Old Jan 28, 2013, 04:35 PM
torg12 is offline
Find More Posts by torg12
United States, NM, Albuquerque
Joined Jan 2013
Eflight Taylorcraft 450 arf - motor choices
Hi,
What are some alternative motor choices for the E-flite's Park 450 BL Outrunner Motor?
Will a Hacker A20-22L give similar flight performance? I'm looking for similar power & torque - just a better motor.
Thanks very much
torg12 is offline Find More Posts by torg12
Old Jan 28, 2013, 10:24 PM
haliotis is offline
Find More Posts by haliotis
United States, CA, Santa Monica
Joined Jul 2006
I had an e-flite 480 (1020 KV). Great motor, far better for this aircraft than the 450.
I had around 400 flights on mine when I finally sold it. The motor was as strong as it was when new.
haliotis is offline Find More Posts by haliotis
Old Jan 29, 2013, 12:52 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I have installed a Scorpion 3008-32 ( similar to E-Flite 480) in a hand-me-down E-Flite P-47 that was all the rage a couple of years ago. It had an E-Flite brushed geared motor which was just adequate as I recall. I also made the rudder functional. May change to a steerable tail wheel linked to the rudder. These foamies are something fun to fly while working on built up scale models.
E-Challenged is offline Find More Posts by E-Challenged
Old Jan 29, 2013, 01:07 PM
BEA flyer is offline
Find More Posts by BEA flyer
Concord, MA
Joined Jun 2002
this motor is a little bigger but very powerful
http://www.hobbyking.com/hobbycity/s...idproduct=2127
I had this in a glider (2 meter and a little over 3 lbs) with a folding 9 X 4.5 prop. I think 250 watts (but not continuous) on 3 cells and I have the higher Kv one, 1370 Kv.
There is another KD motor a little smaller in diameter, that may be more sized right.
I will try and find it. Exceed motors are OK too, but if you have to have the top shelf stuff, look at AXI's too.
It is maybe a half ounce lighter and about 1000 Kv.
BEA flyer is offline Find More Posts by BEA flyer
Old Jan 29, 2013, 01:17 PM
Concord, MA
Joined Jun 2002
They also have a 20mm long and a 10 mm long version the same diameter.
I have the 22 20 and it pulls my Acrocub which is 43" and about 26 oz around pretty well on a 3 cell battery.
These are all on backorder however.
Old Jan 29, 2013, 01:19 PM
Concord, MA
Joined Jun 2002
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
I cut and pasted wrong URL in the above post.
Old Feb 01, 2013, 06:15 PM
torg12 is offline
Joined Jan 2013
Thanks for the input
Old Feb 01, 2013, 11:12 PM
FrankSteffens is online now
Find More Posts by FrankSteffens
United States, NY, Ronkonkoma
Joined Jun 2012
I fly mine with the Eflite 480 1020Kv motor, 40A Lite Pro ESC and an 11x5.5 APC prop and am very pleased... its actually my favorite plane to fly. It moves along pretty nicely, and can perform some nice aerobatics with this setup. I have flown it with an APC 12x6 prop, and it still performed well, but I got a few prop strikes while doing touch and go's, particularly if a previous touch was not too stellar and bowed out the landing gear a little. I haven't had that problem since using the 11x5.5 (not just because it gave me more clearance, but my landings got better lol).
If you're still building it, you may want to wick in some CA in the motor box/firewall area....my only gripe about the plane stems from that area getting a little loose. I have read here and on other sites that I wasn't the only one to have this (albeit small) issue.
My favorite part about flying it is going to the approach end of the runway, lifting up the tail, and slowly gaining speed, finally lifting off almost at the departure end of the runway, doing a pattern, and touching down on the runway threshold and riding the mains for as much of the runway as possible and lifting off again.
I really love this plane... and hope you will also.
FrankSteffens is online now Find More Posts by FrankSteffens
Old Feb 15, 2013, 04:17 PM
torg12 is offline
Joined Jan 2013
Thanks for the tips - yall got some nice folk in here!
Old Feb 15, 2013, 08:38 PM
Joined Jun 2012
No prob! Its really a great plane... you're going to love it!
Old May 16, 2015, 05:18 PM
jobinseattle is offline
Find More Posts by jobinseattle
They call me "Crash"
jobinseattle's Avatar
Joined Nov 2014
Would this setup work for the Taylorcraft 450 ARF?
Motor: http://www.hobbyking.com/hobbyking/s...arehouse_.html
ESC: http://www.hobbyking.com/hobbyking/s...arehouse_.html
jobinseattle is offline Find More Posts by jobinseattle
Old May 22, 2015, 01:06 PM
WI53072 is offline
Find More Posts by WI53072
United States, WI, Pewaukee
Joined May 2006
I run the Eflite Park 480 in mine with a Xoar 10-6 prop. I flies really nice. I skipped the wheel pants and put on a slightly larger diameter wheel 2.25" i think. Love this plane!
WI53072 is offline Find More Posts by WI53072
Discussion alfa Ta 183 Huckbein pattern14 Electric Ducted Fan Jet Talk 38 Mar 17, 2013 01:00 PM
Sold Alfa models ta 183 huckebein arf (SOLD PENDING FUNDS) pilotorc4 Aircraft - Electric - Jets (FS/W) 5 Jan 04, 2013 05:05 PM
Wanted WTT or WTB Tamiya TT-01, TA-04, TA-05 Sprint 2 Drift, TT-01E, TT-01 Drift speedkingrc Cars - Cars and Parts (FS/W) 7 Feb 11, 2011 08:51 PM
Patton mini TA 152 electric? jasonstach Power Systems 7 Dec 04, 2001 01:26 AM
Is tA webpage for wing covering instruction( balsa frame ) ? Feodosia Flyer Beginner Training Area (Aircraft-Electric) 1 Jul 09, 2001 04:17 PM
