Old Feb 26, 2008, 06:13 PM
hyperdyne is offline
Find More Posts by hyperdyne
Doppler wrangler
hyperdyne's Avatar
Joined Sep 2007
Su-47 model?
Looks cool, but I'd love to hear about info/reviews/etc. How fast, it is worth the dough?
http://www.bananahobby.com/1539.html
Anyone?
hyperdyne is offline Find More Posts by hyperdyne
Old Feb 26, 2008, 07:37 PM
TurboFanElectric is offline
Find More Posts by TurboFanElectric
www.turbofanelectrics.com
TurboFanElectric's Avatar
Tampa, FL
Joined Apr 2002
That is the SU-47 produced by fly-it-yourself.com. I will be testing one shortly. I'm just wainting for my shipment to arrive. I'll report back if no one else chimes in by then.
TurboFanElectric is offline Find More Posts by TurboFanElectric
Old Mar 13, 2008, 08:05 PM
DaveESPI is offline
Find More Posts by DaveESPI
Chef, Snowboarder, WEEEE!
Latham NY
Joined Apr 2007
I was tooling around looking at EDF jets and warbirds, and happened upon this beauty.
It looks spot-on in details, and the quality seems comensurate with the price for a RTF.
Anyone have experience? I looked here in the forums, but no mentions of it at all cept this thread.
SU-47
The SU-47 program is developing the next-generation air superiority fighter for the Air Force to counter emerging worldwide threats. It is designed to penetrate enemy airspace and achieve a first-look, first-kill capability against multiple targets. The SU-47 is characterized by a low-observable, highly maneuverable airframe; advanced integrated avionics; and aerodynamic performance allowing supersonic cruise without afterburner.
This SU-47 holds the same beautiful lines as the original fighter jet. The wing and body used in this jet are specially designed to allow high G maneuvers, yet the wing loading is still very low. It becomes a stableaircraft with excellent performance.
Feature: 4 Channel Full Function Radio Controlled (Aileron,Elevator,Rudder,Throttle) 4 Channl Digital Proportional FM PPM High Quality and Performance Futaba Compatible Radio
Full aerobatic characteristics; inside loops, outside loops, axial rolls, inverted flight, knife edge, stall turns, hammerheads, and spins are possible
2 Powerful twin ducted fans with brushless motors makes it possible to fly this plane at high speed in the situations with much wind
Excellent hedgehopping performace
Die-cast design , spare parts are easy to replace
Excellent stability of nosing up and down
One of the best ducted fan jet in the market!
State of the art components such as Twin EDF55 Ducted Fans with Brushless Motors, Twin 18amp Brushless Speed Control, and 2200mAh 11.1 Volt 15C Li-Po Battery Pack
Famous "Cobra Maneuver" available
Steerable nose landing gear
Rudder helps steer plane on ground on its scale landing gear for easy take off
Ready to Fly in Just Minutes!
Super tough, lightweight airframe!
Perfect appearance and emulation (Scale appearance, great attention has been given to details)
Shock Resistant Reinforced Fuselage and Strong Wings
Can Take Off From Ground or Hand Launched
Ground Take-Off can be performed easily
Excellent Flight Performance
Super easy and super stable electric powered scale R/C park flyer for beginner or middle-level users
Stable inverted flight
Fuselage with pre-installed Electronics, Motor, Servos, and Speed Controller
Superb Quality, Simply the Best RTF Jet you can find!!!
Super stable for beginner, Super low speed for safety, Super low altitude for fun
Fabricated by accurate molds with high fidelity of real airplane
One of the Best Looking Jet in the market
Excellent stability and aerobatic capability
Detailed Body Structure
High roll rate
Digital Proportional Motor Speed Control
Slow Speed Flying Capable, Good for Beginner
Suitable for both beginners and experienced pilots
Approximately 10-15 minutes flight time on each charge - Optional Li- poly battery will help to achieve better performance and longer flight time.
All spare parts and accessories are available
Complete Kit, Ready to Fly, Easy to Assemble (Everything is included and 90% assembled -- only required 8 AA batteries for the transmitter to start flying)
Specification:
Wingspan: 1024mm (40.5 in)
Length: 750mm (29.5 in)
Flying Weight: 700g (24.5 oz)
Wing Load: 55g/dmē
Wing Area: 12.7dmē
Drive System: Twin EDF55 Ducted Fans with Brushless Motors
Servo: 3X 9g high speed micro servos
Speed Controller: 2X 18amp Brushless Speed Control
Battery: 11.1V 2200mah 15C Li-Polymer
Control system: 4 CH Multifunctional FM Radio Transmitter and 6 CH Micro Receiver
Radio Control Range: 3000 feet (1000m)
Package Include:
Airplane (90% assembled)
4 Channel Multifunctional FM Radio Transmitter
Wall Battery Balance Charger
High Quality Rechargeable 11.1V 2200mah 15C Li-Polymer Battery
English Manual
DaveESPI is offline Find More Posts by DaveESPI
Old Mar 14, 2008, 08:36 AM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Absolutely sinister looking...
Is this a good first twin? How does the top speed compare to other kits out there? Can you slow it down at all?
Only available as an RTF?
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Mar 18, 2008, 12:01 PM
DaveESPI is offline
Latham NY
Joined Apr 2007
I picked one up from Nitro models/ planes website.
Will have it in a week. I'll have a good update then.
It was just too damn nice looking not to grab one.
Old Mar 18, 2008, 01:13 PM
Joined Jun 2005
Awesome... thanks for offering to share your impressions.
Did you go with the RTF?
Old Mar 18, 2008, 01:32 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
www.ejf.com carries it as well...
ATIS is offline Find More Posts by ATIS
Old Mar 25, 2008, 06:30 PM
DaveESPI is offline
Latham NY
Joined Apr 2007
Got the Jet. Box was smaller than I expected.
http://aycu35.webshots.com/image/469...7453109_rs.jpg
Oh, I'm so glad to know !
http://aycu37.webshots.com/image/479...3215114_rs.jpg
OH NOES ! there is WITCHES !
The instructions were hilarious with some typos and improper wording, but was clear and easy to use with good pictures.
There was no instructions as to how to set up the radio equipment as the RX was not installed in the plane at the time which could also be a nice thing for people who are more interested in just using the plane and their own radios.
http://aycu30.webshots.com/image/507...1901428_rs.jpg
http://aycu29.webshots.com/image/482...5505905_rs.jpg
The gear kit that came with it seemed good quality. should be able to handle a few hard landings.
http://aycu03.webshots.com/image/480...5381362_rs.jpg
Fairly nice charger, and it ballances as well. NO AC ADAPTER that I could find, so I'll have to figure that one out on my own.
The Lipo.... no idea the brand or quality, but the plugs and wiring look to be of good quality.
http://aycu09.webshots.com/image/492...6474279_rs.jpg
nosecone came pre weighted and is hollow plastic that gets glued ont he front. I was a tad dissapointed about this, but it may be a blessing in desguise as it will be easy to replace once I smash it * and yeah I know it will smash, I always am busting up the nose on my planes.
More pix of build comming soon.
http://aycu10.webshots.com/image/490...7652120_rs.jpg
Old Mar 25, 2008, 09:17 PM
DaveESPI is offline
Latham NY
Joined Apr 2007
http://aycu05.webshots.com/image/502...4541122_rs.jpg
all the parts.
They all test fit together very well.
http://aycu40.webshots.com/image/502...5056247_rs.jpg
hatch is lexan plastic and velcro for RX.
http://aycu32.webshots.com/image/489...9903747_rs.jpg
twin esc's in the tubes for cooling.
http://aycu24.webshots.com/image/485...3050747_rs.jpg
Ya RTF. * with minor assembly
Old Mar 26, 2008, 01:39 AM
Doppler wrangler
hyperdyne's Avatar
Joined Sep 2007
Finally got this guy on order. Cant wait to see it in person.
Old Mar 26, 2008, 10:43 PM
DaveESPI is offline
Latham NY
Joined Apr 2007
Someone said this was "junk" on another forum and made by GUANLI.
I'm familliar with the GUANLI stuff, and this is miles away from it.
72 mhz full porp controls, and quality EDF/ brushless, twin esc's, the servos are "Bluebird" (perhaps knockoffs?) and the battery is LiPo.
Made by a company called FIY "Fly It Yourself" they have a f-16 also that is rhumored to fly nicely.
SO, ok,
I got 90% of the assembly done, charged the batteries, and set the toggle switches. It is set for mixing and all the DIP SWITCHES are where they should be.
I ran the servos and the hardware through a few "paces" on the bench, and I can say without a doubt that the wing servos suck ass. I had one lock up and "freeze" on me twice, then it stripped a gear.
I'm replacing both with some E-Flite s-75s I'm not taking the chance on them locking up in mid flight.
The wing aleron hinges are not attached very well with the kinda crappy HongKong "tacky glue" and I had the throws set at maximum and I ripped one off the surface of an aleron (closest to the servo control rod). I reglued it and it is fine now.
the engines sing a nice loud as hell hum and for fear of waking my upstairs neighbor, I didn't go past 1/4 throttle, but it was enough to blow papers off my desk, so I can tell this baby has a lot of grunt sofar.
Hopefully this is the end o my issues with it.
I put some double sided tape in the landing gear as a "spacer" for where it mounts to the brackets (will post pic soon) and I was also able to utelize some gorilla glue to button up a few minor crevaces and make it a structuraly sound wing structure as it mounted to the fuselague.
Old Mar 30, 2008, 09:22 PM
Doppler wrangler
hyperdyne's Avatar
Joined Sep 2007
I think the pieces of this model go together very well. They fit together nicely and the fit and finish is on par with all the other RTF models out there (if not better). The linkage is interesting and has screws for securing - not the cheap clevises you typically find.
After powering mine up, I am not sure if I am hearing vib or the beat note of both motors. I cant see or feel and strong vib, but the exhaust note is certainly different than a single edf. I measured the model at 28oz, and was getting 18 oz of thrust.
I am wondering on the motor kV, it might be nice to go to a higher kV motor (like the stock hp f-16 motor). Anyone know motor specs??
Also does anyone know the correct CG location?? Its not in the manual
I maidened mine and it flew really nose heavy. They even put some putty in the nosecone, wasnt sure if that was needed or not. Also lost a nut on the elevator control linkage in flight! Other than that it was a pretty cool flight, this thing is a sight to see in the sky.
Old Mar 30, 2008, 10:14 PM
Tampa, FL
Joined Apr 2002
su47 CG
Hyperdyne congradulations on the successful maiden.. Here is the CofG on the FIY SU47. Also if you put a drop of CA on the nuts they will not come off; I had the same issue and the CA solved it.
regards,
William
Old Mar 30, 2008, 10:30 PM
lavochkin is offline
Find More Posts by lavochkin
lavochkin's Avatar
Mokena,Illinois -United States
Joined Oct 2006
I had to pull mine apart cause of manufacturing defects! I believe the kv was 4400kv. Two of the hp f-16 would indeed be better on 3s at 5100kv. Better yet two lsjs on 4s would be surely over 1.1 ttw. The fans are good! They are a type of xf fan with its own molded lip like the gws fans.
lavochkin is offline Find More Posts by lavochkin
Old Mar 31, 2008, 11:39 AM
Doppler wrangler
hyperdyne's Avatar
Joined Sep 2007
What kind of defects did you have?
I am still getting some vib sounds but not sure if it is true vib. The motors stop fairly abruptly when power is removed. But I dont see any of the fan blades rubbing at all. They are a pretty good fit.
I am wondering if the HP-16 motors would fit right in. I might try that as I have 2 of them sitting around. On stock I am getting about 0.6 thrust-weight. Would be nice to get that up to above 0.8.
Colito, thanks for the CG info. Against my better judgment I flew it without checking CG! I just had to see if fly once. LOL But I will go back now and check CG and tighten everything up.
BTW, if you are looking to get one of these check out www.turbofanelectrics.com. Nice price for the RR version!
SU-47 Berkut Parkflyer Rane Pusher Prop Jet Models 215 Feb 03, 2016 11:22 AM
Foamy SU-47 Construction Rocketman1092 Foamies (Kits) 2 Aug 19, 2008 11:55 PM
SU-47 Plans Blindrage Fuel Jet Talk 8 Oct 04, 2007 04:04 PM
Su-47 aids Electric Ducted Fan Jet Talk 2 Dec 06, 2004 01:16 PM
SU-47 Project cyberfly Electric Ducted Fan Jet Talk 7 Oct 27, 2002 10:10 AM
