Old Mar 20, 2005, 07:52 PM
Smooth Spanky is offline
Find More Posts by Smooth Spanky
Hack of all trades...
Smooth Spanky's Avatar
Detroit, Michigan
Question
When to re-charge field battery?
I recently bought a new hobby battery (12V) to power my panel in my field box (starter, etc). Being curious, I put the voltmeter across the battery poles and it measured 12.8V with no load. At what voltage should one of these batteries be re-charged?
Thanks!
Smooth Spanky is offline Find More Posts by Smooth Spanky
Old Mar 20, 2005, 08:43 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Thanks!
Ask 10 people and you most likely will get 10 different answers. Many so called experts state that 12.2 volt is approximately 50% charged. It is reallyy best not to deep cycle most inexpensive gell cell batteries that are not relly designed for deep cycle useage.
Back when I flew glow a lot I charged mine weekly sometimes every few days.. Most of my e power field power source 12 volt batteries get charged weekly just to keep them toped off.
http://www.batteryuniversity.com/parttwo.htm
Charles
Old Mar 22, 2005, 08:27 PM
Detroit, Michigan
Charles:
Hey, thanks for the information and for the web site. What type of charge rate would you use, that is, would you overnight charge?
Thanks again!
Old Mar 22, 2005, 08:53 PM
Southern Pride
Charles:
Thanks again!
The stsndard overnight charge rate is C/10 or 10% of the batteries capacity which for a 7Ah would be 700 mAh / 0.70Ah. Most chargers designed for thes batteries are around 500 - 600 mAh . I have a Hanger 9 one which has an LED which dims as the charge rate cuts back,simple and effective.
Charles
Old Mar 22, 2005, 09:33 PM
Cas123 is offline
Find More Posts by Cas123
Perth, Australia
Joined Mar 2004
If you can find a dc power supply that can put out a steady 13.2v - 13.4v you can leave the charger on all the time when its not in use. The important thing, as everydayflier states is to make sure you dont put too many amps through it when charging, C/10 is a good rate.
If your charger is putting out more than this, a large resistor in series can reduce it. I have used a auto light bulb in series with the battery to limit the current .
Unlike Nicads and Nmhi and lipo batteries, Lead acid batteries in general deteriorate more quickly whilst not in a fully charged state. So its a good idea to recharge it immediatly after use and keep them that way to get max life expectancy.
Ron...
Cas123 is offline Find More Posts by Cas123
Old Mar 22, 2005, 10:29 PM
adamdb is offline
Find More Posts by adamdb
United States, CO, Denver
I usually charge mine with my Triton as soon as I get home from the field. I had heard that they don't like to be left discharged.
So far, so good.
Adam
adamdb is offline Find More Posts by adamdb
Old Mar 22, 2005, 10:39 PM
Bob Baker is offline
Find More Posts by Bob Baker
Austin, TX, USA
Joined Feb 2001
Originally Posted by everydayflyer
10% of the batteries capacity which for a 7Ah would be 70 mAh / 0.070Ah.
Slight decimal correction: 7/10=0.7 Amps.
Bob Baker is offline Find More Posts by Bob Baker
Old Mar 22, 2005, 10:59 PM
Southern Pride
Noted and corrected
I guess that comes from charging to many batteries of less tha 1000 mAh, atleast I got the C/10 part right..
Thanks,Bob
Charles
Old Mar 23, 2005, 05:05 AM
rscamp is offline
Find More Posts by rscamp
rscamp's Avatar
Dundas, ON Canada
Joined Feb 2001
Ron...
Yup - they sulphate badly when not maintained at a full charge.
Rob
rscamp is offline Find More Posts by rscamp
Old Mar 23, 2005, 05:29 PM
Detroit, Michigan
I'm now duly educated and aware of the fact that I'm doing things completely wrong! I'll be charging my battery when I get home tonight!! I learn something everyday if I'm not careful, thanks again.
Smooth
Old Mar 24, 2005, 07:13 AM
batman is offline
Find More Posts by batman
Baptised Heathen
batman's Avatar
Bundaberg, Qld, Australia
Joined Jun 2002
You have to be carefull about learning stuff everyday. I try not to because I'm crammed so full of useless information now there's not much room left up there.
batman is offline Find More Posts by batman
Help! Cigarrette lighter from car to charge field battery mrfliboy DIY Electronics 0 Jan 16, 2007 12:28 PM
How do you charge a field battery Solcat Batteries and Chargers 1 Sep 16, 2005 10:27 PM
When to charge Tx battery?? duganderson Batteries and Chargers 1 Jan 30, 2003 09:43 AM
Can I charge a 12V Field Battery with a GWS MC2002 Charger? mrebman Parkflyers 6 Jan 17, 2003 06:23 AM
What size field battery to charge motor packs? 1g1yy Electric Plane Talk 5 Aug 02, 2002 04:06 PM
