Old Apr 29, 2015, 11:52 AM
rct is offline
rct
Find More Posts by rct
rct
rct's Avatar
ohio
Joined Apr 2003
re wing flutter
I was told this The Pegasus is a really nice pure floater but it does, IIRC, have a reputation for flutter at high speeds.
Cheers! thanks for the heads up Peter .
Q How to cure or help improve the wing from flutter with little weight increase ?
anyone ?
http://api.viglink.com/api/click?for...jales-arf.aspx
rct is offline Find More Posts by rct
Old Apr 29, 2015, 11:59 AM
rct is offline
rct
rct
rct's Avatar
ohio
Joined Apr 2003
Will try not to overspeed ....but sometimes it happens............
Old Apr 29, 2015, 12:26 PM
peterlngh is online now
Find More Posts by peterlngh
Joined Apr 2012
Hi again, rct. I'll add a link to a thread on the Pegasus.
I don't think that the flutter is a big problem and I have only seen one or two comments about it. I just wanted to mention it because in your original post you mentioned that you were looking for a wide speed range and the Pegasus is considered to be a "light lift, light wind" specialist. I haven't seen anyone suggest that one would want or need to beef up the structure. If you do get one and you do find that you want to increase the stiffness a bit then the lightest, simplest, and cheapest way is to simply use clear packing tape along the spar of the wings. I have even used diagonal pieces of tape to add washout to the wing of a foam ASW28.
http://www.rcgroups.com/forums/showt...pegasus&page=2
Cheers!
peterlngh is online now Find More Posts by peterlngh
Old Apr 29, 2015, 12:38 PM
Joined Apr 2012
BTW. Here's a link directly to the Topmodel cz site. Many of their gliders are available direct with a ARC (almost ready to cover) option. The shipping is expensive but if one picks a day when the exchange rates are favorable then it ends up being close to a push with a covered version from a U.S. distributor.
http://www.topmodelcz.cz/index.php?&...u_eshop_id=373
Cheers again!
Old Apr 29, 2015, 02:06 PM
rct is offline
rct
rct
rct's Avatar
ohio
Joined Apr 2003
re wing
thanks peter
I just found these motors look good for the money ?http://www.altitudehobbies.com/brush...equiv.-to-2217
Old Apr 29, 2015, 02:14 PM
Joined Apr 2012
I'm always happy to (try to) help!
I don't know anything about the Leopard motors but the Suppo motors, also available from altitude, have a lot of fans and I'm seriously considering trying one when I need another motor.
Cheers!
Old Apr 29, 2015, 03:26 PM
rct is offline
rct
rct
rct's Avatar
ohio
Joined Apr 2003
re motors
Iv'e used 3 of 4 sizes of the suppos and had good luck with .
rt
Discussion Re-use WLtoy heli 0.3mp camera as fixed wing cam(need advice) kevinmce Electric Plane Talk 1 Mar 06, 2015 08:58 AM
Build Log Flying wing flutter Marcio Flying Wings 7 Aug 14, 2014 07:25 PM
Discussion Flying wing - flutter problem Marcio High Performance 16 Aug 09, 2014 07:45 PM
Discussion Is the SS foam wing softer now?? Wing Flutters!! ToddL GWS (Grand Wing Servo) 46 Sep 29, 2006 09:39 PM
The 7' twin is dead.. flutter, flutter, flutter --- BANG! RIP lmopar69 Electric Plane Talk 11 Dec 11, 2005 09:12 AM
