Old Nov 09, 2014, 08:36 PM
JureZ is online now
Find More Posts by JureZ
Sokol
JureZ's Avatar
United States, CA, Walnut Creek
Joined Jul 2013
High Wing pusher - 54" Chuck Glider conversion
I would like to share with you my High Wing pusher - Chuck Glider conversion project.
It was a very tempting proposition to me to do this conversion as the 54" wing span foamy chuck glider could be purchased at HobbyTown for just $8, and the rest of the material was available on hand.
here is a link to my blog describing two versions of the plane.: high wing pusher - chuck glider conversion blog thread
It started as a RET first, then modified the wing to have ailerons, with two 9g servos on the wing. No landing gear , hand launch and belly land.
The design proved to be very stable and nice to see flying on the air.
"It flies like it is on rails" ...
It has shown also to be quite capable as a trainer and a platform for a Mobius HD camera.
It is well behaved in windy conditions, to the point that I flew it in one occasion when the wind blew my hat off...
Just in case, I am attaching here some of the pictures from the blog , to give an idea of what it is all about.
JureZ is online now Find More Posts by JureZ
Old Nov 10, 2014, 05:06 AM
JureZ is online now
Sokol
JureZ's Avatar
Joined Jul 2013
some numbers:
and here are some numbers:
AUW : 933g = 32.9 oz
Length = 38.5"
Wing span = 54.0" , wing chord at root = 6.75" ; mean wing chord = 7.5"
Wing area = 405 sq in = 2.81 sq ft
Wing loading = 11.7 oz/ sq ft
CG is located 3.25" from wing leading edge at root.
Vertical distance from top of horizontal stabilizer to wing bottom = 5.5"
Horizontal distance from trailing edge of wing root to root leading edge of h stabilizer = 14.0"
Horizontal stabilizer + elevator inscribed in rectangle of dimensions = 18.0" x 8.0"
Vertical stabilizer + rudder inscribed in rectangle of dimensions = 8.5" x 6.5"
Vertical distance from top of tail boom to motor shaft = 6.25"
Old Nov 11, 2014, 01:39 AM
JureZ is online now
Sokol
JureZ's Avatar
Joined Jul 2013
motor spec
The motor is a Turnigy 2217-16 , 3S , 20 A , 73 g , Kv = 1050 RPM / V ,
turning propellers in sizes from 9x6 to 10x4.7.
link to 2217-16
The battery is a 2200 mAh, 3s, 30C, weight = 200 g = 7.07 oz .
Old Nov 11, 2014, 05:20 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Is it really That heavy ???
gpw is offline Find More Posts by gpw
Old Nov 11, 2014, 05:46 AM
JureZ is online now
Sokol
JureZ's Avatar
Joined Jul 2013
yes it is , close to two pounds. built strong , plenty of strapping tape and packing tape.
actually survived many crashes and tree captures ...
in the end , wing loading is not that bad, I think
Maybe it is time to build a really lightweight version ... ?
for the record , I regularly fly for 15 mins, with a record of 30 mins one day when I just wanted to glide, and use the wind activity on my slope.
Old Nov 11, 2014, 07:08 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
JZ, just sayin’ , a Light version should be a real floater... just judging from similar projects built in the past ...
That really is Cool what you’ve done !!!
Old Nov 11, 2014, 10:03 AM
JureZ is online now
Sokol
JureZ's Avatar
Joined Jul 2013
thanks GPW ! I am honored by your comment
Old Nov 13, 2014, 03:00 PM
JureZ is online now
Sokol
JureZ's Avatar
Joined Jul 2013
Drawings
attached drawings
sketchup (version is 15.0.09350 , zipped ) , and png image
It is my first attempt at sketchup, some dimension values need to be rounded..
Old Nov 26, 2014, 07:36 AM
JureZ is online now
Sokol
JureZ's Avatar
Joined Jul 2013
Video
here is a new video , ground based , taken using the Mobius Hard-Hat-Cam : video
a bunch of close overhead passes for the camera !
two snapshots attached
Mini-HowTo HobbyKing X16 chuck glider to R/C EDF Jet Conversion! NitroCharged Micro EDF Jets and Power Systems 53 Apr 06, 2015 03:11 AM
Discussion Chuck gliders - I didn't think they would fly jww_289 Free Flight 47 Dec 21, 2014 08:51 AM
Discussion What is needed to Convert Concorde Chuck Glider into pusher model.. Concordefan Pusher Prop Jet Models 2 May 25, 2010 04:27 AM
Discussion high performance chuck gliders z999 Free Flight 7 Mar 06, 2010 09:06 PM
