Old Oct 09, 2015, 03:44 PM
BentProps is offline
Find More Posts by BentProps
Joined Sep 2015
Help with Tracing Plans
I just printed out a tiled plan for the nutball with a 19" wing.
I was tracing the rudder wing(I believe thats what its called) and I got to wondering how to trace onto the foam board the location of the control horn. On the plan its a line on the paper.
Should I just eyeball where to put the line? Any techniques?
BentProps is offline Find More Posts by BentProps
Old Oct 09, 2015, 05:25 PM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Eyeball works pretty well in this case ... It’s called TLAR (That looks about right ) ...
gpw is offline Find More Posts by gpw
Old Oct 09, 2015, 05:28 PM
ver2go is offline
Find More Posts by ver2go
Joined Dec 2012
Stick a pin through it.
ver2go is offline Find More Posts by ver2go
Old Oct 09, 2015, 05:38 PM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
Just glue the plans to the foam, in spots that are waste, cut through the plans. Save the parts
patterns for the next one or for repairs.
It's not like you spent a lot of $ on the plans, a bit of time putting them together.
This is built from a 3 view I found on line. Printed it to the size I wanted, 30" wing to
fit the foam board. Stuck it to the board and cut it out. From printer to plane was
just over an hour.
BHOFM is offline Find More Posts by BHOFM
Old Oct 10, 2015, 05:24 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
We still print out our plans on Index card stock ( thick paper for computers) then cut them out to make patterns.... That makes transferring shapes to foam very easy ...
Old Oct 10, 2015, 12:40 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
If you know and have CAD then you can trace the plans out IN CAD !
Then either plot out the plans as many times as you want or
cut them on a CNC machine.
birdofplay is offline Find More Posts by birdofplay
Old Oct 11, 2015, 01:22 AM
Bare is online now
Find More Posts by Bare
Canada
Joined Nov 2000
Plotter or printer.... One still gets a paper plan .
Glue stick the paper onto 'whatever' then cut parts out with a blade.
Fairly self evident.
Bare is online now Find More Posts by Bare
Old Oct 11, 2015, 02:09 AM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
Old Oct 11, 2015, 06:11 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Nice knife ... Fiskars ... I want one ...
Old Oct 11, 2015, 09:22 AM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
Some one posted about this thing some time back, I bought mine at Hobby
Lobby. They have a smaller one with a swivel blade, I got it as well, not
as useful as the larger one. I love the thing, very easy to be very actuate.
Just like using your finger to cut. And it does not roll off the table. Uses
regular #11 blades
the smaller one cuts half way through DS foam board.
Old Oct 11, 2015, 10:13 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Thanks !!! BHOFM
Found Legionair 140 plans or trace eissman Aircraft - Sailplanes (FS/W) 0 Jul 20, 2014 06:58 PM
Help! NEED HELP with TRACE OSD WIRING with Gopro Camera - Diagram Included v00d0o FPV Equipment 3 Mar 10, 2013 04:54 PM
Build Log Help with tracing picture in ACAD, JAS 39 Build marell01 Foamy EDFs 122 Mar 07, 2008 06:31 PM
Discussion Cheap way to trace plans GeoffinIN Scale Kit/Scratch Built 4 Aug 05, 2007 06:46 PM
FG plans: How Do I Trace? dstout Foamies (Kits) 3 May 22, 2004 05:14 PM
