Old Apr 26, 2015, 08:20 PM
winchdoc is offline
Find More Posts by winchdoc
Yes, ALL your money...
winchdoc's Avatar
A hut in the woods in Oregon
Joined Jan 2003
New Product
Oberadapter F3B turnaround upgrade kit
Over the past few years, I've been making some turnaround pulleys that seem to work really well.
After a trip to the GATOR WEST F3B contest, I got to see how the pulley are used, and get some good feedback from current F3Ber's about what they would like to see in turnarounds.
One thing I noticed is the "this end up" arrows on almost everyone's pulleys.
Other folks were asking for a 'chute stop built into the pulley.
Consensus is that the WinchDoc pulley does little or no damage to the line, and the line never slides on the pulley surface. It is snag-free and smooth running.
Folks were looking for a solution to mounting the WinchDoc pulley onto an Ober stake assembly.
Here is what I came up with. I only made a few for evaluation, but considering how I've been playing with it all evening, I think it will be a hit.
I only made a half dozen or so just to get them out there.
I can bring some to Cal Valley...
WinchDoc
winchdoc is offline Find More Posts by winchdoc
Old Apr 26, 2015, 08:45 PM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
Nice work
mlachow is offline Find More Posts by mlachow
Old Apr 26, 2015, 11:57 PM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
Looks good Doug!
Kiesling is online now Find More Posts by Kiesling
Old Apr 27, 2015, 10:15 AM
sailjester2811 is offline
Find More Posts by sailjester2811
Jody Miller
sailjester2811's Avatar
Orlando, Fl
Joined Jun 2009
Well that's how you do that!
Jody
sailjester2811 is offline Find More Posts by sailjester2811
Old Apr 27, 2015, 12:50 PM
Glauco is offline
Find More Posts by Glauco
Glauco's Avatar
United States, MO, Maryland Heights
Joined Jul 2002
Looks great Doug.
Just one observation on the chute stop. If you look at the first two pictures you just posted, our own made stops are closer to the pulley and also closer to the center.
When we use thin line like 1.02 with a 2 mm sleeve on the chute, if the stop isn't a couple of millimeters from the edges of the pulley, the chute will go through.
Also, if the stop isn't in the center, the line can rub on it if for example you are on a downwind launch going past the turnaround.
Glauco
Glauco is offline Find More Posts by Glauco
Old Apr 27, 2015, 01:19 PM
San Diego
Joined Aug 2004
I agree with Glauco - the stop needs to be closer to the pulley to guarantee it will stop the chute. It also should be biased to the bottom side of the pulley - actually below center.
The reason I know, is my first pulley has the stop about where Doug has this one and the chute can and does pull through sometimes. The line also can rub on it it. On my second pulley, I have the stop on the center, very close to the pulley. The chute can never pull through this one, but the line can rub on it during a downwind launch. Putting it 10 degrees down from horizontal is probably all it needs to keep the line from rubbing in just about all cases.
One of these days I'll get around to putting the stop in the right place. . .
Tom
Old Apr 27, 2015, 01:55 PM
winchdoc is offline
winchdoc's Avatar
Joined Jan 2003
Chute stops
Well good news/bad news-
Good news is that the modified pulley plates are done;
Bad news is the modified pulley plates are done... with the 'chute stop
where it is shown.
Next batch I run will have the 'chute stop in a better location.
Meanwhile, I have finished all the Oberadapters, they are really slick and rotate freely with the thrust bearing inside the block. I made these from some nice 2024 aluminum alloy- nicer material than good ol' 6061.. (but more expensive)
If you want just the Oberadapter, it's $95 shipped in CONUS
Adapter/pulley combo is $185.
WinchDoc
3 left...
Old Apr 27, 2015, 02:06 PM
San Diego
Joined Aug 2004
If you mount the pulley upside down, that will solve the rubbing problem.
A larger diameter spacer will put the stop closer to the pulley. Those two things should address the concerns mentioned above without having to put the hole in a different place.
Tom
Old Apr 27, 2015, 04:04 PM
winchdoc is offline
winchdoc's Avatar
Joined Jan 2003
REWORK 'chute stop & bonus
OK,
I think I understand where we want the 'chute stop.
Here is a shot of where I plan to put it.
I'll set up this operation again and re- drill & tap the stop in the new location.
Plus, in the limited time I have these on the machine, I will be able to offer free custom text
on your pulley IF YOU LET ME KNOW RIGHT AWAY, I'll put your name on it.
(talkin' to YOU, Michael & Kyle)
WinchDoc
Funny the AMA folks still insist on being able to pull the entire 'chute, and other hardware thru the turnaround.
Old Apr 27, 2015, 04:27 PM
San Diego
Joined Aug 2004
Looks good to me Doug!
Tom
Old Apr 28, 2015, 02:58 AM
Avaldes is offline
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
GREAT work Doug! Good job understanding our requirements and making mods to your pulley! If I had the cash I would be in for some parts too. Hopefully you will get enough interest to do another run at a later time
Perhaps we should talk offline about figuring out an adapter for the Swede-pulley too. I really love your large diameter/low friction wheel. MUCH nicer on the line.
Avaldes is offline Find More Posts by Avaldes
Old Apr 28, 2015, 03:40 AM
San Diego
Joined Aug 2004
With just one more part for a linear bearing plus a stake, there would be enough for a stand alone turn around. I really like the linear bearing in my turnaround. It never gets stuck in the up position like I see happen with turnarounds that use a bushing. . .
Tom
Old Apr 28, 2015, 12:45 PM
Glauco is offline
Glauco's Avatar
Joined Jul 2002
Doug, for F3B the chute stop is part of the rules, not a personal requirement.
The intent is to avoid the line to come through the turnaround and lay over other team lines impeding launches and so delaying the contest.
Glauco
Old May 07, 2015, 11:04 AM
Mr. Kite is online now
Find More Posts by Mr. Kite
May the Wind Always be Good
Webster, Minnesota
Joined Feb 2007
Funny the AMA folks still insist on being able to pull the entire 'chute, and other hardware thru the turnaround. Just a note that the only Super Chutes that I have got back is where some one has pulled it thought the turn around ..Chutes are not meant for that ...Love your turn around pulley's...Keep Up the good work ...
Mr. Kite is online now Find More Posts by Mr. Kite
Sold Winch Doctor F3B/F3J Turnaround Pulley Black New (reduced) LetsSoarXC Aircraft - Sailplanes (FS/W) 5 Jun 23, 2014 08:44 PM
Sold F3b-F3J turnaround pulleys winchdoc Aircraft - Sailplanes (FS/W) 4 Jun 26, 2007 09:18 AM
For Sale F3B winch and turnaround tomv36 Aircraft - Sailplanes (FS/W) 0 Mar 26, 2007 06:27 PM
For Sale F3B winch and turnaround tomv36 Aircraft - Sailplanes (FS/W) 0 Jun 14, 2006 05:55 AM
Sold F3B Winch with Turnaround GoFaster Aircraft - Sailplanes (FS/W) 3 May 03, 2006 07:00 PM
