Old Nov 18, 2010, 03:10 PM
agony sweetns the victory
atjurhs's Avatar
Any Flying Field Across America
Joined Jul 2005
Dihedral for Thermal Planks
Hey guys,
I'm in the middle of building a thermal plank
http://www.rcgroups.com/forums/showthread.php?t=536530
Trouble is, I have no idea how much dihedral (EDA) I should build for. Yes, I can look at the plans that I have for the WindFreak, but my wing is different than that one.
Does anyone know of a calculation/formula for determining how much EDA I should use?
Thanks!
Todd
atjurhs is offline Find More Posts by atjurhs
Old Nov 21, 2010, 08:21 AM
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
A good rule of thumb I was given that seems to work well is 1" per foot of span under each wing tip, so a 6 foot wing would have 6" under each tip.
Your 10 foot plank would have 10" under each tip.
Add another inch if in doubt
mhodgson is online now Find More Posts by mhodgson
Old Nov 21, 2010, 01:55 PM
atjurhs's Avatar
Joined Jul 2005
That's probably a good rule of thumb; however, by measurements the Windfreak used 1inch for every 14.75inches of span.
Old Nov 28, 2010, 12:18 AM
Chuck Clemans's Avatar
Bellevue, WA, USA
Plank Dihedral
For my planks with elevons I use 4 degrees which is close to the Wind Freak's 3.88 degrees. For rudder only planks, I use six degrees under each wing.
It really depends on how much stability is desired. I also fly planks with elevons and zero dihedral, but they have be flown all the time which is very tiring when thermaling.
Chuck
Chuck Clemans is offline Find More Posts by Chuck Clemans
Old Jan 28, 2014, 05:06 PM
The Willamette Valley, Oregon
Joined Dec 2008
planks, dihedral and roll trim
Chuck
If any people on this thread or with similar experience are still active on-line, I'm wondering what aileron (elevon) input is typically needed to hold the bank angle constant while circling near the min-sink angle-of-attack, in the case of a Plank plank with this sort of configuration (about 4 degrees dihedral.) Typically a bit of outside aileron, or inside aileron, or neutral aileron? How do you think that would change if we eliminated all the dihedral?
Thanks, Steve
aeronaut999 is offline Find More Posts by aeronaut999
Old Feb 02, 2014, 03:05 PM
Whiskey Tango Foxtrot
guitarcher's Avatar
Australia, QLD, Maryborough
Joined Jan 2013
Steve, my thermal planks , with 3/4"per foot dihedral require a small amount of opposite aileron and some up elevator to maintain constant bank thermal turns depending on conditions.
My smaller slope planks with no dihedral do not require opposite aileron.
I do not use use an active rudder.
Hope this helps.
Greg.
guitarcher is offline Find More Posts by guitarcher
Last edited by guitarcher; Feb 02, 2014 at 03:10 PM. Reason: copy of OP post in another forum
Discussion Dihedral Angle for V Sailplane Wing? ForeverFlying Modeling Science 15 Oct 18, 2010 06:38 PM
Discussion PW51 has two CoG for planks ? Marcos Quito Slope 3 Sep 24, 2010 06:45 PM
Build Log Drive65 PW51 plank (Was: Anhedral/Dihedral and washout in planks) +video! Crashaholic Slope 117 Sep 21, 2008 08:17 AM
Discussion Why does dihedral/ polyhedral help sink rate in tight thermal turns? Flyingwingbat1 Modeling Science 26 Feb 04, 2008 04:57 PM
DS planks and dihedral? Florrain Dynamic Soaring 8 Jun 26, 2005 02:53 AM
