Old Dec 06, 2012, 01:03 PM
Enrique K. is offline
Find More Posts by Enrique K.
Enrique K.'s Avatar
Montevideo, Uruguay
Joined Apr 2006
Question
Cogging of motor
After dozens of flights, my Boom fell into river water. When I picked it up the ESC -a Jeti Advance Pro 18A- gave up smoke -dead. I dried the RC gear and the engine -an AXI 2212/26- and waited a few days to make sure everything was dry.
Bought a cheap Chinese 30A ESC, tried radio gear, tried engine, everything worked -engine made no particular noise, so I believe no magnet is loose-, went flying.
Flew for 7 minutes, landed, noticed that engine had quite a bit of cogging. Did not think much of it, flew it again. After a couple of minutes, engine stops, model more or less glides to the ground. I notice an enormous amount of cogging. A few minutes pass, I test it again, cogging gone!
What is happening?
There is one thing that might be important. The motor mount is not as firm as it used to be. After the second engine failure I noticed there was a crack in the foam, so maybe the engine experiences a lot of vibration.
Thank you!
Enrique K. is offline Find More Posts by Enrique K.
Old Dec 06, 2012, 03:34 PM
Ron H is online now
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Sounds to me like a magnet came loose. You might want to open it up and have a look.
Ron H is online now Find More Posts by Ron H
Old Dec 06, 2012, 04:03 PM
modisc is offline
Find More Posts by modisc
Inspiration
modisc's Avatar
United States, MI, Ann Arbor
Joined Aug 2011
What is happening?
Thank you!
There are a few scenarios for cogging becoming stronger than before.
1, stator is not well centered due to crash or other type of impact on the shaft, resulting in the air-gap in certain region becoming smaller.
2, There is a short somewhere in the coils. If you connect 2 of the 3 wires together, the cogging will be stronger; if all 3 wires are connected, the cogging will be even stronger. but rathan than describing the cogging becoming stronger, it is more like a resistive feeling.
You can do a no-load test on the motor, and measure the no-load current at certain voltage, and compare it with the factory nominals.
modisc is offline Find More Posts by modisc
Old Dec 07, 2012, 12:27 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Some ESC leave the brake on after powering down, until all the residual voltage bleeds off in the ESC. Disconnect the ESC from the motor next time you try.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Dec 07, 2012, 04:41 PM
Enrique K.'s Avatar
Montevideo, Uruguay
Joined Apr 2006
Thank you all!
Before opening up the engine -as suggested by Ron-, I tried the easier stuff suggested by Modisc. Results:
1. There was no appreciable increase or reduction of cogging neither with two nor three leads conencted. I used a screwdriver and connected first two leads and then three to make sure connection was good. I guess this is good.
2. With the prop off but still leaving the prop holder on, I got a current consumption of between 0.65 to 0.72 Amps at 12.36 to 12.41 volts. The motor specs say it sould be 0.45 at 10 volts, I don't know what this means: Should the current increase with voltage? Could the prop holder be the cause for the higher current? Is this increase significant?
Should I proceed to open up the engine?
Thanks!
Old Dec 07, 2012, 11:05 PM
Enrique K.'s Avatar
Montevideo, Uruguay
Joined Apr 2006
I repaired the cracks near the firewall and installed some reinforcements around it. I then test ran the motor again to see what happened.
Again with no prop, the amperage was 0.65 very stable (not as in the previous test).
I then put the watt meter away and ran the engine more or less as if I were actually flying the plane -throttle usually around the center and sometimes going WOT. After repeated stops to check, no cogging at all -even with the ESC still connected.
But then I noticed the engine became hot (probably some 50C or 122F). I could still keep my fingers on it , but I believe if I ran it one minute longer I would probably not have been able to. Approximately half of the 1300 mAh were consumed when I stopped the test.
I have never run the engine on the ground for so long until today, so I do not know if this is normal.
Ambient temperature was 24C - some 75F.
Can this help with the diagnosis?
Ron, as you can see, I am trying to delay opening up the engine at all costs -I have never done it and don't know what awaits me!
Old Dec 08, 2012, 03:29 AM
modisc is offline
Inspiration
modisc's Avatar
Joined Aug 2011
Your no-load current looks normal. And the motor getting hot after no-load full throttle run (nominal voltage) is also normal. Is your motor an outrunner? 50 degree C is a little bit too hot for the rotor of an outrunner after 1-min no-load full throttle test run at nominal voltage.
A normal 3 phase brushless motor, if you short 2 leads or all 3 leads, you should be able to feel noticable increasing resistance when you turn the shaft by hand.
Old Dec 08, 2012, 08:13 AM
Enrique K.'s Avatar
Montevideo, Uruguay
Joined Apr 2006
I am sorry for not having been clear. I was running the engine with an APC 10*3.8 slow fly prop. And I must have been running the motor for at least five minutes before I noticed the increased temperature.
Yes, the motor is an outrunner. See http://www.modelmotors.cz/index.php?...e=26&line=GOLD
Old Dec 08, 2012, 09:46 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
A 10x3.8 APC SF on 3s takes an Axi 2212/26 beyond its rated maximum... it is rated for 10A-12A max and you are running it at ~14.75A/160W.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Dec 08, 2012, 10:10 AM
Enrique K.'s Avatar
Montevideo, Uruguay
Joined Apr 2006
Yes, you are right! But in the link above, the manufacturer offers an example of a 3D use with a model weight of 450 grams or one pound -exactly what my Boom weighs- using 3S and a 10 x 3.8 prop.
I usually fly around mid-stick and only go WOT when climbing for loops or wingovers, which never takes more than 5 seconds. It has worked so far flawlessly, through summer and winter, for over two years.
Maybe you are right and I should prop down to 9 x 3.8 or 4.7...
Do yu believe ambient heat -which was around 28/30C -83/86F- could have had something to do with the recent motor failures?
Old Dec 08, 2012, 10:49 AM
lectroglide is offline
Find More Posts by lectroglide
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
yes , heat can do some bad things to anything rotating, if you dont have a wattmeter get one soon. also some maunfactures give faulty info on their stuff which is more reason to have a wattmeter
lectroglide is offline Find More Posts by lectroglide
Old Dec 08, 2012, 11:17 AM
Enrique K.'s Avatar
Montevideo, Uruguay
Joined Apr 2006
I do have a wattmeter and I just measured current... Dr. Kiwi is right, I am scratching 15 Amps with that prop! Stepping down to 9" diameter! What a dumbhead, I didn't use the wattmeter with this motor!
Thanks for your advice.
Discussion Sensored motor cogging with Vxl-3s Munkey On-road Cars 6 Dec 08, 2012 06:33 AM
Question Motor cogging Zerts Electric Motor Design and Construction 6 Aug 08, 2012 12:54 PM
Discussion Cog removal brushed motor ballores Electric Motor Design and Construction 2 Apr 11, 2012 03:09 PM
I have a motor with a brass cog on the end/How do i remove the cog and replace it? mortonj69 Power Systems 25 Mar 24, 2003 07:07 AM
Cogging action in motor dshly Parkflyers 1 Oct 30, 2001 11:59 AM
