Old Mar 18, 2007, 06:59 PM
Trex Fanatic is offline
Find More Posts by Trex Fanatic
Trex Fanatic's Avatar
Christchurch, New Zealand
Joined Jun 2006
Futaba GY240 VS GY401
I have a GY240 and have a 401 on the way. I an using a HS-81 at the moment on the tail. Am I likely to notice a difference with the 401 using an analogue servo or do I need to go to a digital servo for it to really shine over the 240?
Trex Fanatic is offline Find More Posts by Trex Fanatic
Old Mar 18, 2007, 07:25 PM
Spidious is offline
Find More Posts by Spidious
Bush Pilots Bounce Higher
Spidious's Avatar
USA, IL, Champaign
Joined Dec 2006
Try a POLO 4 Digital. Same size and about $50
http://www2.towerhobbies.com/cgi-bin...?&I=LXGZU9&P=7
This is the MultiPlex Mini Polo Digital Size Servo.
FEATURES: Heavy duty metal gears Universal connector Can be used in aircraft where a Mini size servo is needed 3-Pole Motor Dual Ball Bearing
INCLUDES: One MultiPlex Mini Polo Digital Servo with 1 each round, star shaped, and two straight arms, four mounting screws, four rubber grommets, and four eyelets
REQUIRES: Installing in model
SPECS: Length: 1.1" (28mm) 4.8V 6.0V Width: 0.5" (13mm) Torque: 39 oz-in 49 oz-in Height: 1.3" (33mm) Speed: 0.10 sec 0.08 sec Weight: 0.77oz (22g) Motor: 3 pole ferrite
Spidious is offline Find More Posts by Spidious
Old Mar 18, 2007, 07:40 PM
ozace is offline
Find More Posts by ozace
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
You will notice the difference between the 2 using the same servo and you wil get the most out of it using a fast tail servo.
ozace is offline Find More Posts by ozace
Old Mar 18, 2007, 07:41 PM
thermlin' is offline
Find More Posts by thermlin'
Needs a vacation
thermlin''s Avatar
In a house
Joined Nov 2005
hes asking about gyro differences.
no, from what i read, you should feel it right away. the 240 is said to have a slower piro rate, and the holding isnt as good. plus, gain needs to be changed on the gyro itself, not that it REALLY matters, but its more precise on the radio/401 because you can use 1% by 1% rather than a pot. plus, the 401 has a DS mode which optimizes for futaba digi servos.
thats all i can think of, somebody else could probably help.
if youre going to spend that much on that digi servo, youre better off going for an extra $10 on a Futaba 9650.
for 35 bucks though, the S3154 is a steal. DO NOT DO NOT DO NOT run DS mode on a 401 and an S3154 on 6V. and keep the tail shaft SLICK, im talking lube every 5-10 flights. i burned up my S3154 not doing these. Futaba replaced it for free, and i thankfully get another chance. im sure its a great servo (FAST!), but i apparently never gave it a chance.
thermlin' is offline Find More Posts by thermlin'
Old Mar 18, 2007, 08:07 PM
billyzelsnack is offline
Find More Posts by billyzelsnack
drops screws
Iowa City, IA
Joined Dec 2005
I like the 401 over the 240 for two reasons..
I really like having a limit. It really is annoying when working on your heli and having your tail servo constantly binding.
I love messing with my gain from the TX instead of the stupid pot on the gyro.
billyzelsnack is offline Find More Posts by billyzelsnack
Old Mar 19, 2007, 07:52 AM
Vince Herman is offline
Find More Posts by Vince Herman
Vince Herman's Avatar
United States, OH, Strongsville
Joined Nov 2000
In my experience, both the 240 and the 401 hold the tail VERY well.
As Billy Z said, the limit is really nice to set the servo movement limits.
And I do know that the 401 pirouettes considerably faster.
I think that with your existing servo, you will see all of the benefits, unless you are into 3D, and then the Futaba 9650 servo will be what you want.
Vince
Vince Herman is offline Find More Posts by Vince Herman
Old Mar 19, 2007, 02:04 PM
johnbyrne is offline
Find More Posts by johnbyrne
Often wrong ("wife")
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
Can you run the 401/9650 is DS at 6V or is this only for use with the S3154?
Thanks in advance
John
johnbyrne is offline Find More Posts by johnbyrne
Old Mar 19, 2007, 03:07 PM
Joined Jun 2006
Can the 401 run on 6V OK and is the 9650 OK on 6V as well?
Old Mar 19, 2007, 03:08 PM
Joined Jun 2006
Vince
Thanks Vince,
I am into 3D but only the basics so far so I will test the waters with the 81 first and then decide if moving to digital is worth it.
Old Mar 19, 2007, 03:48 PM
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
I checked the S9650 and it is "rated" for 6v. What is the issue with the S3154? Is it only the 6v or is it only the 401 or both?
Seriously considering selling one of my 240s and try a 401 with the S9650 on a TRex. Is this the way to go and worth getting rid of one of my trusted and proven GY240s?
Old Mar 19, 2007, 04:14 PM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
I would not run the 401 or 9650 at 6V. I remember reading about bad things happening.
The 401 and 9650 is awesome. The 9650 doesnt burn up for mysterious reasons and its super fast. I am sooo happy with that combo and so glad I didnt settle for less.
vic20owner is offline Find More Posts by vic20owner
Old Mar 19, 2007, 05:48 PM
Needs a vacation
thermlin''s Avatar
In a house
Joined Nov 2005
9650 should be fine on DS mode at 6V. nobody seems to have problems. the issue is running an S3154 at 6V with DS mode. it seems you can get away with it, and ive heard of people doing it, but you really gotta keep the tailshaft slick. mine was running 6V, DS mode, and a little sticky shaft when it burnt up. ill be running 6V with DS mode here when i get flying again and see how it goes.
try it out-if it gets a little hot after flights, switch to 5V or Normal. its not worth the risk of burning it up.
i was thinking about just getting a 9650, but this S3154 is so blazin fast im spoiled now. and if you get it locked in well, it holds like a rock.
whatever you do, keep that shaft slick, because with the lower torque S3154 vs. the 9650 it doesnt take a whole lot of stick to burn it up.
Old Mar 19, 2007, 05:52 PM
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
I've decided to get the 450SE so my funds don't allow the 401 .... yet . Sooo for now it will be the trusted 240 probably on 6v. What servo is recommended? Could I get by with an HS50 for awhile and save for the 401? I have several HS50's.
Old Mar 19, 2007, 05:53 PM
Needs a vacation
thermlin''s Avatar
In a house
Joined Nov 2005
ive not had any experience with it, but it can WORK for hovering. i emphasize WORK because it will only do that. it has VERY little torque, and the tail will be sloppy. 3D? no. get a better, higher torque servo, even if its analog.
whew! theres a LOT of people on right now! 70 people, 48 of which are members. havent seen it this full in a long time.
Old Mar 19, 2007, 09:53 PM
rotarypower3 is offline
Find More Posts by rotarypower3
Trex450/500/600E(vBar)
rotarypower3's Avatar
Melbourne (east burbs), AUSTRALIA
Joined Mar 2005
Rubbish!
I've been running the 9650 on 6V and digi mode for 15 months now with no probs...
rotarypower3 is offline Find More Posts by rotarypower3
Futaba GY240 vs GY401 Wingnut One Electric Heli Talk 13 Jul 26, 2005 04:55 PM
GY240 vs GY401 luis104 Micro Helis 22 Jun 16, 2005 03:36 PM
Futaba GY240 vs GY401 in a micro el heli RaEh Micro Helis 6 Jun 03, 2004 06:45 PM
Who has the best prices on a Futaba GY240 or GY401 gyro? vkmaynard Electric Heli Talk 7 Apr 16, 2004 11:37 PM
Futaba gy240 vs. csm200 wademcgee Micro Helis 12 Jun 15, 2003 09:18 PM
