Old Oct 23, 2014, 03:02 PM
TheTick is offline
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
Hysol 9460 vs 9462
9462 seems more popular, but 9460 comes in 6.76ml cartridge for a better price. Are the consistencies pretty much the same? Mcmaster Carr does not sell the gun or plungers. How would I even dispense it?
http://www.mcmaster.com/#loctite-hysol/=ua3gvy
Any help would be appreciated.
Thanks!
Ben
TheTick is offline Find More Posts by TheTick
Old Oct 23, 2014, 03:57 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Thanks!
Ben
Minor correction Ben, it's 6.76 oz , not ml. Much the same as this one
http://www.amazon.com/Systems-610-Ha...iglink20264-20
You use a regular caulking gun to dispense it.
Saw it talked about here: http://www.rcgroups.com/forums/showp...&postcount=210 read the 2 following post too.
1/2 the price of similar sized Hysol.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 23, 2014, 06:33 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
Love that it uses a regular caulking gun! I read that you need to use it all at once or replace the nozzle. Is that right?
Old Oct 23, 2014, 06:46 PM
Joined Dec 2008
I couldn't tell you, I haven't bought or used any as of yet, but plan on getting some .
I just PM'd turbonut to see if he would add his expertise on the subject.
Just hang tight--
Old Oct 23, 2014, 07:03 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
If you use small amounts just pump it out on a plate and mix like 2 part epoxy. If you need to use a lot use the mixing tip.when done remove the tip and toss it and reinstall the cap. keep for a long time that way. But use a good quality gun to mix as its a bit stiff and will wear you out pumping it
turbonut is online now Find More Posts by turbonut
Old Oct 23, 2014, 07:25 PM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
McMasters has the gun at the bottom of the linked page. I know at work they would break them, or strip the plunger fairly often. I never broke one, was careful. And would hand mix from a larger container if I needed lots of resin.
Roto Rob is online now Find More Posts by Roto Rob
Old Oct 23, 2014, 07:42 PM
Joined Dec 2008
Yes, But that one only holds the 1.69 oz/50 ml cartridges, the 9460 he's talking about is 6.76 oz/200 ml . The dispensing gun for that one is $91.59.
http://www.mcmaster.com/#7451a51/=ua73di
Just a little to pricy for me!
Old Oct 23, 2014, 10:37 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
Thanks guys. Just noticed It doesn't mention use for plastics in the description. Was hoping to use it for servo mounts and gear door hinges as well. I know hysol works well for this but its so pricey!
Old Oct 23, 2014, 11:02 PM
Joined Dec 2008
Could use double sided tape I suppose.
I've never had an issue with epoxy not holding to plastics.
But then again I never glue my servos in either. I used the old fashioned way--screws.
This might help out.
http://www.westsystem.com/ss/new-six10-epoxy-adhesive/
http://www.westsystem.com/ss/six10-introduction/
Old Oct 23, 2014, 11:15 PM
Denver, CO
Joined Dec 2005
Yes, the gun is expensive. I would make one, before I would pay that much.
Old Oct 24, 2014, 12:08 AM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Trust me six10 will stick to pretty much anything...and any good calking gun works with it
Old Oct 24, 2014, 12:49 AM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
Thanks turbonut I'll give it a try.
Old Oct 24, 2014, 06:15 PM
demetrius is offline
Find More Posts by demetrius
demetrius's Avatar
Van Nuys
Joined Mar 2004
Since we're on the Hysol topic, has anyone used 20 clear? I'm told that it's just as good and cures faster? Comments would be appreciated!
Andrew
demetrius is offline Find More Posts by demetrius
Old Oct 24, 2014, 07:42 PM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
Yes I use the clear , is not to pricey @ the local fastener store.
I t's like 30 minute epoxy but much better . Very strong and not to runny. I rarely use the tip with the dispenser . I just shout some glue with the gun in a cup and mix with a stick. For bulk head I use Hysol or Aeropoxy or the new stuff from Aerothech industry.
bidule is offline Find More Posts by bidule
Old Oct 25, 2014, 08:01 AM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
I've been using dollar store 5minute epoxy for years without any issues.
Is hysol so much stronger than regular epoxy, and do our models really need glue stronger than the materials we are gluing together?
4stripes is online now Find More Posts by 4stripes
Discussion First cp heli? Nano CPx vs mcpx v2 vs mcpx bl vs mcpx bl vs 130x ... gaaunapoi Micro Helis 30 Nov 17, 2014 11:58 PM
Sold Hysol 9360 exf3bguy Aircraft - Sailplanes (FS/W) 2 May 23, 2014 06:21 PM
Discussion Hysol vs JB Weld? jijohans Composites Fabrication 7 Jan 04, 2009 10:05 PM
Discussion Hysol vs JB Weld? jijohans The Builders Workshop 3 Jun 26, 2007 09:49 PM
Discussion Loctite 9462 Hysol MarkJayne Fuel Jet Talk 3 Sep 19, 2006 12:08 PM
