Old Oct 15, 2015, 12:49 PM
mm2icbm is offline
Find More Posts by mm2icbm
Quando Omni Flunkus Moritati
mm2icbm's Avatar
United States, FL, Ocala
Joined Feb 2013
CC Programming 600DFC
Greetings,
I have an Align 600E DFC, with a CC ICE2 100 ESC, programmed for Throttle Type - Fixed End-Points. I would like to re-program the ESC for Throttle Type - Governor Mode.
A little about the heli. It has an Align RCM-BL650L (1220 Kv) motor powered with a 6S 5000mAh pack. 12 tooth pinion, 188 tooth main gear. Don't know the pole count on this motor and a search of the web hasn't provided me with this information either.
So, what do you recommend for setting up this bird? Need to know desired head speed 1, 2, & 3 as well as any other pertinent information I might need to know.
Thanks in advance for replies I get.
mm2icbm is offline Find More Posts by mm2icbm
Old Oct 15, 2015, 02:59 PM
Paul 1968 is offline
Find More Posts by Paul 1968
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
First and foremost have you got the Castle link and software downloaded? It will make the job a heck of a lot more straight forwards. You'll need to know your maingear tooth count, pinion tooth count and the number of poles on the motor, look into the can and count the magnets, that's your pole count. Make sure your endpoints are set correctly in your Tx. The rest is simple, plug the esc into the software, click on the governor tab. Then tell it what your desired headspeed is and it'll tell you your throttle curve point, that's it, it's that simple.
Paul 1968 is offline Find More Posts by Paul 1968
Old Oct 15, 2015, 05:07 PM
mm2icbm is offline
mm2icbm's Avatar
Joined Feb 2013
Yes
Yes
Yes
Yes
Was hoping I didn't have to remove the motor from the frame to count the magnets!
Yes
But how do I determine what my desired headspeed is? Is this just a number I pull outta thin air or what??
Old Oct 16, 2015, 05:00 AM
FlyingPhilUK is offline
Find More Posts by FlyingPhilUK
I built a new
FlyingPhilUK's Avatar
United Kingdom, Scotland, Edinburgh
Joined Jan 2013
Here's my HS settings on my 600 with a CC ESC:
Desired Head Speed 1: 2000
Desired Head Speed 2: 2100
Desired Head Speed 3: 2245
FlyingPhilUK is offline Find More Posts by FlyingPhilUK
Old Oct 16, 2015, 05:17 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
generally the older 6s version of the trex 600 would run lower head speed than the 12s pro, but 2000RPM +/- 100RPM or so should put you in the ballpark. I don't usually worry about the exact RPM., it's more how it 'feels' in flight so just adjust to suit your preference.
According to this site it's a 6 pole motor: http://www.snhobbies.com/product_inf...oducts_id=1068
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Oct 16, 2015, 06:10 AM
I built a new
Joined Jan 2013
Good point about 6s vs 12s
Old Oct 16, 2015, 07:57 AM
mm2icbm is offline
mm2icbm's Avatar
Joined Feb 2013
Thanks!!
Thanks for this information as it is exactly what I am looking for. RCG is the best!!!!!
Old Oct 16, 2015, 06:45 PM
I built a new
Joined Jan 2013
You're welcome! Pleasure to be of service!
For Sale Trex 600DFC with batteries CrashnBurn420 Aircraft - Electric - Helis (FS/W) 1 Sep 22, 2015 05:39 PM
Sold WTS: CC Phoenix Edge 120HV ESC (No BEC) with Castle program card redtwiilight Aircraft - Electric - Power Systems (FS/W) 3 Jul 01, 2015 07:47 PM
For Sale Align Trex 550E Helicopter with 600DFC Flybarless and BeastX (BNF) Skywarrior01 Aircraft - Electric - Helis (FS/W) 0 Aug 24, 2014 06:21 PM
For Sale Price Drop Align Trex 700 Flybarless Head only! CC Pro Bec & CC Field Program Card Lenny7118 Aircraft - Electric - Helis (FS/W) 3 Sep 14, 2011 02:52 AM
Question CC 125 / CC 180 - firmware/programming carpetbomb High Performance 2 Aug 09, 2009 06:08 PM
