Old Jun 28, 2016, 06:05 PM
mucwendel is offline
Find More Posts by mucwendel
mucwendel's Avatar
Deutschland, Nordrhein-Westfalen, Wuppertal
Joined Jun 2009
Broken MFDlink Rlink Transmitter
Hi from Germany,
today I lost my plane due to sudden failsafe situation.
After collecting all items and some investigation it turns out, that the TX is only connected if closer than 1m to the receiver.
As I'm an electronic engineer I took a lock inside the tx.
I found the problem as the antenna connector was moving due to bad soldering.
There was nearly no solder material and the tx pin was just sometimes touching the pcb.
So I free some more copper on the pcb and correctly solder the item.
See the pictures...
!!! Before (original) … no solder material visible and bad or no connection
After my soldering…strong and 100% contact
After that I did a range test and the range was just 20m (1m before soldering, 18km last week)
So I conclude, that the tx amplifier has got damaged during transmitting without antenna connection.
Now I'm looking for a solution. Is there any Idea to repair the pcb by myself?
All smd part looking normal.
Receivers are OK tested with another pilot MDFLink.
Thanks for suggestions
mucwendel is offline Find More Posts by mucwendel
For Sale Rlink V2 433Mhz transmitter receiver 16 channe remote FPV remote 50Km remote process flymaesky Aircraft - General - Radio Equipment (FS/W) 0 May 17, 2016 09:52 AM
Sold Rlink V2 433Mhz transmitter receiver 16 channe remote FPV remote 50Km remote process flymaesky Aircraft - General - Radio Equipment (FS/W) 4 May 16, 2016 08:22 AM
Wanted Rlink/MFDlink receivers Hmerly FPV Equipment (FS/W) 0 Apr 22, 2016 03:52 PM
Sold 433MHz LRS MFDLink (RLink) TX/RX diversity Aries321 Aircraft - General - Radio Equipment (FS/W) 1 Feb 04, 2016 06:36 PM
Sold MyFlyDream MFDLink 433Mhz LRS (RLink) Aries321 FPV Equipment (FS/W) 0 Dec 18, 2015 08:31 PM
