Old Nov 11, 2007, 09:01 PM
Slowly Approaching 1,000
Detroit (area), MI
Joined Mar 2004
Question
Is there a wattage/pound rule of thumb for helicopters?
Is there a rule of thumb to go by for how much wattage per lb. is needed to fly helos certain ways, i.e. hover, sport, 3d, insanity?
Such as with planes you want 100 watts per lb for "fun" sport flying, 200 watt/lb for exciting white knuckle flying, etc.
philosophicle_1 is offline Find More Posts by philosophicle_1
Old Nov 11, 2007, 10:04 PM
Toronto Canada
Joined Dec 2002
It turns out that it requires approximately 50W per pound to hover.
Some helis can go as low as 35W per pound depending on motor efficiency.
The power required to hover is also dependent on rotor RPM.
Slower RPM requires less power, but the stability of the heli suffers.
Most model helis require about 50W per pound to hover.
For the same heli and rotor system, the power required to hover increases as the weight increases to the power 3/2.
That is, Power is proportional to WEIGHT^(3/2)
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Nov 11, 2007, 10:05 PM
hover happy
spinup's Avatar
over under
Joined Aug 2007
Yep. See section 30.11.2 of the Electric Helicopter Beginner's Guide. Should be linked from a sticky in this forum.
Jeff
spinup is offline Find More Posts by spinup
Old Nov 12, 2007, 11:53 AM
Detroit (area), MI
Joined Mar 2004
Thanks guys, I did a brief search and after the first 3 pages of threads and hour+ in front of the PC, I figured I'd ask very specifically. Appreciate it.
Old Nov 12, 2007, 12:56 PM
hover happy
spinup's Avatar
over under
Joined Aug 2007
Yeah, it would be great if forum search also covered some sections of the EHBG. Some of the technical explanations in that guide are the best I've seen.
Jeff
Is there a rule of thumb for crow (butterfly) setup? jorgeeli Sailplane Talk 10 Apr 27, 2005 12:42 PM
Is there a rule of thumb for designing planes Dezynco Fuel Plane Talk 2 Apr 26, 2004 03:04 PM
Is there a rule of thumb for AC weight to Ski size. The Other Dave Electric Plane Talk 0 Mar 17, 2003 06:17 PM
Rule of thumb for brushless # of turns aireze Electric Plane Talk 5 Jul 06, 2002 09:43 AM
Rule of thumb for center of gravity spark363 Modeling Science 4 Jul 05, 2002 03:31 PM
