Old Apr 18, 2016, 08:33 AM
basicguy is offline
Find More Posts by basicguy
Dream it...Build it...Fly it!
basicguy's Avatar
United States, MO, Macon County
Joined Dec 2014
folding MPF, can it be done?
One of the reasons that come back to Reddi board is that I can fold it into a airfoil shape pretty easy. I like the qualities of MPF for flat stock and have sanded it to shape but my luck in folding it as for a leading edge have not been great.
I have tried ironing on tape but no joy.
Not dissing MPF I like it a lot, just trying to use it to it's full potential.
Has anyone had good luck with sharp bends on MPF.
basicguy is offline Find More Posts by basicguy
Old Apr 18, 2016, 09:26 AM
SNice is offline
Find More Posts by SNice
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
I've done several successful MPF wings with fold over leading edges. It did take some time to get my process down but since then I have had no issues.
Here is how I do it:
It's all in how you treat the inner fold surface.
- For a sharp leading edge, I mark my leading edge line with a pen or pencil.
- Then I sand a v-groove (using the corner of a sanding block) along the leading edge fold line. The deeper you sand the groove, the sharper your leading edge will be. I generally do not go deeper than 50% thickness.
- Next, place tape along the outside surface of the leading edge fold line. The tape will help prevent the foam splitting along the seam. If you plan on removing the tape once the wing is formed, use painters tape.
- Fold the wing in half along the leading edge. Fold it completely in half. Do not force it back open or you will split your leading edge. I usually open the folded wing just enough to put a bead of hot glue along the inside v channel. This helps to protect your leading edge. I think the heat also helps prevent splitting.
- Your wing skin should now be ready for installation of ribs, spars, etc.
Hope this helps! I have pics of the process in build logs of mine. I will attempt to locate them. Note - my process is the same for DTF. MPF behaves a bit differently due to its thickness.
Happy Building and Flying!!!
SNice
SNice is offline Find More Posts by SNice
Old Apr 18, 2016, 12:21 PM
basicguy is offline
basicguy's Avatar
Joined Dec 2014
Thanks, had not thought about using a groove on the inside.
For DT foam I usually just remove paper from inside and using a 3/8" dowel on the inside then work it over. Once the wing is done I mist lightly the paper and peel it off, then tape it.
Discussion Turnigy i10 to i6 in a buddy setup can it be done? Paul80 Radios 3 Nov 02, 2015 10:02 AM
Discussion sailplane wing on sport fuselage can this be done carl witwer Electric Plane Talk 16 Sep 27, 2015 10:50 AM
Discussion Triebfluegel..... can it be done? quenda VTOLs 36 Aug 09, 2015 07:59 AM
Question Devo7 Tx which UHF mod can be done? thach FPV Talk 1 Oct 19, 2013 05:21 PM
