Old Apr 23, 2015, 07:57 PM
ace_drummond is offline
Find More Posts by ace_drummond
ace_drummond's Avatar
United States, CO, Parker
Joined Mar 2001
FRSky DHF Module
Does anyone have the pinout for the FRSky DHT module?
Thanks//
Note 'my mistake' below. Need info on DFT pinout.
ace_drummond is offline Find More Posts by ace_drummond
Old Apr 24, 2015, 06:29 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
red/black power up to 3s lipo - 14V
the other remaining wire is PPM input.
renatoa is online now Find More Posts by renatoa
Old Apr 24, 2015, 09:17 AM
Joined Mar 2001
My mistake
I am looking for pinout module DFT which is module that would normally go into a Futaba TX.
It has 5 pin connection on the back.
My plan is to refit this into the shell of the AM module and make the connection to the 10pin Futaba connection on an old AM system 8JN.
Thanks//
Old Apr 24, 2015, 09:21 AM
Joined Sep 2007
title typo then, DHF don't even exist
well, should be as any standard futaba module
http://damage-designs.com/blog/2013/...-and-flys.html
Old Apr 24, 2015, 09:23 AM
Warjet1950 is offline
Find More Posts by Warjet1950
RC Warjet
United States, CA, Jamul
Joined Mar 2013
Are you wanting the module or just the pin-out configuration?
Thanks//
Warjet1950 is offline Find More Posts by Warjet1950
Old Apr 24, 2015, 09:45 AM
Joined Mar 2001
Just looking for the pinout of that module.
Old Apr 24, 2015, 10:05 AM
phil_g is online now
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
From hole nearest the edge of the module, it goes PPM, Pos, no-connection, Neg, no-connection.
They run fine on 2S.
phil_g is online now Find More Posts by phil_g
Old Apr 24, 2015, 11:24 AM
Joined Mar 2001
Got it and appreciate the input.//
Old Apr 26, 2015, 06:17 PM
Joined Mar 2001
Finished Product
End Result is FrSky module in a Futaba FP-T8JN.
This is an old AM TX with a 10 pin AM Module.
I took the board out of the old AM module and cut an opening in it to accommodate the somewhat smaller FRSky module (it has only 5 pins).
Connection to the old TX is via a 3 wire servo cable cut in half. Female cable end soldered to the pins needed on the TX 2=(PPM OUT), 3=(+), 5=( -) Slipped 1/16 heat shrink over them.
I soldered male end wires to the new module where pins would have gone 1=(PPM IN), 2= (+), 4 = (-)
End product looks like it was made that way!
Now all I need to do is find another old AM 10 pin Futaba Module so I can build one with an Orange DSMx module and this will be complete!
Old Apr 27, 2015, 01:34 AM
Joined Sep 2007
Based on pin layout and distances, another approach would be to remove the leftmost pins and the four rightmost pins, ans just plug the DFT without any wiring/soldering.
Should work, try this way and you will have a p&p solution.
Old Apr 27, 2015, 09:10 AM
Joined Mar 2001
DFT module is much smaller than AM module thus it would not stay in place without some type of modification.
Also what I did is easily removable in future should someone want to do that.
Thanks for you comments//
Old Apr 28, 2015, 04:21 AM
Joined Sep 2007
Sure, you can check this design too, derived from a similar idea of mine.
Sold FRSKY DJT module + LCD for JR/Spectrum/Frsky Tx, 2 D8R-II Plus receivers $70 Shipped NHmoose Aircraft - General - Radio Equipment (FS/W) 5 Sep 14, 2013 10:18 PM
Question 9rx with Frsky module .. should I upgrade to DIY Frsky Tx? CyberCrash Radios 5 Jul 07, 2013 02:59 AM
Discussion Connectng FrSky telemetry to FrSky module?? ZSimon Radios 5 Aug 16, 2012 03:19 PM
Sold Frsky diy module v8ht + frsky 8ch rx v8fr vewdew Aircraft - General - Radio Equipment (FS/W) 5 Mar 15, 2012 11:29 AM
Discussion Anyone know how to convert DX7 to FrSky 2.4Ghz using the DIY module from FrSky?? roberted5 DIY Electronics 6 Sep 09, 2011 10:43 AM
