Old Dec 08, 2012, 05:54 PM
United States, WA, Duvall
Joined Mar 2012
Pulling my hair out
I'm using Multiwii 2.1 Conf to set-up a new quad. Everything I'm reading here on the forums and in the docs talks about multiwii controllers having two flight modes: Acro mode and level (or stable mode).
I can't for the life of me figure out how to map those two words (Acro and Level) to the checkboxes on the MultiWii Conf UI.
Multiwii Conf 1.9 had a checkbox labeled 'Level' that you would associate with an accessory switch. I always assumed when 'Level' was on you were flying in level or stable mode and when it was disabled, acro mode.
The 'level' checkbox is entirely missing from the newer 2.1 version of MultiWii Conf.
What am I missing?
AaronHartwell is offline Find More Posts by AaronHartwell
Old Dec 08, 2012, 05:56 PM
United States, NV, North Las Vegas
Joined Sep 2009
ACC and level mode are the same thing
shultz is offline Find More Posts by shultz
Old Dec 08, 2012, 06:02 PM
Joined Mar 2012
Ohhhh.... that would explain why 1.9 has Level and no ACC. Duhhh... That makes sense.
For some reason I thought barometer, magnometer, and accelerometer (gyro) were all needed for 'level' flight mode.
Old Dec 08, 2012, 06:32 PM
Joined Sep 2009
Briefly, Barometer is for height/altitude hold, Magnometer is for direction and ACCelerometer is for level, for "level mode" all you want/need is ACC on.
I haven't messed with Mag or baro much... heck I hardly use ACC!
John
Old Dec 08, 2012, 08:09 PM
Joined Mar 2012
Awesome. Thanks John!
Old Dec 09, 2012, 03:34 AM
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
In the pic you posted above you'd be flying in acro mode when the AUX1 stick is in position 1 (low) and acc/autolevel mode when stick is in position 2&3 (mid&high).
If you always want to fly in acc mode, just mark all 3 boxes.
kinderkram is offline Find More Posts by kinderkram
Discussion Pulling my hair out - KK 4.7 and Motor 2 Phytone Multirotor Electronics 2 Aug 24, 2012 03:02 PM
Discussion Pulling my damn hair out over .25 pitch angle causing engine cut out. ryank Fuel Plane Talk 5 Oct 12, 2009 05:01 PM
how do you set up a ms44 with a jr 8103 pulling my hair out i'll be bald before x-mas falcon41176 Micro Helis 0 Dec 21, 2004 08:58 PM
Pulling my hair out-trying to get dual ail. servos right. BDuffel Radios 0 Oct 15, 2004 05:14 PM
Voyager Build Questions...I'm Pulling My Hair Out jimmyG Electric Heli Talk 18 Jan 18, 2002 02:38 PM
