Old Dec 28, 2012, 02:27 PM
NoFlaps's Avatar
Louisville, KY
Joined Jan 2003
Minwax or epoxy over Coverite ?
Hi all,
I want to fiberglass a plane, and have previously done so using 2 methods (1) Minwax with light cloth. 2) Finish epoxy over light cloth) on different planes.
However- I have a fully sheeted plane that has been covered in clear "Coverite" (cloth) covering. I wanted to know if anyone has ever tried painting on Minwax or epoxy over this in order to get essentially the same finish as fiberglassing ?
NoFlaps is online now Find More Posts by NoFlaps
Old Dec 29, 2012, 08:01 AM
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
A friend does this, using Solartex and nitrate dope.
The process should work on Coverite, too. Use the nitrate, though, not epoxy or Poly C. The nitrate will eat into the Coverite, creating a strong chemical bond.
In my opinion, the proces is heavy. It does create a smooth surface, however.
I once covered a model in Coverite, and used a lacquer based automotive primer to fill the weave. Thje strong solvents in the lacquer ate into the covering, providing good adhesion.
The model was exceedingly heavy, but looked pretty good.
TomCrump is online now Find More Posts by TomCrump
Question Can you put epoxy or Gorilla Glue over foam-safe CA? Spackles94 Electric Plane Talk 5 Aug 12, 2007 05:58 AM
Fiberglassing with Minwax or Epoxy, weight data hermperez Foamies (Kits) 0 Feb 22, 2004 12:04 PM
