Old Apr 19, 2013, 10:12 AM
TNug is online now
Find More Posts by TNug
Waypoint Collector
TNug's Avatar
United States, NC, Raleigh
Joined Feb 2012
Originally Posted by Radio.Active View Post
FLD-02 does not have the SD chip the best I can tell from the HK pictures and documentation.
Confirmed. I have one on my 9x/Er9x with FrSky DJT module. No SD card - display only.
Had I recognized the logging capability potential with the DHT-U, I would have gone that route instead.
TNug is online now Find More Posts by TNug
Old May 02, 2013, 11:26 AM
Varicopax is offline
Find More Posts by Varicopax
Hungary Hajduszoboszlo
Joined Jul 2008
Hi,
My second competition season just started, I finished my first 2 competition.
I am satisfied . 2 weeks ago F5J Intertour at Szeged Hungary i finished 4th place and also at F5J-400 category also 4th place.
Last week Budapest Cup I finish second place at F5J-400 category.
BR
Tamas
Varicopax is offline Find More Posts by Varicopax
Old May 02, 2013, 11:49 AM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old Sep 10, 2013, 11:16 AM
Joined Jul 2008
Topic not too active, continue my previous post.
I finished the competition season and had several 2nd positions with the T9X.
I got lucky and won the Hungarian National championship in F5J-400-Alti category too.
I am proud
https://picasaweb.google.com/1143381...seg_Kupa_2013#
Old Sep 10, 2013, 12:14 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Congratulations!
But wait, how could you be a national champion? You are flying a cheap radio! Don't you need an expensive radio to win big contests?
You posted a switch map and set-up file back in February. Have there been any updates/improvements?
Still using Open9X?
Still using FrSky?
aeajr is offline Find More Posts by aeajr
Old Sep 14, 2013, 03:41 PM
ScottSails is online now
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
No competition winner here - just someone having fun with this transmitter (with Open TX) for 3 seasons now.
This transmitter saved my plane a few weeks ago. On my second flight, I lost my rudder control (servo) in my RESM ALES plane. Normally, this would be time to pick up pieces flying only elevator and motor (I do know someone whom landed fine in the past successfully but I am not that skilled). Anyway, I use independent servos for spoilers and had previously set them us as spoilerons (not even sure if that is real name but you get the idea). I landed it at my feed and plane was saved. I am not sure what other transmitters or systems (Aurora, Futaba, Airtronics) have the programming flexibility to even do something like this...
Of course the other feature I swear by due to FrSky is the RSSI - which I consider to be a safety feature - it really is good knowing that your receiver is seeing a strong signal from your transmitter when flying way out "there". Flying without this seems like flying with the assumption that I am in control. Nothing like hitting a strong turbulent section of air and KNOWING that it is not the plane or radio but in fact the air.
Scott
ScottSails is online now Find More Posts by ScottSails
Old Sep 15, 2013, 02:32 PM
Joined Jul 2008
Hi,
Thank you.
I decided to not change my mapping and version during the season. I had some bad experience with it. Lost my expos and curves one time, almost I have to set up my plane again 2 days before competition day.
I plan to update to the latest opentx and want to try 2 features, one is the snap flap and the second is the throttle on startup then crow for the rest of flight.
One improvement to my radio/thermal flying is to add an old 35Mhz antenna(just ducktape it) and monitoring the windshifts during flight and before start.
If somebody knows how can officially put back 35MHz antenna, dont hold it back, I think for thermalling is must have.
https://picasaweb.google.com/1143381...34438703549682
Thats me watching/waitng for windshift before start.
Thank you
Tamas
Originally Posted by aeajr View Post
Congratulations!
Still using Open9X?
Still using FrSky?
Old Oct 28, 2013, 08:33 PM
GarryOgilvie is online now
Find More Posts by GarryOgilvie
Professional sink locator
United States, NC, Greenville
Joined Dec 2012
Guys'
I'm near completion of a full house ALES sailplane and would like some suggestions and help with programing my 9X flashed Turnigy TX.
I'll be using the FrSky module and the 8 channel RX. I have the Smartie Parts board installed and eepe loaded in my pc.
I'm quite new at this programing stuff so please be patient with me if I need a lot of hand holding as I go through this.
My plane has the standard rudder, elevator, ailerons and flaps. I would like to have the motor on the throttle switch, not on the throttle stick.
Thank you in advanced for your help,
Garry
GarryOgilvie is online now Find More Posts by GarryOgilvie
Old Oct 29, 2013, 04:58 AM
Joined Jul 2008
Hi,
I use the trainer switch for the motor and pot2 to control the throttle, 99% its full, but when you need to test then its handy.
Here is my throttle settings
On your channel in the mixes page set
-100% MAX
-100% P2 Switch(TRN)
Be aware it can be +/-100% settings depending your ESC throttle sensing!!!!!!!
Try it carefully it may turn on with full throttle, better to check it first which is your null throttle settings.
BR
Tamas
Old Oct 29, 2013, 10:08 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Best to play with throttle mixes with the prop removed.
Old Oct 29, 2013, 10:20 AM
Joined Dec 2012
Right now I'm not using the motor battery since I'm just doing the initial set up.
Once I get a template or my programing closer I'll attach the motor battery and make sure that things work the way they need to without a prop on the motor.
Anyone have any good templates out there?
Old Oct 29, 2013, 04:27 PM
Thoren is offline
Find More Posts by Thoren
Closed Account
Joined Jun 2013
Thoren is offline Find More Posts by Thoren
Old Aug 15, 2014, 01:06 AM
EddieFC02 is offline
Find More Posts by EddieFC02
Canada, BC, Richmond
Joined May 2014
Calypso Glider
I am fairly newbie to the rc hobby but I love it. I am using the Turnigy 9x for my Flyzone Calypso electric sailplane. Question. What expo rates do you recommend for someone beginner to intermediate on the turnigy 9x?
EddieFC02 is offline Find More Posts by EddieFC02
Old Aug 15, 2014, 03:27 AM
SpeedsterDEN is offline
Find More Posts by SpeedsterDEN
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
I use 40% on elevator and rudder and 50 % on ailerons on new planes on my Spektrum.
When I was using the 9x I felt I should go 5% up with the )x compared to the Spektrum to give the same feeling.
But I would say around 50 % would give a good feeling with the plane.
(For me at least)
Cheers
Soren
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Old Aug 15, 2014, 06:59 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Expo is a very individual thing. There is no need to use expo at all.
I never put expo on rudder for gliders. If I use it at all it is on elevator and ailerons only.
Some may only use expo in thermal settings.
I have a friend who uses reverse expo which makes his glider more responsive.
Just because your radio has a feature does not mean you should use it. It is there to solve a problem or enhance control, but only if you need it.
Discussion Turnigy 9X - for sailplanes? aeajr Radios 19 Mar 05, 2012 10:43 PM
Help! Turnigy 9X Full throttle really full throttle? Kamu Radios 3 Dec 28, 2010 04:35 AM
Discussion Anyone flying Aurora 9 with full house ship? 12ten Sailplane Talk 208 Jun 18, 2010 07:50 AM
Discussion Opinions on best 7-ch 2.4 GHz radio for full-house sailplanes Forest Flyer Sailplane Talk 29 Oct 12, 2008 10:10 PM
anyone flying full house photon II ? wing warrior Hand Launch 3 May 01, 2005 12:31 PM
