Old Nov 22, 2012, 07:00 PM
Joined Nov 2012
My First Quadcopter design - will it work? (arducopter)
hi there RC,
my name is gal and im a senior at the TAU.
I'm trying to build a quadcopter and i would like to know, from your experience, if it will work correctly.
The design:
Processor: Arduino Uno - Rev. 3
https://www.sparkfun.com/products/11023
Communication system: Arduino Xbee kit
https://www.sparkfun.com/products/9897
Gyro: tri-axes gyro breakout L3G4200D
https://www.sparkfun.com/products/10612
Motors: 2725 brushless outrunner motor 1600kV
http://www.hobbyking.com/hobbyking/s...or_1600kv.html
Propellers: 12x4.5 props 2pc standard rotation /2 pc RH rotation
http://www.hobbyking.com/hobbyking/s...on_Black_.html
ESCs: turnigy multistar 20 Amp multirotor brushless ESC 2-4S
http://www.hobbyking.com/hobbyking/s...ESC_2_4S.html/
Adapters: propeller adapter (colet type) 3mm
http://www.hobbyking.com/hobbyking/s..._type_3mm.html
Frame: Turnigy talon carbon fiber quadcopter frame
http://www.hobbyking.com/hobbyking/s...ter_Frame.html
Battery: turnigy 2200mAh 3S 40C lipo Pack
http://www.hobbyking.com/hobbyking/s...dproduct=10279
Charger: hobbyking 50watt 5A X-charger/balancer
http://www.hobbyking.com/hobbyking/s..._Balancer.html
and i have a few questions.
1) will it work correctly? do i need any other components?
2) do i need another shield for my arduino to allow the arduino to communicate with the ESCs?
3) are the motors powerful enough? will they give me enough thrust?
4) are the adapter i choose correct?
5) is the charger suitable for the battery?
6) do i need another battery for the arduino? what kind of battery?
thx =]
shokata is offline Find More Posts by shokata
Old Nov 22, 2012, 07:47 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
I don't know what your objective is with those Arduino boards, but for a basic quad with a lot of functions to play with I would go with this or something similar: http://www.goodluckbuy.com/mwc-multi...breakout-.html. It's all the boards you need. It contains 3 axis gyro, barometer, magnetometer and accelerometers.
You want a balancing charger. I don't see balancing ports in that one.
If you have no previous experience flying a quad, you will probably break this one rather quickly.
Balr14 is online now Find More Posts by Balr14
Old Nov 22, 2012, 07:56 PM
Joined Nov 2012
lol. i thought this is a charger for the battery.
what kind of charger do i need to buy for the battery?
Discussion My First Quadcopter design - will it work? (arducopter) shokata Multirotor Talk 1 Nov 22, 2012 05:58 PM
Discussion Will the Rx that comes with the FlySky 9x work in a quadcopter? SplitFire Multirotor Talk 3 Jun 22, 2012 09:26 PM
Discussion Will this Work??( My first attempt at a quad) Bixler13 Multirotor Talk 2 Apr 02, 2012 10:13 PM
Sold Selling my Quadcopter/Arducopter mein electronics +(Magnetometer+GPS) CyberCrash Aircraft - Electric - Multirotor (FS/W) 0 Jan 04, 2012 09:08 AM
Discussion Aerial video from a 3D plane? Will my design work? Hellbore Aerial Photography 14 Aug 24, 2007 07:43 AM
