Old Jul 23, 2011, 03:18 AM
Heather is offline
Find More Posts by Heather
Hastings, Hawkes Bay, New Zealand (Aotearoa)
Joined Feb 2000
Unilog Question
I have a question regarding the wiring of the 400A sensor. I am not intending to use the limiter function but also have the brushless rpm sensor I want to use.
Do I need to connect the black wire from the 400A sensor to the negative of the main battery or not?
I have a Kontronik Jive 100LV ESC, Kontronik FAI10 motor & a 3s Battery. I'm also running a small Rx battery in parallel with the BEC in the Jive ESC.
Heather
Heather is offline Find More Posts by Heather
Old Jul 23, 2011, 07:27 AM
Robert Hermens is offline
Find More Posts by Robert Hermens
F5B addict with a soft spot!
Robert Hermens's Avatar
Steenwijk/Netherlands
Joined Jun 2009
Black wire
Hi Heather,
If your ESC has a BEC (and the Jive has a superb one) there is no need to connect the black wire because the BEC will power the Unilog and not the Ampssensor.
Robert Hermens
Robert Hermens is offline Find More Posts by Robert Hermens
Old Jul 23, 2011, 04:12 PM
Heather is offline
Joined Feb 2000
Thanks!
I'll wire it up today and give it a test.
Heather
Old Jul 23, 2011, 05:28 PM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Is the rx getting power through the unilog? On mine, I have the rx opto isolated from the unilog, and the rx pack powering the rx directly. I recently had the same question and was told to have the esc bec power the unilog, and to absolutely not wire the big black one from the shunt to the flight pack... though I am using castle ice series escs.
Hope this helps!
la528it is offline Find More Posts by la528it
Discussion SM Unilog Help !!! GeorgiMirov High Performance 44 Jul 14, 2012 10:56 PM
Discussion Unilog Speed Sensor Darron High Performance 4 Nov 03, 2010 04:35 PM
Discussion No Unilog USB driver for 64bit OS (Windows Vista) ? GeorgiMirov High Performance 7 Aug 23, 2009 03:20 PM
Discussion FAI 18 with unilog. Do i need the opto cable? JWS High Performance 2 Jun 08, 2009 02:35 PM
Discussion buying unilog in the US? flying evader High Performance 3 Aug 12, 2008 03:33 PM
