Old Jun 21, 2012, 07:38 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Multirotor LED brackets
I whipped these LED brackets up for myself, but I thought others might be interested. There are four varieties, each holds 2 5mm LEDs at different angles depending on the bracket. I've put them up in sets of 4 and 6, which should cover most forms of multirotors.
http://www.shapeways.com/shops/wyvern
v1 - Two at 90 degrees to the arm
v2 - Two at 45 degrees to the arm
v3 - One at 90 degrees, one at 45 degrees to the arm.
Landing - one at 90, one at 0 (facing down)
-K
kad is offline Find More Posts by kad
Discussion Shaft bracket Purple // HobbyKing FlyingNiko Racing Boats - Electric 2 Jun 22, 2012 04:43 AM
Discussion Multirotor frame materials list signal15 Multirotor Talk 3 Jun 12, 2012 12:49 PM
Question Motor cross mount brackets Physics_Dude Multirotor Talk 3 Jun 11, 2012 01:50 PM
Sold Turnigy LED strips - 60 LED's, 1 Meter sgomes Aircraft - General - Miscellaneous (FS/W) 2 May 13, 2012 04:56 PM
For Sale T-Rex 500 LED tail blades and Main blade LED's. TMASTER Aircraft - Electric - Helis (FS/W) 2 May 08, 2012 06:30 PM
