Go Back   RC Groups > Aircraft - Sailplanes > Slope
This thread is privately moderated by Sensiblenick, who may elect to delete unwanted replies.
Old May 23, 2008, 06:28 PM   #1
Tearing the Skies a new one...
Sensiblenick's Avatar
Send a message via MSN to Sensiblenick
EVERYTHING: Faq, Techniques, Tools, Tips'n Tricks.. Pretty much everything really.
It seems to me that there are a large amount of questions that regularly pop up.
"How do I vacuum bag"
"How do I cut wings"
"how do I work out the Center of Gravity?"
"What plane for a beginner?"
and so on....
Usually to answer these (and all other questions) regulars have to trawl the archives to find the links. Even those who know and love the search function have to admit that finding some things can be frustratingly difficult.
I've been out for some time (I went for a walk) but I'm back to stay and will be happy to edit this thread and keep the 2nd page as a continually updated list of links to other threads/posts of particular value.
The aim is to collect all the posts that you have found useful in one place so that we can by-pass the search and direct people to a specific post...
Got a particularly good link? Remember a great bit of advice or work that was useful to you? Post the link and suggest a category or title, and I'll edit into post Nr 2
Sensiblenick is offline Find More Posts by Sensiblenick   Reply With Quote
Old May 23, 2008, 06:29 PM   #2
All the links that you could want.
This list is FAR from full... please post links you'd want to see added.
Aerobatics
Surfimps Slope-specific Aerobatics page
Ian Cole's Slope Aerobatics page
Balsa
Calculations
A collection of links for sailplane design / aerofoil analysis (Flyonline)
CoG Calculator (Aircraft Proving Ground)
Aero Design Rules
Slope wing calculator
Link to Profili 2
Curtis Sulter's collection of calculation sheets
A REYNOLDS Nr Calculator
CONVERT EXE - A very useful freeware program for nearly all convertions.
Construction Techniques - Finishing
DECALS Thread
PAINTING - a nice sequence (Carlski)
Covering Techniques: Video showing Use of Monokote to make patterns
Construction Techniques - Structure
A 100% pictorial DLG build (Yclui) that touches on nearly every construction method.
CANOPY MOULD - How to (Legliderman)
CLEAR CANOPY made while using home-built Vacuum setup
CNC modelling
Linkages - How To - Many techniques (Tailslide UK)
"LOST FOAM" technique for making fuselages (Louis Dionne)
JART-V-XL Lost Foam Fuse Prt1 (posts #59-#184) Part 2 (Posts #259-#280)
SILICONE HINGES - how to
SOLDERING - How to solder Piano wire (various)
TORQUE RODS - discussion and examples - (SlopeIron + others)
WET SEAMS on moulded fuselages (Samotage)
WING construction for VACUUM bagging
Wing-Joiner - "Sparless" (Slopeflyer.com)
Construction Tools
HINGE Slotting Jig (SlopeIron)
HOTWIRE: the very simple "Swingwire" Technique. (TFLG)
GOOP and Gorilla glue tests and info (Derek Choice)
VACUUM FORMING - Build your own machine
VACUUM Forming using home-built Vacuum setup
CNC Foam cutting info
Composites
KEVLAR: how to deal with it (Samotage)
Daft Things. Slope-related Fun and Idiocy
Converting a £10 foam toy into a sloper for trainee slope-trash (sensibelnick)
Autogyros.. can the be sloped? (Sensiblenick)
Furry Planes... Will they work? (guess who)
Are Slopers Idiots? .... Maybe...
Electrics
POWER SUPPLY made form Computer power supply (Instructables)
SERVO CABLES - one method of lengthening or replacing them (Andy W)
FAQ
SLOPE TERMINOLOGY: The complete thread
Fun things to do at the slope??
"Rip the Bring" and "Brick*" .. where do they come from?
Where can I see some VIDEOS of sloping? Mike Y's youtube collection.
Are there FREE PLANS for slopers? Sure, they've been collected here
SSDC? what's that all about?
WHAT FIRST PLANE? Discussion regarding whta to get when starting.
I have a brushless motor and an Icecream tub... Is there some way I can combine these?
F3f
Plan your F3f Improvement (Pierre Rondel)
Model supplies - Composites
Dedicated post can be found here
Model supplies - Regional
UK - Thread dedicated to useful places
Plane Specific - Build logs -
All collected logs can be found here
Plane Specific - Setup Advice
TWF (Twisty Wing Fetish) information thread. (Sled Driver)
PLANK Balancing (Derek Choice)
WEASEL tuning (Surfimp)
PW51 plank balancing (Various)
SLOPE DESIGNS RAPTOR 48/36 build and tweak advice
Plane Specific - Scale
A good Source of 3-view drawings
A massive thread of 3-views (Local Psycho)
Radio Gear
AERIAL (Rx) - Extending with Shielded Coax cable in a Carbon Fus (Pile Bruck)
FUTABA 9C Programming discussion
MULTIPLEX Evo programming (Many)
SERVO choice discussion for 60" span slopers
Repairs & Salvage
Fuselage repair using carbon sock (TFLG)
A pictorial composite wing repair tutorial (Yclui)
Highly comprehensive Mouldie repair thread by Wr Mizzard
Repairing a Fuselage using Carbon Sock by Mike Furcolow
Need more titles.. PLEASE Suggest them.
Old May 24, 2008, 12:35 PM   #3
...in with the new
ajroahkni's Avatar
Joe Manor's Carbon Testing threads.
http://www.rcgroups.com/forums/showthread.php?t=480273
http://www.rcgroups.com/forums/showthread.php?t=778363
and the 80" dynamic thread
http://www.rcgroups.com/forums/showthread.php?t=303670
ajroahkni is offline Find More Posts by ajroahkni   Reply With Quote
Old May 28, 2008, 12:08 AM   #4
No fuse too fat
Gold Member
slopeiron's Avatar
Hey Nick,
Lets not forget one of the coolest build threads of all time:
Build Log - SSDC: Sloop (circle abuse)
I love this!
"sloop" flying at cross mt. (thats funny) (0 min 27 sec)
slopeiron is offline Find More Posts by slopeiron   Reply With Quote
Old Jun 03, 2008, 05:04 AM   #5
The Composite Supply Post
Composite suppliers - Australia
http://www.fgi.com.au/
http://www.fibreglassmaterials.com.au/
http://www.offtheedge.com.au/page.asp?id=1 (Bagging Matrls)
Composite suppliers - Germany
http://www.bacuplast.de/
http://www.emc-vega.de/
Some special things there you rarely find anywhere else, like thin endgrain balsa as sandwich material.
http://www.r-g.de/
Very good documentation and info ('how to', tipps, etc.) and a very complete assortment of literally everything you might need to work with composites.
http://www.lange-ritter.de/content/index.php
Used to have good prices if you need rather big amounts of the stuff.
http://www.schloesser-cramer.de/sta...lang=de&status=
Manufacturer of carbonfibre cloth.
http://www.siltex.de/index.html
Manufacturer of glasfibre and carbonfiber socks.
Composite suppliers - Sweden
http://www.bhp-glasfiberprodukter.se/
Composite suppliers - UK
http://www.fibretechgb.co.uk/DefaultHome.htm
http://www.freeflightsupplies.co.uk/
Composite suppliers - USA
http://www.acp-composites.com
http://www.tapplastics.com/shop/category.php?bid=45&
http://www.solarcomposites.com/
http://www.fiberglasssupply.com/
http://www.fibreglast.com/
http://www.cstsales.com/
Old Jun 03, 2008, 03:25 PM   #7
The Build Log Post.
Just incase...
Old Jan 11, 2009, 01:48 PM   #8
Originally Posted by Marcos Quito
In the very first thread, there´s:
And I could not identify your suggestion though.
This and many more have just been added. Thanks all for your suggestions.
We now have the new "Daft things" category too....
Keep on suggesting stuff gents!
Old Jan 12, 2009, 07:49 AM   #9
... and a new thing the FAQ for your amusement...
Old Jan 12, 2009, 02:12 PM   #10
Long to be flyin'
Antonsoarer's Avatar
Not really an Everything thread as long as New Stuff (Laminating materials/techniques) is missing, head in sand?
Antonsoarer is offline Find More Posts by Antonsoarer   Reply With Quote
Old Jan 12, 2009, 02:50 PM   #11
Linky? and Can I get it in Sweden?
Old Jan 12, 2009, 02:57 PM   #12
Note to self
http://www.rcgroups.com/forums/showthread.php?t=982770
Old Jan 12, 2009, 05:10 PM   #13
Long to be flyin'
Sweden should be no problem, just need to find the best laminating stuff available (adhesive/film ratio, overall thickness and stiffness), they all work well to varying degrees.
Lots of links and no one-stop shop yet, they all cover different aspects. Many people still experimenting with application and colouring techniques, loads of information being posted)
Tony.
  • Name: NS-88.jpg
Description: This shows the finish that's possible on a 88" foam wing I did recently.  It's the stiffness that really is amazing. This shows the finish that's possible on a 88" foam wing I did recently. It's the stiffness that really is amazing. 28.8 KB · Views: 717
Old Jan 12, 2009, 05:20 PM   #14
Ooohhh.. I had my head in the carbon.. *ahem* sand on that one. I'll find a way of working it in without causing clutter
N
Old Jan 12, 2009, 06:10 PM   #15
Long to be flyin'
N
Nick, I have put all the above links in the first post of the 'NS Techniques and Feedback' thread. Maybe that will keep this thread clean.
Post - portal to NS threads:
New Stuff portal
Bored? Want to fight?
Join the RCGroups clan!
