Old Oct 16, 2001, 11:34 AM
Sunnyvale, CA
Joined May 2001
GWS 370-A thrust
The search engine is down and I couldn't find anything on http://www.grandwing.com so....
Does anyone know what the thrust for the GWS 370-A motor is and how many amps it draws?
tom_yellowblue is offline Find More Posts by tom_yellowblue
Old Oct 16, 2001, 12:36 PM
Old Desert Rat
Arizona Chuck's Avatar
Rimrock AZ. USA
Joined Mar 2000
I would make a guess at 6 1/2 oz. I put one in a plane I'm designing and it had a little less then the M100. That is comparing recommended props. The big difference is the GWS 370 is harder to mount in a fuselage neatly and it uses a bigger prop. I flew it with 8/300 NiMH with no trouble. I would guess less then 3 1/2 amp.
Arizona Chuck is offline Find More Posts by Arizona Chuck
Old Oct 16, 2001, 12:38 PM
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
Tom, the sheet I have that comes with the EPS systems only starts with the B motor.
At 7.2V and an 8x4.3 prop, the B motor draws 4.2 amps and delivers 220 grams of thrust.
Sorry I can't be more helpful.
Doug
CoClimber is offline Find More Posts by CoClimber
Old Oct 16, 2001, 01:54 PM
Bleriot's Avatar
Joined May 2000
MRS BINDER! DOUG GOT OUT OF BED!! Back in the sack Doug, with a big bowl of chicken soup and some Brownies Hope you get well soon Best Regards
Bleriot is offline Find More Posts by Bleriot
Old Oct 16, 2001, 02:01 PM
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
Bleriot, Shhhhhh!!! At least the computer that I'm using is in the bedroom!
For those who are wondering what the heck we are talking about, see the UrbanFlyer post.
Doug
Old Oct 16, 2001, 02:58 PM
Sunnyvale, CA
Joined May 2001
Thanks AZ Chuck. I was wondering if I should get one for a little more oomph than the M100 I have on the way, but it looks like the M100 will be fine.
Doug, do you have the data sheets in your bedroom too or do you have that stuff memorized?!
Old Oct 16, 2001, 03:09 PM
d_trafalgar's Avatar
Ontario, Canada
Joined Sep 2001
You can find Information here.....
http://servoman.hypermart.net/english.htm
d_trafalgar is offline Find More Posts by d_trafalgar
Old Oct 16, 2001, 08:55 PM
Old Desert Rat
Rimrock AZ. USA
Joined Mar 2000
You can push the GWS to more amps then the M100 but then you have to go to nicad batteries or big NiMH. The M100 and 8/300 NiMH has good power to weight. I had the GWS on that setup. I love Radical RC's batteries but don't want to push them over 3 1/2 amps. You can get 8 oz thrust from the M100 with a different prop but the amps go up and the battery weight goes up. Can't see where you are gaining anything.
Old Oct 17, 2001, 01:01 AM
Celje, Slovenia
Joined Jul 2001
Hello!
Try http://servoman.hypermart.net/english.htm
it have popups, but usefull inf too.
EPS-DX-A (M0.4) 60 / 16 = 3.7 : 1
PORP Volts (v)
Amps (A) Thrust (g) Power (w)
4.5 150 27 5.5555
Here you are!
L.P. Samo
samo is offline Find More Posts by samo
Old Oct 17, 2001, 04:21 PM
Huber Heights, Ohio, 45424, USA
Joined Mar 2000
Radical RC Dave here. I've done extensive testing on the GWS 370-A. This is one of the most powerful S-300's in the world. We fly them as one of the reccomended power packages on the Edge-540. They LOVE 8 720 NiMH cells, 8-6 GWS prop. Expect 11 oz of thrust. Expect about 6.5 amps draw. Mine have lasted a long time. You can mount a Graupner 300 in the same box and spend about 9 amps to 6100 RPM or a RRC Black Diamond 301 at about 8 amps on the ground and 6500 rpm same prop, same gear ratio. The Black Diamond falls off to about 6.5 amps in the air. I've run them on my RRC-300's 8 cell but only with limitied full throttle bursts. They get ahead of that battery quick. Though the RRC-300's will handle it with throttle control and handle any speed 280 setup with ease. Generally the 720 is a better choice in these amp ranges. We've even got a limited supply of the 800's (4/5AAA) in stock. I've used them on the 301 motor but extensively so I am not aware of how much punch they can swallow.
Happy Flying!
Dave
radicalrc.com is offline Find More Posts by radicalrc.com
Old Oct 17, 2001, 04:45 PM
mattk17's Avatar
Dallas,TX
Joined Jul 2001
I'm going to buy one of the gws 370s. Who has the best price out there?
mattk17 is offline Find More Posts by mattk17
Old Oct 17, 2001, 06:50 PM
Zoom, Zoom, Zoom
Rochester, NH
Joined Oct 2001
try www.balsapr.com not sure if they are in stock or not.
Brian E. is offline Find More Posts by Brian E.
Old Oct 17, 2001, 06:58 PM
Joined Mar 2000
Dave from Radical RC here. I stock them for $18, $2 shipping. $20 delivered. I don't think Bob at BP is going to tip me for turning you on to it so give me a jingle and I'll send you one.
Dave
Old Oct 17, 2001, 08:03 PM
mattk17's Avatar
Dallas,TX
Joined Jul 2001
Is the gws geared 370A motor for $20 shipped the best value in that price range? I only have experience with the little gws motors and speed 400s so I could use some advice from others who have experience with this motor size.
Old Oct 17, 2001, 08:45 PM
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
Dave T,
Did you also try the 370-B system?
With a 9x4.7 thrust is 342.
Thrust w 370-A w 8x6 is 286.
Specs from GWS web site.
DNA is offline Find More Posts by DNA
Whoops! GWS 370 versus G4046 question (?) poobs Parkflyers 31 Nov 02, 2002 03:59 PM
GWS 370 a drive setup Steve H. Parkflyers 7 Feb 13, 2002 08:16 PM
gws drives and thrust/ best for tiny? DeaninMilwaukee Scratchbuilt Indoor and Micro Models 51 Feb 03, 2002 09:54 PM
Gws Prop Thrust ? mjse Parkflyers 4 Nov 18, 2001 11:56 AM
Do we break-in GWS 370 geared motor ? Al P Parkflyers 3 Sep 13, 2001 06:20 PM
