Old Dec 27, 2004, 03:37 AM
_James_ is offline
Find More Posts by _James_
_James_'s Avatar
Western Australia
Joined Jun 2004
First Depron Wing
I built this wing 50cm (24") using 3mm depron in the build up fasion i have seen, when it is complete it will be 18mm thick, i have left the top off untill servos and rx go in... im still thinking what kind of motor, i will be using maybe a 2s 700 with a 3x3 prop on a 180(or something)
is a brushless little screamer to big for this wing?
Attached is the unfinished wing, 1 servo (hs 55) and the motor i mite be using,
_James_ is offline Find More Posts by _James_
Old Dec 28, 2004, 03:07 AM
Rob Russell is offline
Find More Posts by Rob Russell
Busselton Western Australia
Joined Aug 2003
James
Do you sand down the leading edge?
Where did you get the 3mm depron from and what glue did you use?
Rob
Rob Russell is offline Find More Posts by Rob Russell
Old Dec 28, 2004, 04:36 AM
_James_ is offline
_James_'s Avatar
Western Australia
Joined Jun 2004
covering
the top is covered with 3mm depron,
i got the depron from a home bisnus in perth and i used 5min epoxy which was a bit heavy, but i will be getting a little screammer motor in it so it should be great and fast! =)
James
Old Dec 28, 2004, 06:50 AM
Magnum9 is offline
Find More Posts by Magnum9
Molded Hotliner Destroyer
Magnum9's Avatar
Perth, Australia
Joined Jul 2004
Good work James, did you get the Depron from Richard in Kinross? They actually run the depron-australia website. Have a look at my latest creation built from his Depron - http://www.rcgroups.com/forums/showthread.php?t=311552
Magnum9 is offline Find More Posts by Magnum9
Old Dec 28, 2004, 05:28 PM
klong66 is offline
Find More Posts by klong66
Joined Jul 2004
Very Nice,
a couple of questions...
What is your AUW?
Did you use a heat gun to help shape the top layer depron?
Ken
klong66 is offline Find More Posts by klong66
Old Dec 28, 2004, 05:30 PM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
it doesnt look like you have much sweep if it flys you might have abit of a bumpy ride but it should still fly fine a 180 motor might be a tad bit small u should look at the J250 or a go brushless CD ROM motors they would be great for something this size if you would like to use a J250 motor but dont have one on hand do a search on aussie ebay i have one on there for sale
gazza2003au is offline Find More Posts by gazza2003au
Old Dec 29, 2004, 05:08 AM
_James_ is offline
_James_'s Avatar
Western Australia
Joined Jun 2004
magnum9 thanks and yes i did get it from Richard it was a fair drive,
the construction was VERY easy and the top layer of depron just was epoxied over the stairs, no heat, no stress, just glue and taped togerther to dry, sorry not shor on the weight, im still trying to find a good motor, dont the j250 pull like 10amps?
thanks guys
James
Old Dec 29, 2004, 05:19 AM
Sydney, Australia
Joined Jul 2003
J250 on a 4x2.5 draws around 5-6amps at WOT 3x3 draws around 7 at WOT it would make that wing hammer and you could use bigger lipolys 1200-1500's
but if you go with the 180 motor go with a 3x2 once u launch it it'll get flying alot quicker with the 3x3 you'll get more speed but more of a chance of stalling the prop i think its called check out all the 24" wings avaliable in the USA that use the GWS 50XC (180 motor)
heres a few different manufacturer's on one page http://www.slofly.com/index.php?cate...&parent=Planes
Old Dec 30, 2004, 02:13 PM
Arthur P. is offline
Find More Posts by Arthur P.
Hoofddorp, Netherlands
Joined Sep 2004
Red Depron MiniWing with RTF weight of 105g
I just posted pics, plans and build description of my miniwing here: http://www.rcgroups.com/forums/showthread.php?t=315680. It has managed windspeeds of up to 20mph with a full battery and has proven to be very, very crash resistant despite having only a spar and no complete filling up of the wing.
Arthur P. is offline Find More Posts by Arthur P.
Old Jan 02, 2005, 03:26 AM
Joined Aug 2003
James
The depron you got from Richard do you still have to buy a box or can you get 3 or 4 sheets at a time?
I got some 2 years ago and you had to buy 1/2 a box at a time.
Rob
Old Jan 02, 2005, 06:35 PM
Sydney, Australia
Joined Jul 2003
www.depron-australia.com its in WA only bad thing is you'll need to buy min 5 sheets
Old Jan 02, 2005, 06:45 PM
Magnum9 is offline
Magnum9's Avatar
Perth, Australia
Joined Jul 2004
Originally Posted by Rob Russell
James
Rob
You can buy as little as one sheet as long as you pick it up from his house. I went to buy two sheets, ended up changing my mind to 4 sheets when I got there, and he gave me 7 sheets because he had some mildly damaged pieces which he didn't charge me for.
First flight of the Wing-E!! Martin Hunter Parkflyers 41 Jul 21, 2002 11:04 PM
First flying wing advice shazi Parkflyers 4 May 09, 2002 12:16 PM
Depron wing joining dgoslee Scratchbuilt Indoor and Micro Models 2 Mar 21, 2002 07:58 PM
hot depron wing with DX-A Nicke Parkflyers 11 Jan 11, 2002 07:20 AM
The most awesome Depron wing I ever saw ChrisP Foamies (Kits) 4 Nov 21, 2001 07:28 PM
