Old Feb 18, 2004, 06:11 AM
pdemon is offline
Find More Posts by pdemon
The simplest, the better!
pdemon's Avatar
Italy, Europe
Joined Apr 2002
First under 100 grams!
Just want to share with you my first under 100 grams plane, and it flies well too! The goal was max 50 cm wingspan, easy to build, cheap, use of standard micro gear and cdrom unmodified motor. After two hours work here it is: the Slowfish! Why? It is slow and I usually fly this kind of model at the beach 50 metres from my house, so ...fish , hoping not to meet the sea with the model!
The powerhouse is a 16x CDRom motor with standard windings and the specs are: 1 amp consumption with two lipoly 145 Kokam, Gunther prop spinning 5900 rpm, all up weight 91 grams .
Pdemon
pdemon is offline Find More Posts by pdemon
Old Feb 18, 2004, 06:26 AM
bleriot 11 is offline
Find More Posts by bleriot 11
Cannes Mandelieu, France
Joined Jun 2003
is this thread only for bmw bikers?
very cool plane.maybe you can call it the gull!
patrick.
bleriot 11 is offline Find More Posts by bleriot 11
Old Feb 18, 2004, 07:58 AM
pdemon is offline
pdemon's Avatar
Italy, Europe
Joined Apr 2002
no, it's for all the bikers
here is a nose detail...
prop simply pressed on the shaft with the aid of some heat shrinking tubing, at this power level it is enough: 8watt
Discussion First camera for under $100, any suggestions? Munkey Aerial Photography 3 Mar 23, 2006 11:19 AM
Best Digital Camera under $100 KatanaGuy Electric Plane Talk 12 Aug 10, 2002 01:26 PM
Best charger under $100 Viper Pilot Electric Plane Talk 10 Jul 19, 2002 01:20 PM
Best Blushless motor for under $100? Mike Hall Electric Plane Talk 9 Jul 04, 2002 01:08 PM
Best charger for under $100??? deadcell Power Systems 8 May 28, 2001 01:18 AM
