Old Dec 07, 2005, 12:21 AM
inSANe DIEGO is offline
Find More Posts by inSANe DIEGO
Journeyman re-kitter
San Diego, Cali
Joined Oct 2003
How do I get started making videos????
I'm not sure if this is where to post this, but it's the best I could find being as tired as I am. Can anyone point me to a "how to" website (how explain here how to) for getting the video from my mini dv cam (sony dcr-trv19) to my computer (PC) with sound? I've used the bundled software that came with the camera, but no sound comes across when doing a USB xfer and the picture quality is terrible. Must I get a fire wire card to xfer the image to the PC with sound and quality?
Also, I'd like to get info on converting from dv to different computer video types (like avi, mpeg, etc.) and then to dvd or at least vcd.
John
inSANe DIEGO is offline Find More Posts by inSANe DIEGO
Old Dec 07, 2005, 12:36 AM
Skrogg is offline
Find More Posts by Skrogg
Balsa is for doll houses
Skrogg's Avatar
Texas, San Antonio
Joined Aug 2004
Audio (7)
The DCR-TRV19 is not designed for sound quality. Despite minimal motor noise, the mike is tiny and sounds tinny. One would be remiss not to invest in the external microphone, which attaches to the camcorder's hot shoe. Unfortunately there are not many recording options either, multiply channels for adding sound or voice over in post just aren't offered.
Found that on the web
When you capture the video to your PC what format is it? AVI?
As for free software i've had allot of luck with MoviemakerXP
what software are you using to capture the video now?
What are the specs on your PC?
Skrogg is offline Find More Posts by Skrogg
Old Dec 07, 2005, 07:06 AM
dawnron1 is offline
Find More Posts by dawnron1
"Have Glue - Will Travel"
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
John,
I have a Sony MiniDV camcorder, and I'd highly recommend a firewire card, especially if your pc is fairly new and you have an extra PCI slot to install the card into. They are cheap and the data transfer is MUCH faster than with a USB connection. To be honest, I didn't even use the software that came with the camcorder. As Skrogg mentioned, I also use Windows Movie Maker, which is a free download from the Microsoft website, is easy to use and works great. The review I just finished that is on the Ezone has some videos I made with my camcorder and the firewire card:
http://www.rcgroups.com/links/index.php?id=4947
Ronnie
dawnron1 is offline Find More Posts by dawnron1
Old Dec 07, 2005, 12:08 PM
San Diego, Cali
Joined Oct 2003
Well, for some reason my computer isn't even recognizing that I've hooked the camera up to it with the USB cable. I'm suspecting that when the ccd blew it was because of disconnecting the USB incorrectly and it also damaged the USB port somehow. I've since gotten the camera fixed, but maybe the USB port was missed. When the computer was "seeing" the camera I was using Pixela Image Mixer to capture the video. It never did seem to work correctly and the sound never came across. I guess I'll go the firewire route. How much would a card run me and is there a specific one you recommend or are they all the same? My laptop may already have one in it. Trying to find out about that. If it does I guess I can capture to it then xfer the file to my desktop to burn the dvd.
John
Is there anything else I would need to get other than a FW card and cable? Does Moviemaker recognize the format coming out of the cam?
Old Dec 07, 2005, 12:17 PM
LBMiller5 is offline
Find More Posts by LBMiller5
Use the Force!
LBMiller5's Avatar
San Marcos, CA
Joined Jan 2005
Most DV cameras have 2 outputs, a USB connection and a Firewire connection. The USB conection is for downloading still photos from the SD chip or Memory Stick. The Firewire connector is for downloading the video from the tape. Make sure you are not trying to plug your USB cable into the Firewire output.
Firewire is truly the only right way to go when downloading video. The PC will recognize the camera and you can control the playback from a little interface on the PC via the firewire connection.
You can get a firewire card for your PC for $20.00 or less if you do not already have one.
Lucien
LBMiller5 is offline Find More Posts by LBMiller5
Site Sponsor
Old Dec 07, 2005, 12:54 PM
Indiana_Geoff is offline
Find More Posts by Indiana_Geoff
Random Pic #23982
Indiana_Geoff's Avatar
Joined May 2005
Go get some "good" software. My current pick is the latest version of Pinnacle Studio. It will manage the download and editing. Go ahead and spend the bucks for a full (not bundled) version.
That being said, all video editing software is buggy, flakey, prone to crashing, memory hogging and frustrating. You just have to get used to it.
Indiana_Geoff is offline Find More Posts by Indiana_Geoff
Old Dec 07, 2005, 01:00 PM
Skrogg is offline
Skrogg's Avatar
Texas, San Antonio
Joined Aug 2004
Mabey for you
Old Dec 07, 2005, 01:04 PM
tridim is offline
Find More Posts by tridim
tridim's Avatar
Denver, CO
Joined Jan 2005
Except Sony Vegas Video. IMO the best video editing suite ever written. It's rock solid and then some.
I think there's also a consumer version available you might want to check out.
http://www.sonymediasoftware.com/pro...code=3144-3000
tridim is offline Find More Posts by tridim
Old Dec 08, 2005, 06:57 AM
podavis is offline
Find More Posts by podavis
podavis's Avatar
Louisville KY
I second that. I downloaded the $100 version from the Sony website and ordered the optional cdrom for S&H as a back-up. Totally satisfied customer. My pre-teen son also figured it out and made a good video with almost no help from me. Tons of features like fades and transitions. Interface is fast and almost bullet-proof. Never hung or crashed. Note: Computer specs make a difference. Mine is a 2.4GHz P4 laptop with 128M video RAM, 512M RAM, GeForce video chip.
podavis is offline Find More Posts by podavis
Old Dec 08, 2005, 09:16 PM
San Diego, Cali
Joined Oct 2003
Well wouldn't ya know it...
I took a closer look at my puter and it already has a 4 pin firewire in it. DOH! Dumb I've only had the thing for four years and the cam for two. I could have been doing this stuff for a while now! Ok. I'm looking at possibly making the switch to the other guys in Mac land. What are the top video editing programs for a mac that are at consumer price level?
As for this puter (PC) I think I'll stick to something basic so I don't throw money at something that I won't be using for photography and such. I looked at the Microsoft site for Movie Maker and found v2.1. Are there any effect filters by Microsoft or interest groups for it? Mainly looking for something to make it look like vintage film. Maybe even with the scrape lines like in film reels from elementary school.
John
Old Dec 08, 2005, 10:27 PM
Random Pic #23982
Joined May 2005
Check out this video http://www.e-flightline.com/multipod.htm click on the old plane on the lower right. Very well done oldie video.
How do I get started? SafetyChain Combat 7 Mar 12, 2004 07:20 PM
how do i get started in ion lithim batteres? Thomas Manson Parkflyers 1 Jul 08, 2002 11:12 PM
How do I get more negative pitch on my eco 8? jtthebiggafigga Electric Heli Talk 3 Nov 28, 2001 11:35 PM
How do I get pictures on web from film??? bjsiegel@texas.net Electric Plane Talk 5 Oct 07, 2001 07:22 PM
How do I get that Superslim x-tal cover / protection (rubber thingy) in place?? Erik Johansson Power Systems 4 Jul 10, 2001 07:07 PM
