Old Jun 29, 2014, 04:18 PM
United States, PA, Doylestown
Joined Jun 2010
Hobby hawk wing rod.
Can any one tell me where I can replace my original hobby hawk wing rod? Thanks .
dropspeed150 is offline Find More Posts by dropspeed150
Old Jun 29, 2014, 06:04 PM
Fresno CA.
Joined Apr 2009
Wing Rod
Try Aircraft Spruce - Alum or C- Molly by the foot ! I still have one I got in 1974 ! Still fly it !!! Way ahead of it's time !!
ricshaw is online now Find More Posts by ricshaw
Old Jun 30, 2014, 12:17 AM
slopemeno's Avatar
Joined Jan 2003
Get a DixiePin of the appropriate diameter and cut it to length with a dremel cutoff wheel.
http://www.dixiepins.com/
slopemeno is offline Find More Posts by slopemeno
Old Jun 30, 2014, 09:33 AM
Joined Jun 2010
Thanks for the info. I was told ACE hardware has what I need.
Old Jun 30, 2014, 09:45 AM
leadville colorado
Joined Oct 2002
Watch out for hardware store aluminum rods as they are not hard enough and bend easily, don't ask how I know. I got mine from Small Parts(?) I think. I am not near my shop now so can not help with a part number. I think it was 6061 aluminum.
2milehighguy is offline Find More Posts by 2milehighguy
Old Jun 30, 2014, 09:48 AM
Life-abstract=conformity
S.F. Bay Area
Joined Aug 2002
You are talking about a Hobie Hawk right?
IIRC the main wing rod is 5/16".The pins may be 5/32" but don't quote me.
Hardware store steel rod should work unless your into some serious winching.Keep it rust free.
Skies
J
AirBornOne is offline Find More Posts by AirBornOne
Old Jun 30, 2014, 01:08 PM
Fresno CA.
Joined Apr 2009
"Hardware Stores"
All hardware stores sell 6063 or lower grade !! They call it "Architectural Grade" It"s "SOFT" The first time you pull up it will bend both wings up ! Then if you make it back to ground! Then you will have "REAL" fun trying to get wing rod out !! Go to Aircraft Spruce and get sum 2024T3 or T4! less than $1.00 per foot !! or get sum C/M 4130 Structural Tubing ! You would be more than safe with .028 in wall, This what I have in mine, never bent one yet!! May be under $3.00 per foot ! The Ozone Ranger
Old Jun 30, 2014, 01:13 PM
Mark Miller's Avatar
St. Louis, MO
Joined Oct 2002
I have used some 5/16" 7075 T6 aluminum bar from Speedy Metals. Works great! Steel puts a lot of stress into the wing on launch where the aluminum will flex
Mark Miller is offline Find More Posts by Mark Miller
Old Jun 30, 2014, 03:13 PM
S.F. Bay Area
Joined Aug 2002
Originally Posted by ricshaw View Post
All hardware stores sell 6063 or lower grade !! They call it "Architectural Grade" It"s "SOFT" The first time you pull up it will bend both wings up ! Then if you make it back to ground! Then you will have "REAL" fun trying to get wing rod out !! The Ozone Ranger
I was wondering about just that.
Mark's idea is good however I've always seen high shipping & handling charges from online metal suppliers.Buyer beware.
Could prolly get a nice piece of SS tube from the metal display @ the hobby store (K & S metals?) if you have one.Maybe hardware store too.
Do Not Use plastic I only say this cause a fellow used acrylic rods (worried about weight IIRC) on his OE Hobie w/ 10' wings.Last time that one flew.
Although I bet a delrin rod may work.I just won't bet my bird on it.
Skies
J
Old Jun 30, 2014, 07:07 PM
Fresno CA.
Joined Apr 2009
Skies
J
S- Steel Nope !! No Plastic- Delrin Nope - Nope !!!!!!!!!!!!!! Spend $10.00 or less and save your Hobie Hawk !!
For Sale HOBBY HAWK 2 right wing panels Rich Burnoski Aircraft - Sailplanes (FS/W) 2 Feb 05, 2014 03:34 PM
Help! Uni carbon wing spars / wing rods DLGjunkyard Hand Launch 27 Nov 11, 2013 01:05 PM
Help! Wing rod has tiny wobble inside brass tube hog2soar Sailplane Talk 6 Sep 20, 2013 04:51 PM
Wanted Hobby Lobby Raptor Wing Joiner/Rod SFBC Aircraft - Sailplanes (FS/W) 8 Jul 05, 2013 07:53 PM
Wanted Hobie Hawk wing rod and wire Chuchuf Aircraft - Sailplanes (FS/W) 4 Sep 01, 2009 09:00 PM
