Old Jan 22, 2002, 08:47 PM
new2heli is offline
Find More Posts by new2heli
santa clarita ca
Joined Jul 2000
wedgie upgrade
I'd like to get longer flight times on the wedgie.It seems fast enough with the speed 400 but if I put a Hacker 20 series brushless on it wont I get longer duration as well as saving a few ounces? How about the Astro 020? comments please
Tom
new2heli is offline Find More Posts by new2heli
Old Jan 23, 2002, 12:17 AM
Merrill Brady is offline
Find More Posts by Merrill Brady
Downey, S. CA
Joined Sep 2001
Longer Flight times
Try a stock speed 400 and go with 1050 Nim 8 cells sub A. Flight times are about 15-20 min. at full speed.
Merrill Brady is offline Find More Posts by Merrill Brady
Old Jan 23, 2002, 02:35 PM
new2heli is offline
santa clarita ca
Joined Jul 2000
merril,
wont the duration be even longer with a lighter more effecient hacker in it?
thanks,]
tom
Old Jan 23, 2002, 02:37 PM
blfinche is offline
Find More Posts by blfinche
Peachtree City, GA
Joined Aug 2000
You statement is generally correct. Brushless motors are generally lighter and more efficient, which leads to long flight times. I don't know about the particular motor. Talk to Sean at www.aero-model.com.
blfinche is offline Find More Posts by blfinche
Old Jan 23, 2002, 03:52 PM
HILDY is offline
Find More Posts by HILDY
Pennsylvania
Joined Dec 2001
Merrill- Where can I get those batteries? I would LOVE 15 - 20 min run times!
HILDY
HILDY is offline Find More Posts by HILDY
Old Jan 23, 2002, 04:43 PM
SchiessCo is offline
Find More Posts by SchiessCo
SchiessCo's Avatar
North Hills
Joined Nov 1999
Don't know if these are the ones that Merrill wrote about, but Diversity has 1000 mah NiMHs that are the same size as 600AE's. I've been using them as rx batteries in my sailplanes. They're good for up to 10 amps, so they ought work well for Speed 400 apps.
Pete
SchiessCo is offline Find More Posts by SchiessCo
Old Jan 24, 2002, 12:40 AM
Downey, S. CA
Joined Sep 2001
Batterys
I am working on getting some new batterys in to do some testing. I have some friends helping with them. I need to get the data together so stay tuned for the info.
Speed 400 draws 15A at full power.
Old Jan 24, 2002, 10:42 AM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
15 amps is only static though, on a slightly over-propped condition, like I use. 10 amps, in flight (or less), is pretty typical if you take run time & flight time, then calculate the amp draw from batt capacity. With very little throttle mgt, I think it would work well, but it would be nice if Steve Neu or somebody else in the battery "know" ran some controlled tests on some of these smaller, newer Nimh's.
Eddie P is offline Find More Posts by Eddie P
Old Jan 24, 2002, 05:00 PM
new2heli is offline
santa clarita ca
Joined Jul 2000
8 cells for the 1000 size nimh or 9 if you are planning to run the Astro 020 or Hacker brushless?
thanks, Tom
Old Jan 27, 2002, 08:59 AM
dr.E is offline
Find More Posts by dr.E
Don't cut the Yellow Wire
dr.E's Avatar
Ridgewood ,NJ
Joined Jan 2000
1005 3y on 7 500 ar's, 5x5 cam prop . over 100mph pitch speed !!
Cheaper alternative is a Rocket s400 motor
dr.E is offline Find More Posts by dr.E
Old Jan 27, 2002, 01:02 PM
keven64 is offline
Find More Posts by keven64
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
Dr. E,
I make it 96mph pitch speed at about 20500 rpm - for just over a minute - at full throttle ! ! !
Rocket400 motor, of which I have more than a few - for use with MFA gearboxes . . . these eat amps on direct drive - 15 Amps at almost 18,000 rpm with nearly two minutes ( at full throttle ) is about the same as the Aveox that you quoted, on 7 X 500AR's
Pitch speed in this case would be about 67mph.
7 X 600AE's fair little better with 'The Rocket'.
I'm going to make a new 30" wing for My Hacker B20-26L - able to use all my 7- and 8- cell packs of AE, and AR nicads !
Will be very fast, with 4+ minutes at full throttle.
My Motor is 14,700 rpm at 6 Amps with 7 X 500AR's - that's nearly 5 minutes at full throttle - with a more realistic 56mph pitch speed !
With 7 X 600AE's - almost the same performance - for nearly 6 minutes at full power !
With 8-cell packs . . .
Application of throttle in a dive might even slow it down !
I think I might have made a good choice with the Hacker; as always, time will tell !
Then there's the small copy of a German Nurflugel I'm planning on doing as well. . .
Where is that HWC ?
keven64 is offline Find More Posts by keven64
Old Jan 27, 2002, 07:50 PM
new2heli is offline
santa clarita ca
Joined Jul 2000
what about ihe nimh's???????
