Old Jan 20, 2015, 09:29 PM
AirQuad
Roman Khudyakow's Avatar
Russia, Tomskaya oblast, Tomsk
Joined May 2013
Hello, World!
I have a problem or is it a normal AR. Drone 2.0 + XR mod?
I turn drone with inserted USB stick
Drone flash card can not "see"
I pull out USB stick and insert again - Drone begins to see the flash card (application FreeFlight USB stick do not see)
so,
reboot AR. Drone (USB stick is inserted)
AR. Drone again the USB stick can not "see"
.. begins to see the USB stick only if it again reseated
Is this normal? If this is not normal, how can I fix it? (I tried to delete all folders "USB" in the directory / data / video /
after the USB stick is inserted, AR.Drone creates a link "usb" and directory named "usb0" ("usb" - this link leads to "usb0" directory.)
but as you have? the attachment screenshot directory ftp://192.168.1.1:21 directory / data / video /
Roman Khudyakow is offline Find More Posts by Roman Khudyakow
Old Jan 21, 2015, 04:49 AM
Makers gonna make...
pawelsky's Avatar
Polska
Joined Jan 2012
Originally Posted by Roman Khudyakow View Post
Is this normal?
Yes
how can I fix it?
Use pendrive that has the metal plug shield connected to GND.
http://forum.parrot.com/ardrone/en/v...ic.php?id=5053
pawelsky is online now Find More Posts by pawelsky
Old Jan 21, 2015, 05:20 AM
Joined Feb 2014
So no one has a variation on the gps question? Further more, can i assume no one uses a gps with the mod full stop?
damouav is offline Find More Posts by damouav
Old Jan 21, 2015, 05:40 AM
AirQuad
Joined May 2013
Originally Posted by pawelsky View Post
Yes
I use the USB Stick is connected to the metal "ground '
mod but did not see after the restart drone USB Stick (((
if you disable the mod board that once is enough to insert the USB stick when the drone
Old Jan 21, 2015, 06:30 AM
AirQuad
Joined May 2013
Yes
You are absolutely right! the case was in the usb stick - sealed-off contact. after changing to another usb stick everything works.
Thanks Pawelsky!
Old Jan 21, 2015, 02:38 PM
Electric Flyer
Connecticut, USA
Joined Oct 2003
So assuming you have a grounded USB stick, would the procedure be to install it AFTER the drone boots up?
Yes...No?
rms59 is offline Find More Posts by rms59
Old Jan 21, 2015, 09:38 PM
AirQuad
Joined May 2013
Yes...No?
Yes! after restarting the drone sees usb stick / further manipulation is required. then copy the files from the usb stick via ftp
Old Jan 22, 2015, 02:54 AM
AirQuad
Joined May 2013
RC Controlled AR.Drone 2.0 w/o WiFi
Night Flight and special effects || AR. Drone 2.0 + RC Mod (XR-4Mod)
Night Flight // Ar.Drone 2.0 Power Edition, RC Mod (XR-4Mod) (4 min 10 sec)
Old Jan 23, 2015, 06:12 PM
Joined Dec 2014
http://youtu.be/PkNOiz-Llc0
Neat video Roman...couple things:
I get some of the same reactions by the ARDs flight mgt system in that sometimes the attitude sticks with a list to one side whilst I'm controlling it to either move left/right or rotate..yours does the same mid flight.
Secondly, doesn't the city of Tomsk plow the streets? If it snows much more, where will you park?
Do you all get a lot of used cars there in Russia from the US? I think I recognize a couple GM sport utility vehicles.
davefolts is online now Find More Posts by davefolts
Old Jan 23, 2015, 11:07 PM
AirQuad
Joined May 2013
Thank you for your kind words about the movie!
In this video, data lists and pictures of the program FreeFlight and other program used only for beauty (as a special effects). Unfortunately the flight route with the installation of intermediate points (coordinates, altitude, speed) are not possible (there is no possibility to use the program in conjunction with QGround + RC.Mod + GPS) - or I do not know how to do it. In this video all the control was initially manual.
We have three weeks every day it was snowing. The roads were cleared but work has not been fully implemented. Therefore, we see great drifts.
Designated parking even in our climate and weather conditions can always be found. :-)
American GM make me excited. The strength and power!
But I probably AR.Drone piloted better than to drive a car :-)
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 05:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 10:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 11:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 12:04 PM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 04:54 PM
