Old Aug 28, 2015, 07:59 PM
tewatson is offline
Find More Posts by tewatson
Riddle me this...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
Originally Posted by FlyingGorilla83 View Post
Xplorers come with control rods, The Maxa does too... this is why they have threaded ends...
FWIW...I never use what is supplied with the models anyway (the one exception sometimes being threaded fuse pushrod couplers). They usually provide incorrect linkage lengths to boot.
Cutting some carbon rod to the precise length needed and attaching clevises is not hard. This is WRT conventional linkages...if we're talking LDS or something exotic, then the mfr should of course provide something.
Tom
tewatson is offline Find More Posts by tewatson
Old Aug 28, 2015, 08:14 PM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
I've built Supras and Xplorers. Never used the supplied rods or supplied wiring for the Supras. Most of the time I succeed in getting the servo installed with a horn that stays below the surface of the wing so I can replace any bubble covers with flat covers.
The wiring on the Perfection is pretty nice. I actually used it.
mlachow is offline Find More Posts by mlachow
Old Sep 02, 2015, 04:44 AM
Hoot is offline
Find More Posts by Hoot
United States, TX, Houston
Joined May 2003
Is there a video showing how the lds system works? The pushrod connection on the control surface looks like it has almost no moment arm which would require a powerful servo and and a really strong hinge line.
Hoot is offline Find More Posts by Hoot
Old Oct 22, 2015, 03:43 AM
DrFragnasty is offline
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
Glider Gear | Perfection CNC Horns
FYI
Greg Potter in Adelaide Sth. Australia is making replacement cnc horns.
http://www.glidergear.com.au/
DrFragnasty is offline Find More Posts by DrFragnasty
Old Feb 21, 2016, 11:56 PM
F3B Fly Faster is offline
Find More Posts by F3B Fly Faster
Joined Jul 2008
I'm flying the V tail version.
Has anyone had the V tails fail with creases.
2 models both V tails both creased.
F3B Fly Faster is offline Find More Posts by F3B Fly Faster
Old Feb 22, 2016, 01:15 AM
ak79 is online now
Find More Posts by ak79
Flightcomp.com
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
I fly a V-tail Perfection. No problems yet. Got photos?
ak79 is online now Find More Posts by ak79
Site Sponsor
Old Feb 22, 2016, 03:18 AM
mlachow is offline
Joined Oct 2005
Bottom of one tail side just where some internal spar ends. I don't know if it was flight or transportation damage that started it.
Repaired with a layer of carboweave.
Old Feb 22, 2016, 05:33 AM
Alex Hoekstra is offline
Find More Posts by Alex Hoekstra
Alex Hoekstra's Avatar
Hurdegaryp Netherlands
Joined Feb 2007
Very likely the builder did a spar from carbon tow running directly from one half to the other. When the epoxy cures in a temper box the carbonfibre shrinks a bit and that shows in the corner where it come loose from the skin and might show a small crease. There are 2 ways to overcome this problem. Or let the epoxy cure at room temp. and do the tempering after. Or make the spar from 2 separate tows that just overlap in the middle.
Alex Hoekstra is offline Find More Posts by Alex Hoekstra
Old Feb 22, 2016, 01:37 PM
Joined Jul 2008
Both sets that have failed have been the left hand side tail 1/2 inch past the joiner box.
The first model is brand new with only 6 flights when the crease appeared. the 2nd model probably had about 20 flights.
AK79 If I took photos they wouldn't do justice to see the problem as I have cut 2 hatches in the bottoms and placed carbon tows inside. A messy job as I want to keep flying.
Alex the spa in the tails are what looks like foam wrapped in a carbon twine like a spider web. there is very little strength there.
Old Feb 22, 2016, 04:41 PM
ak79 is online now
Flightcomp.com
ak79's Avatar
Joined Apr 2006
Hmmm, I'm going to have a close look at mine when I get home and report back. Maybe there is something there and I just never noticed it.
Site Sponsor
Old Feb 22, 2016, 08:17 PM
mlachow is offline
Joined Oct 2005
Hmm, sounds like the same side of the tail.
I just used some CA, then a piece of IM spread tow and a layer of Carboweave pressed on with a patch of mylar and some foam. Not a pretty fix but it's on the bottom. It looked like a buckling failure on the skin maybe starting at the end of the joiner tube where the foam/carbon braid web starts. It probably could have used an extra layer of the skin carbon through that area to stiffen the skin a little.
Old Feb 23, 2016, 12:00 PM
ak79 is online now
Flightcomp.com
ak79's Avatar
Joined Apr 2006
Checked my v-tails. Both sides are fine. Model is maybe a year old. Also, I never remove them.
Site Sponsor
Old Feb 25, 2016, 07:44 PM
proppy jon is online now
Find More Posts by proppy jon
Original Bloody Spadder
proppy jon's Avatar
phoenix
Joined Jul 2004
I'm curious. Are they the Ls lay up only. Others. Sl or c68
proppy jon is online now Find More Posts by proppy jon
Old Feb 29, 2016, 02:57 AM
f3f-f3b is offline
Find More Posts by f3f-f3b
f3f-f3b's Avatar
Joined Dec 2009
My V-Tails on the ST 76 Both deliminated after two landings fixed with thin CA got New Tails from Flightcomp (as l didn't trust the creased one's) & have had no problems since the model is 18 months old.
f3f-f3b is offline Find More Posts by f3f-f3b
Old Mar 13, 2016, 03:56 PM
stefanoc2 is offline
Find More Posts by stefanoc2
stefanoc2's Avatar
Joined Aug 2006
Can somebody with experience using the Perfection LDS (Samba) post their impressions please?
Stefano
stefanoc2 is offline Find More Posts by stefanoc2
Sold T-Rex 550FBL 3GX V2 "PERFECTION" (SOLD) rapyd Aircraft - Electric - Helis (FS/W) 7 Jul 25, 2011 06:44 AM
Wanted Pike, Pike Plus, Pike P or Pike WR Wing Center Section Lancer263 Aircraft - Sailplanes (FS/W) 0 Nov 11, 2010 11:07 PM
