discussion Anyone ever use the ARC 36-65-1 or 36-75-1 motors with prop? mikes68charger High Performance 0 Apr 16, 2012 09:53 AM
Question electronic gizmo to split a channel carl rich Electric Ducted Fan Jet Talk 11 Mar 28, 2012 10:35 PM
