Old Oct 09, 2012, 02:22 PM
wigedd is offline
Find More Posts by wigedd
wigedd's Avatar
United States, AZ, Mesa
Joined Jul 2012
Help!
Gear driven tail rotor slowdown with increase headspeed
Hi All,
Being new to this sport this may be a dumb question. I just completed a nice build of the Align 250 Pro and did a successful setup with a DX8 Transmitter. The problem I'm having is the gear driven tail rotor slows down to a stop when the main rotor head speed rises. The front drive gears and tail gears are ok. Do I have some kind of bearing problem?
wigedd is offline Find More Posts by wigedd
Old Oct 09, 2012, 02:55 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Turn the main rotor by hand in the direction it normally turns, while holding the tail. Look to see where it is slipping.
Roto Rob is offline Find More Posts by Roto Rob
Old Oct 09, 2012, 03:45 PM
wigedd is offline
wigedd's Avatar
Joined Jul 2012
The bottom gear in the front drive gear assembly meshes and turns with the main drive gear but the 45 degree gear on top does not when holding the tail. The confusing part is that this assembly was pre-assembled in the main frame and appears to be one molded shaft with two bearings. When not holing the tail all seems to rotate fine.
Old Oct 09, 2012, 04:25 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
Joined Jul 2007
Sounds like maybe the boom isn't pushed in all the way, OR one of your gears is slipping on the shaft - check the little metal attachments that grab the gears, and see if you can spin it on the shaft.
jasmine2501 is offline Find More Posts by jasmine2501
Help! Futaba GY-520 gyro with a steel wire driven tail rotor. RNAF Electric Heli Talk 21 Aug 09, 2012 02:44 PM
Discussion Align 450 belt or gear tail driven? bc3159 3D Electric Heli Flying 2 Jun 15, 2012 02:39 PM
Discussion Motor driven tail rotor spin the same as belt driven tail? BowerR64 Micro Helis 4 Mar 17, 2008 11:53 PM
T-Rex 450XL Tail rotor belt or gear driven?? rudyy Mini Helis 1 Dec 01, 2005 04:35 PM
Tail rotors - shaft driven versus seperate tail motor driven prop JohnM Micro Helis 2 Jun 10, 2004 12:15 PM
