Old Jan 02, 2013, 09:08 PM
sceadwe is offline
Find More Posts by sceadwe
Joined Dec 2012
Brushless Motor not drawing rated amperage?
So I am part of my college's ROV team and in charge of the propulsion team. We are testing a brushless motor system for our ROV.
Today we finally got some propellers (Traxxas 4mm shaft RC Boat Props) however in our initial tests today in water the motors are drawing only about 2.5A-3A at max throttle in water which is far short of the rated 14A continuous draw in air? Maybe I am missing something but we are using E-Flite Park 450 rated with 80A-HV Seaking ESCs.
I'm not sure why they seem to be under powered but my intuition says that it's the smallish size of our props.
I am interested in hearing what any of you on here have to suggest on getting better performance out of our brushless system.
sceadwe is offline Find More Posts by sceadwe
Old Jan 03, 2013, 08:21 PM
nick_75au is online now
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Basically the load determines the amp draw, not the nameplate ratings, all my boat brushless setups draw less than the nameplate ratings and I set them up deliberately that way so additional cooling (usually provided by airflow from the air prop) is not required, enclosed hull provides no airflow.
Two ways to improve the thrust, either change the props to larger ones or increase the voltage, check out my blog for an article on sizing motors and props,
cheers
Nick
nick_75au is online now Find More Posts by nick_75au
Discussion Battery C rating/ Esc AMP draw. rene21 Electric Power Cars 39 Dec 05, 2015 07:06 PM
Discussion No Amperage rating for Neu motors? NoFlyZone Power Systems 8 Oct 11, 2007 08:04 PM
Volz servo not drawing sufficient amperage. ferradas Electric Plane Talk 4 Dec 19, 2003 12:56 PM
Do heatsinks allow you to run a (brushless) motor above its' rated amperage? headless Power Systems 4 Nov 25, 2003 06:48 PM
Amperage draw of and 010 in a Switchblade Jim McPherson High Performance 12 Sep 18, 2001 05:34 PM
