Old Dec 14, 2012, 01:08 AM
FliegenFrosch is offline
Find More Posts by FliegenFrosch
FliegenFrosch's Avatar
United States
Joined May 2012
Question
Lightwieght covering film for hinges?
I'm almost ready to cover my Alien Aircraft Stearman kit and wondering if lightweight covering such as Microlite or Parklite can be used for hinging control surfaces the way Monocote is used on heavier planes. I've used various types of tape such as Scotch Magic Tape and packing tape on foamies with good results, but since the lite covering material is so much thinner, will it hold up over time?
Thanks in advance for any advice.
Alan
FliegenFrosch is offline Find More Posts by FliegenFrosch
Old Dec 14, 2012, 08:47 AM
epoxyearl is offline
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I think it's proprtionately about the same strength...I assume you're covering both sides....lay the moveable surface 180 deg on the mating area, install the 'hinge' then fold over and do the other side....should be fine,better if electric,with less vibration.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: My "Take" on the AMA
Old Dec 14, 2012, 11:40 AM
machinate is offline
Find More Posts by machinate
machinate's Avatar
Joined Jan 2010
The covering will be plenty strong; it's super flexible and the loads are distributed over a wide area. I would be worried about adhesion, though. Microlite doesn't stick all that tenaciously, in my experience, and I would be worried about it peeling up after a bit of use.
machinate is offline Find More Posts by machinate
Old Dec 16, 2012, 02:47 AM
United States
Joined May 2012
Thanks for the info. I had guessed that the film is plenty strong but if it doesn't permanently stick to balsa, then that causes me some concern for using it as hinges. But of course, I always have the option of using Scotch Magic Tape or packaging tape as I have used on foamie planes for several years with no problems. Wouldn't use those tapes directly on balsa but it adheres to covering]
very well.
One last option would be to just cut slots and use nylon or CA hinges.
Old Dec 16, 2012, 07:45 PM
Randy G is offline
Find More Posts by Randy G
Randy G's Avatar
Kirkland, WA USA
Joined Mar 2001
I have used floppy disks and cut them directly into the aileron and the plane wings and a little CA for it. Works great.
Randy G is offline Find More Posts by Randy G
Old Dec 19, 2012, 12:51 AM
United States
Joined May 2012
Randy, when you say "cut them directly into the aileron and the plane wings", does that mean cutting slots and inserting floppy disk material? The reason I want to use covering film or tape is that the tail planes are made of 1/8" balsa and the last time I tried slotting in thin balsa, I ended up with blood all over a previously perfect airframe. Thanks for the tip.
Alan
Old Dec 19, 2012, 01:25 AM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
> Microlite doesn't stick all that tenaciously...
Strange how different people's experiences can be. I used it on my last two models and found it to stick very tenaciously to both balsa and itself.
With my Martian Spaceship, http://www.rcgroups.com/forums/showp...2&postcount=15 I carry the model, and launch it, by holding onto the front "fin", which is a piece of 2.5mm depron glued on edge to a 1/8" balsa stringer, with two layers of Microlite in between. Still rock solid after dozens of flights and a lot of not-too-gentle handling.
On my Dandy, http://www.rcgroups.com/forums/showp...8&postcount=22 I used it for hinging the rudder and elevator, and it also worked perfectly in that application. The Dandy is a very small model, but I'll be using the same system on a much larger one I'm building at the moment.
Maybe different colors behave differently. I've used only silver and dark blue.
But bascally, I'm very happy with the material and will use it again wherever I can.
Harry D is offline Find More Posts by Harry D
Idea EPP flying wing (covering film for washout) rayonnair Foamies (Scratchbuilt) 5 Mar 30, 2014 04:35 AM
Idea simple safe solution to clean or maintain both foam and film covering Warbirds Smoothcruizer3 Electric Warbirds 0 Apr 20, 2012 09:44 AM
Discussion Looking for opinions on foam covering films rcnutt Foamies (Scratchbuilt) 10 Mar 14, 2012 08:13 PM
Discussion More questions on hinge tape - tape over film covering? Mike-O Sailplane Talk 7 Sep 02, 2010 12:09 AM
For Sale X-ray film, great for edf ducting, hinges, etc. Ebolavoodoo Aircraft - General - Miscellaneous (FS/W) 41 May 23, 2007 02:39 AM
