Old Feb 17, 2011, 02:53 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
Build Log
H&M Skyper Mono 1
Hi guys!
I saw this hull last year and I thought I'll give it a try. Excellent quality as usual, good finish and very solid.
One thing I changed from the original is the height of the cockpit: added about 2cm to help the floodchamber.
Hardware: Stinger - home made, with 2 pcs 8x5mm H&M teflon bearings
Cable - H&M 3.2mm x 5mm with M4 or Dog Drive
Cupler - H&M 5mmx3.2mm
Motor support - home made
Props - Graupner Carbon 35, 37.5; Octura X437
Electric:
Motor - Leopard 4042 4000kv (1200W max)
ESC - Sunrise 100A BEC
Baterii - 2S: No name 5200 30C or Etti 5200 20C
Servo - not yet decided, but definitely a mini
RX/Tx- Spektrum Dx5, Orange DSM2 6ch receiver
Still waiting for a Graupner rudder or an Etti do see which fits best...
CornelP is offline Find More Posts by CornelP
Old Feb 17, 2011, 05:31 AM
blazalb is offline
Find More Posts by blazalb
blazalb's Avatar
Slovenija
Joined Dec 2007
Hello!
I am also a skyper owner, i haven't make flood chamber to work jet, but the boat is super stabile so flood chamber is not so urgent, still it's a good idea.
Will you install the flood chamber suplied by hydro marine? (that weird thing that's supoast to go in the back of the boat)
I got my boat with it already instaled and had a lot of problems ataching the strut.
5200mah is a good idea, don't use any less as the boat is not so economical with power (same setup on a diferent boat will have less consumption)
Your boat looks very good, have fun racing it
here is my boat http://www.freewebs.com/blazalb1/skyper.htm
blazalb is offline Find More Posts by blazalb
Old Feb 17, 2011, 07:47 AM
CornelP is offline
CornelP's Avatar
Bucharest, RO
Joined May 2009
Yours looks better in red I started buying/building yellow boats and I'm trying to stick to it...
I am trying to avoid the use of their "box" by modifying the cockpit. Hopefully it will be ok.
You get decent race speeds with the 540S? I have a couple of them, as well as some 28mm from Leopard in 4000kv, so this option is still open. The 28mm Leopard is rated at 1000W vs the 630W of the Feigao 540S series, so I could be ok and save some weight and current...
Old Feb 17, 2011, 03:46 PM
blazalb is offline
blazalb's Avatar
Slovenija
Joined Dec 2007
Well I actualy wanted a yellow hull but the color wasn't awalible at the time...but red turned out very good
I had a 380S no name 3900kv motor and a graupner k37.5 propeler on a race, didn't go as fast as it should as a had prblems with rudder being to wide and slowing down my boat.
I did replace the rudder but still, 540S gives me more speed, but I only tested it once for now (frozen lake, burned ESC etc.)
Here in Slovenia, most people have 540S size motors in Mono1 category...
Am looking forward to see a video of your boat :P
Old Feb 19, 2011, 11:35 AM
karfrik is offline
Find More Posts by karfrik
karfrik's Avatar
United States, TX, Fort Worth
Joined Apr 2009
Hey Cornel,..what the lenght on this hull?....Albert
karfrik is offline Find More Posts by karfrik
Old Feb 20, 2011, 02:18 AM
CornelP is offline
CornelP's Avatar
Bucharest, RO
Joined May 2009
Hi Albert, it's 630mm long.
For Sale H & M Supercat M-1 TWINS 34" Like New Pro Built jmscard Boats (FS/W) 0 Feb 07, 2011 10:06 AM
Discussion H&m intruder s 101 Kph!! CornelP Racing Boats - Electric 27 Oct 27, 2010 01:12 AM
Build Log YAK 55 M MagicHand 1,56 m G.Hanssmann Sport Planes 2 Oct 26, 2010 02:42 PM
Discussion Suspension from Hormann TK-10 on H.A.R.M. BX3 H.A.R.M. BX3 Off-road Cars 2 Sep 22, 2010 06:27 PM
Sold H&M Spitfire TDisaster Aircraft - Electric - Airplanes (FS/W) 6 Sep 14, 2010 04:01 PM
